I have one domain.
I am putting domain pointers under that domain.
When I try to install the wildcard Certificate NIST/SECG 384 bit, you can't install just one once you have others installed, you need to install them all again.
Does this count against the 100 per week? ie I have 34 selected entries installed. If I tick just one new one then the old installed ones get removed and only the new one gets installed. I just found out so I am not sure.
So if I do this anymore I have to wait a week?
Is there a way to keep the ones installed and just install new ones?
