DirectAdmin 1.61.0 RC1 netdata issues
DRKT
Centos 6 (64 bit) i install with last custombuild 2.0 (rev 2494) but not work and if i restart service:
[root@xxx ~]# service netdata restart
Stopping netdata... [FAILED]
Starting netdata...2020-05-15 16:59:01: netdata INFO : MAIN : CONFIG: cannot load cloud config '/opt/netdata/var/lib/netdata/cloud.d/cloud.conf'. Running with internal defaults.
2020-05-15 16:59:01: netdata INFO : MAIN : SIGNAL: Not enabling reaper
2020-05-15 16:59:01: netdata ERROR : MAIN : LISTENER: UNIX bind() on path '/var/run/netdata/netdata.sock' failed. (errno 2, No such file or directory)
2020-05-15 16:59:01: netdata ERROR : MAIN : LISTENER: Cannot create unix socket '/var/run/netdata/netdata.sock'
2020-05-15 16:59:01: netdata FATAL : MAIN :LISTENER: Cannot listen on any API socket. Exiting... # : Invalid argument
2020-05-15 16:59:01: netdata INFO : MAIN : EXIT: netdata prepares to exit with code 1...
2020-05-15 16:59:01: netdata INFO : MAIN : EXIT: cleaning up the database...
2020-05-15 16:59:01: netdata INFO : MAIN : Cleaning up database [0 hosts(s)]...
2020-05-15 16:59:01: netdata INFO : MAIN : EXIT: removing netdata PID file '/opt/netdata/var/run/netdata/netdata.pid'...
2020-05-15 16:59:01: netdata ERROR : MAIN : EXIT: cannot unlink pidfile '/opt/netdata/var/run/netdata/netdata.pid'. (errno 2, No such file or directory)
2020-05-15 16:59:01: netdata INFO : MAIN : EXIT: all done - netdata is now exiting - bye bye...
[FAILED]
And... if i remove, i have this error:
Deleting netdata user from squid group ...
[/root]# gpasswd -d netdata squid
gpasswd: group 'squid' does not exist in /etc/group
FAILED
Try:
mkdir -p /var/run/netdata/
chown netdata:netdata /var/run/netdata
ok good, but i have this message:
Stopping netdata... [ OK ]
Starting netdata...2020-05-15 17:34:42: netdata INFO : MAIN : CONFIG: cannot load cloud config '/opt/netdata/var/lib/netdata/cloud.d/cloud.conf'. Running with internal defaults.
2020-05-15 17:34:42: netdata INFO : MAIN : SIGNAL: Not enabling reaper
[ OK ]
and if i go on http://xxx.xxx.xxx.xxx:19999 ... not work
and when install netdata, i have this:
--- Add user netdata to required user groups ---
Group 'docker' does not exist.
FAILED Failed to add netdata user to secondary groups
Group 'nginx' does not exist.
Group 'varnish' does not exist.
Group 'haproxy' does not exist.
Adding netdata user to the adm group ...
[/opt/netdata]# usermod -a -G adm netdata
OK
Group 'nsd' does not exist.
Group 'proxy' does not exist.
Group 'squid' does not exist.
Group 'ceph' does not exist.
Adding netdata user to the nobody group ...
[/opt/netdata]# usermod -a -G nobody netdata
OK
Group 'I2C' does not exist.
:19999 shouldn't work :) Try accessing it directly from DirectAdmin interface.
ok, netdata-updater run this night, and after netdata not work.
i remove and reinstall Netdata, and i run manually /etc/con.daily/netdata-updater ... and same problem.
and when remove netdata, it's not remove from DA panel.
/opt/netdata/usr/libexec/netdata/netdata-uninstaller.sh --yes
Are you sure process isn't there anymore?
ps auxwf | grep netdata
Hi @smtalk,
I have uninstalled Netdata and reinstalled via CB.
./build netdata
Now, I don't see any Netdata icon in DA.
My DA version is 1.60.4, would this be the reason?
For the link in DA panel "Netdata server metrics" after remove, not remove in DA panel.
And netdata is not in Service Monitor.
i have this message on https://app.netdata.cloud/ account: (i see server in panel but not connect)
This node is unreachable
This can be a temporary problem of that specific node if this problem persists please contact your administrator.
i install with last DA version 1.61 and i have same error on 4 servers (test) and same problems
ok, but all Netdata crash each day for this /etc/con.daily/netdata-update
Why? i test retart this but not work... i remove nd reinstall each time
