mod_security does not enable when using custombuild? nginx_apache
MaXi32
The Earth
I use nginx_apache for my server and I install mod_security using this guide: https://malware.expert/howto/install-modsecurity-directadmin-custombuild-2-x/ but I use only comodo rule
In this file, /etc/httpd/conf/extra/httpd-modsecurity.conf I got the following commented LoadFile and LoadModule
#LoadFile /usr/local/lib/libxml2.so #LoadModule security2_module /usr/lib/apache/mod_security2.so ... ... ...
I can see that there is also a custom mod_security file in /usr/local/directadmin/custombuild/custom/ap2/conf/extra/httpd-modsecurity.conf and the 2 first lines are not commented. The content is as follow:
<IfModule mod_security2.c>
    # Default recommended configuration
    SecRuleEngine On
    SecRequestBodyAccess On
    SecDefaultAction "phase:2,deny,log,status:406"
    SecRequestBodyLimitAction ProcessPartial
    SecResponseBodyLimitAction ProcessPartial
    SecRequestBodyLimit 13107200
    SecRequestBodyNoFilesLimit 131072
    SecPcreMatchLimit 250000
    SecPcreMatchLimitRecursion 250000
    SecCollectionTimeout 600
    SecDebugLog /var/log/httpd/modsec_debug.log
    SecDebugLogLevel 0
    SecAuditEngine RelevantOnly
    <IfModule mod_ruid2.c>
    SecAuditLogDirMode 1733
        SecAuditLogFileMode 0550
        SecAuditLogType Concurrent
        SecAuditLogStorageDir /var/log/modsec_audit
    </IfModule>
    SecAuditLog /var/log/httpd/modsec_audit.log
    SecUploadDir /tmp
    SecTmpDir /tmp
    SecDataDir /tmp
    SecTmpSaveUploadedFiles on
    # ModSecurity Core Rules Set and Local configuration
    IncludeOptional /etc/modsecurity.d/*.conf.main
</IfModule>
whenever I run
./build rewrite_confs ./build modsecurity_rules
I thought the file in /etc/httpd/conf/extra/httpd-modsecurity.conf, will get replaced by /usr/local/directadmin/custombuild/custom/ap2/conf/extra/httpd-modsecurity.conf but the 2 lines still being commented even I manually change it. Why is that so ?
System details:
I use nginx_apache reverse proxy. and I read that modsecurity is compatible with nginx. https://forum.directadmin.com/threa...t-start-due-to-mod_security.61427/post-315229
Compiled onCentOS 8.0 64-Bit
Compile DateJun 8 2020, 18:53:38
Server Version1.61.3
Current Available Version1.61.3
Last UpdatedTue Jun 9 15:24:14 2020
Last RestartFri Jun 19 03:53:46 2020
ModSecurity doesn't need to be loaded on nginx and apache, as this would be too redundant. You have it loaded on nginx side, as it's the one receiving requests first :)
