factor Verified User Joined Jul 22, 2017 Messages 3,650 Location USA May 21, 2020 #1 Version 1.61.0 | Directadmin Docs DirectAdmin Knowledge Base www.directadmin.com The feature talks about Enhanced skin. But I don't see anything on Evo. Where should I be looking?
smtalk Administrator Staff member Joined Aug 22, 2006 Messages 8,992 Location LT, EU May 21, 2020 #2 If rspamd has been installed using CustomBuild, without any customizations to ports/socket paths (as it needs to find the socket) - it should be shown on admin level Try re-building rspamd if it isn't shown there.
factor Verified User Joined Jul 22, 2017 Messages 3,650 Location USA May 21, 2020 #3 smtalk said: admin level Click to expand... I did yum remove rspamd then ./build rspamd then looked in Plugin section and Mail Queue section There is no GUI screen just a blank. Attachments Screen Shot 2020-05-21 at 10.09.40.png 249.2 KB · Views: 38
MaXi32 Verified User Joined Jul 25, 2016 Messages 643 Location The Earth Jun 20, 2020 #4 bdacus01 said: Version 1.61.0 | Directadmin Docs DirectAdmin Knowledge Base www.directadmin.com The feature talks about Enhanced skin. But I don't see anything on Evo. Where should I be looking? Click to expand... Same here, but a workaround if you still need to access into the rspamd native UI, you do through custom link: Go to Customize Evolution Skin -> Extra Features -> Add Entry (Add Link): For URL put this: CMD_RSPAMD_SOCK For the name: Rspamd UI Icon: plugin-manager Now you can see the icon. Or I think you can just reset your menu to the default setting to see the hidden menu.
