Rspamd Plugin
jamesf
When using the default Rspamd plugin for DirectAdmin, it seems very limited with what you can see.
it seems to only show:
TimeWorker typePIDModuleInternal IDMessage
I have seen it where in the History it shows:
IDIP address[Envelope From] From[Envelope To] To/Cc/BccSubjectActionScoreMsg sizeScan timeTimeAuthenticated user
I can also see an error saying:
cannot init backend redis for statfile BAYES_HAM
well
you might find these helpful
honestly, all I did was right-click on your error and choose Search Google
OK. I did:
# yum remove redis
yum install redis
vi /etc/rspamd/local.d/redis.conf
added this: servers = "127.0.0.1";
seems to show the full menu now..... seems the DA documentation could do with a few more bits adding to it......
after restarting server, get this error:
got error Connection refused when getting history: no value
Thank You, I am trying you use the built in DA plugin... ? perhaps you could point me to the correct docs please?
I installed Redis, following this: https://www.interserver.net/tips/kb/install-redis-and-redis-php-in-directadmin/
and it didn't seem to make any difference?
For shared hosting I recommend using redis on a socket. I use the following set up for rspamd + redis on centos8
Install and enable:
yum install redis
systemctl enable redis
edit /etc/redis.conf
bind 127.0.0.1
port 0
unixsocket /var/lib/redis/rspamd/rspamd.sock
unixsocketperm 770
pidfile /var/run/redis/rspamd.pid
logfile /var/log/redis/rspamd.log
dir /var/lib/redis/rspamd/
Now create the db dir and set permissions
mkdir -p /var/lib/redis/rspamd/
chown redis:redis /var/lib/redis/rspamd/
systemctl start redis
Create /etc/rspamd/local.d/redis.conf and add
servers = "/var/lib/redis/rspamd/rspamd.sock";
Finally verify and restart:
rspamadm configtest && systemctl restart rspamd
Since DA has Rspamd built in... it’s kinda strange it’s not supported when you set it to rspamd... hopefully something for the future.
