DRKT
- Oct 8, 2003
Centos 6 (64 bit) i install with last custombuild 2.0 (rev 2494) but not work and if i restart service:
[root@xxx ~]# service netdata restart
Stopping netdata... [FAILED]
Starting netdata...2020-05-15 16:59:01: netdata INFO : MAIN : CONFIG: cannot load cloud config '/opt/netdata/var/lib/netdata/cloud.d/cloud.conf'. Running with internal defaults.
2020-05-15 16:59:01: netdata INFO : MAIN : SIGNAL: Not enabling reaper
2020-05-15 16:59:01: netdata ERROR : MAIN : LISTENER: UNIX bind() on path '/var/run/netdata/netdata.sock' failed. (errno 2, No such file or directory)
2020-05-15 16:59:01: netdata ERROR : MAIN : LISTENER: Cannot create unix socket '/var/run/netdata/netdata.sock'
2020-05-15 16:59:01: netdata FATAL : MAIN :LISTENER: Cannot listen on any API socket. Exiting... # : Invalid argument
2020-05-15 16:59:01: netdata INFO : MAIN : EXIT: netdata prepares to exit with code 1...
2020-05-15 16:59:01: netdata INFO : MAIN : EXIT: cleaning up the database...
2020-05-15 16:59:01: netdata INFO : MAIN : Cleaning up database [0 hosts(s)]...
2020-05-15 16:59:01: netdata INFO : MAIN : EXIT: removing netdata PID file '/opt/netdata/var/run/netdata/netdata.pid'...
2020-05-15 16:59:01: netdata ERROR : MAIN : EXIT: cannot unlink pidfile '/opt/netdata/var/run/netdata/netdata.pid'. (errno 2, No such file or directory)
2020-05-15 16:59:01: netdata INFO : MAIN : EXIT: all done - netdata is now exiting - bye bye...
[FAILED]
[FAILED]
