SupermanInNY
- Sep 28, 2004
Hi All,
CentOS 7, new install, added two IPs on primary interface ens160
./startips: line 49: 1.2.3.4: command not found
./startips: line 49: 5.6.7.8: command not found
If I drop an IP and then re-add it in the DirectAdmin, it is then showing up on the interface:
# ip a show
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
2: ens160: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 00:50:56:b4:34:be brd ff:ff:ff:ff:ff:ff
inet 1.2.3.4/25 brd 1.2.3.127 scope global noprefixroute ens160
inet 5.6.7.8/25 scope global secondary ens160
3: ens192: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 00:50:56:b4:2f:a9 brd ff:ff:ff:ff:ff:ff
inet 192.168.4.19/24 brd 192.168.4.255 scope global noprefixroute ens192
/usr/local/directadmin/scripts # ifconfig
ens160: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 1.2.3.4 netmask 255.255.255.128 broadcast 62.90.141.127
ether 00:50:56:b4:34:be txqueuelen 1000 (Ethernet)
RX packets 650583 bytes 104244279 (99.4 MiB)
RX errors 0 dropped 51 overruns 0 frame 0
TX packets 408034 bytes 36323686 (34.6 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
ens192: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.4.19 netmask 255.255.255.0 broadcast 192.168.4.255
ether 00:50:56:b4:2f:a9 txqueuelen 1000 (Ethernet)
RX packets 155224 bytes 9570414 (9.1 MiB)
RX errors 0 dropped 156 overruns 0 frame 0
TX packets 8 bytes 432 (432.0 B)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
loop txqueuelen 1000 (Local Loopback)
RX packets 1329 bytes 137493 (134.2 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 1329 bytes 137493 (134.2 KiB)
But, after running service network restart and
./startips
I get
# ip a show
disregard the ens192 -it is a secondary IP for internal communications
Any pointers?
-Sup.
# ip a show
./startips
I get
# ip a show
Any pointers?
-Sup.
