Nginx and Apache - Nginix wont start due to mod_security
Brenden
Hi All
Did anyone else experience this overnight?
Nginx stopped all 4 of my servers with mod_security errors. Commenting out the line and mod_security off fixed it
Hi All
What was the error? Didn't ./build nginx help?
What ruleset are you using Comodo? If yes it’s not compatible with nginx
Sorry! The error is below. Yes, I was using Comodo - didn't realise it wasn't supported as it was working.
nginx[31780]: nginx: [emerg] "modsecurity_rules_file" directive Rules error. File: /usr/local/cwaf/>
nginx[31780]: nginx: configuration file /etc/nginx/nginx.conf test failed
Commenting out mod_security in /etc/nginx/nginx-modsecurity-enable.conf and reloading Nginx fixed it.
May you check if the problem is the same after "./build rewrite_confs"? If it solves the issue - may you try "./build nginx" after? If it doesn't - please try owasp ruleset.
modsecurity_ruleset - chooses ModSecurity Rule Set to install when "./build modsecurity_rules", "./build modsecurity", "./build apache", "./build nginx" or "./build all d" is ran. Set to 'no' to use no ruleset (or to use a custom one, uploaded to custom/modsecurity/conf directory. Comodo option provides Comodo Rule Set for ModSecurity: https://modsecurity.comodo.com/. OWASP ModSecurity Core Rule Set: https://www.owasp.org/index.php/Category:OWASP_ModSecurity_Core_Rule_Set_Project. Add custom rules to custom/modsecurity/conf, they are added automatically to /etc/modsecurity.d after './build modsecurity' or './build modsecurity_ruleset' is ran. Nginx is not compatible with Comodo Rule Set yet. Possible values: comodo/owasp/no. (default: comodo).
Fixed! Thank you for the report :) They released a version compatible with nginx (I hope it still works fine).
We've got multiple reports like this, it seems to be Imunify ruleset related. I guess you're running Imunify as well?
Imunify team replied that they've fixed it in their last ruleset:
imunify360-agent update modsec-rules --force
So you can now use the standard comodo with the latest version of nginx? Great if that’s true.
In DA latest version 1.61.5, if I include options.conf before DA installation using these values:
Apache config:
#WEB Server Settings
webserver=nginx_apache
modsecurity=yes
modsecurity_ruleset=comodo
Then nginx couldn't be started with the error related to modsecurity directive but rebuilding nginx_apache again fixed this problem:
./build nginx_apache
Apache config:
modsecurity=yes
I would like to confirm that this has been fixed in directadmin 1.62+. I don't have to rebuild anymore.
