SSL_write() failed (SSL: error:140800FF:SSL routines:ssl3_accept:unknown state) while processing HTTP/2
mentik_yusmantara
Bali, Indonesia
Help, sir
I have a problem in server log...
2020/06/13 06:01:44 [crit] 8835#0: *68438 SSL_write() failed (SSL: error:140800FF:SSL routines:ssl3_accept:unknown state) while processing HTTP/2 connection, client: 114.124.174.169, server:
2020/06/13 06:01:44 [crit] 8836#0: *68439 SSL_write() failed (SSL: error:140800FF:SSL routines:ssl3_accept:unknown state) while processing HTTP/2 connection, client: 114.124.174.169, server:
2020/06/13 06:02:12 [crit] 8834#0: *68469 SSL_write() failed (SSL: error:140800FF:SSL routines:ssl3_accept:unknown state) while processing HTTP/2 connection, client: 114.124.174.169, server:
I using Let's Encrypt SSL.
The SSL work, but i see this massage in server log...
i have seen before, not secure, then i reload page... (secure again)
How i can fix this or why its happened?
Thanks sir ...
I don't know while is and could be client depended. ( using "old" client software whatever)
So if so and it is you connection you are using that is giving the log message, take care to not block yourself , first be sure what you are using support default tls 1.2 or higher is recomended, and do some real tests.
Please i can't help while not working with to "old" things.
First look at de OS and versions you're using for clients and also server! Then do some websearch..
I am not sure if what i posted is your problem!
Thanks Ikkeben for your answer :)
@bdacus01 i using CentOs 7 64 bit
here the options.conf in /usr/local/directadmin/custombuild/options.conf
#Advanced Settings
autoconf=yes
automake=yes
libtool=yes
curl=yes
new_pcre=yes
ssl_configuration=intermediate
Are these users that have these errors.
Or are these errors you see by accessing DA?
Are you using a LAN based system where the server IP is a Private address like 192.168.x.x?
what is your openssl version
 openssl version
Please
I also get this, i just cheked
2020/06/16 07:25:56 [crit] 846#0: *294756 SSL_do_handshake() failed (SSL: error:1006706B:elliptic curve routines:ec_GFp_simple_oct2poin: point is not on curve error:1408B010:SSL routines:ssl3_get_client_key_exchange:EC lib) while SSL handshaking, client: 114.4.221.42, server: 185.149.xxx.xxx:443
its different error log information
is not supported by RH/Centos based systems last I checked. It means someone is trying to connect with really old software most likely
for ssl3 I hope you didn't enable that somehow.
use this guide to test your server the various methods.
Thanks for the answer... @bdacus01
Looking for that test...
Yes, i think the people access the port
185.149.xxx.xxx:443
And its not show same result as https://help.directadmin.com/item.php?id=316
CONNECTED(00000003)
write:errno=104
no peer certificate available
No client certificate CA names sent
SSL handshake has read 0 bytes and written 0 bytes
New, (NONE), Cipher is (NONE)
Secure Renegotiation IS NOT supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
SSL-Session:
Protocol : TLSv1.1
Cipher : 0000
Session-ID:
Session-ID-ctx:
Master-Key:
Key-Arg : None
Krb5 Principal: None
PSK identity: None
PSK identity hint: None
Start Time: 1592351500
Timeout : 7200 (sec)
Verify return code: 0 (ok)
When access it manual will show
400 Bad Request
The plain HTTP request was sent to HTTPS port
nginx
