Directadmin personal screenshot?
psalm91
Any body has screenshot of a Directadmin personal?
1 account and 10 domains
Right now i have a cpanel with two domains
mydomain.com
subdomain.mydomain.com
these two domains actually one is subdomain have two cpanel account
Does that mean If I get a personal license I will have one Da account and my other subdomain will have to treated a subdomain only or like addon domain?
I can't separate them? Any image or pictures? Thanks
It's mean you can only have " ADMIN " OR
" Create Domain , Add Another Domain " can only have 10 domain.
if you want to add subdomain , you can use " Subdomain Management " in your domains that you want to use.
It's not OR. It's AND. You can only have Admin user AND have 10 domains under user admin (not under or as another user)
Also you can have subdomains under admin, under the domains present.
In no way... really no way, try to restore these on a personal account automatically. You have to merge the two accounts into one.
So transfer one to the presonal account being account admin on the personal license DA.
After that, manually integrate the subdomain and import website and database.
Domain and subdomains will be treated like real domains and subdomains, but limited to 1 user account which is admin.
