Error after update with custombuild
aswinvine
Helle there,
After i updated DirectAdmin with custombuild 2.0 directadmin cant startup anymore.
If I do systemctl status directadmin I got this error:
directadmin.service - DirectAdmin Web Control Panel
Loaded: loaded (/etc/systemd/system/directadmin.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Fri 2020-06-12 23:23:47 CEST; 1 day 15h ago
Docs: http://www.directadmin.com
Process: 864 ExecStart=/usr/local/directadmin/directadmin d (code=exited, status=1/FAILURE)
Jun 12 23:23:47 webpanel.tijdvoortrek.nl systemd[1]: Starting DirectAdmin Web Control Panel...
Jun 12 23:23:47 webpanel.tijdvoortrek.nl directadmin[864]: /usr/local/directadmin/directadmin: /lib64/libcrypt.so.1: version `XCRYPT_2.0' not found (required by /usr/local/directadmin/directadmin)
Jun 12 23:23:47 webpanel.tijdvoortrek.nl directadmin[864]: /usr/local/directadmin/directadmin: /lib64/libc.so.6: version `GLIBC_2.22' not found (required by /usr/local/directadmin/directadmin)
Jun 12 23:23:47 webpanel.tijdvoortrek.nl directadmin[864]: /usr/local/directadmin/directadmin: /lib64/libc.so.6: version `GLIBC_2.28' not found (required by /usr/local/directadmin/directadmin)
Jun 12 23:23:47 webpanel.tijdvoortrek.nl directadmin[864]: /usr/local/directadmin/directadmin: /lib64/libc.so.6: version `GLIBC_2.25' not found (required by /usr/local/directadmin/directadmin)
Jun 12 23:23:47 webpanel.tijdvoortrek.nl systemd[1]: directadmin.service: control process exited, code=exited status=1
Jun 12 23:23:47 webpanel.tijdvoortrek.nl systemd[1]: Failed to start DirectAdmin Web Control Panel.
Jun 12 23:23:47 webpanel.tijdvoortrek.nl systemd[1]: Unit directadmin.service entered failed state.
Jun 12 23:23:47 webpanel.tijdvoortrek.nl systemd[1]: directadmin.service failed.
How can I fix this?
Wrong OS set in DA license :) I'd suggest Linux 64bit as it works on all the Linux distributions. Otherwise just select the OS you're running.
