All:
Just in case you did not know. AbuseIPDB allows auto reporting of the "bad guys" with CSF and Others. You just need a free account.
The main link is here https://www.abuseipdb.com/
CSF link is https://www.abuseipdb.com/csf
Fail2Ban link https://www.abuseipdb.com/fail2ban.html
The csf integration works great.
They even have a bulk reporter log scanner as well.
Bulk link https://www.abuseipdb.com/bulk-report
AbuseIPDB provides a free API for reporting and checking IP addresses.
Every day webmasters, system administrators, and other IT professionals use our API to report thousands of IP addresses engaging spamming, hacking, vulnerability scanning, and other malicious activity in real time.
ConfigServer Security & Firewall(csf) is a stateful packet inspection (SPI)
firewall, Login/Intrusion Detection
and security application for Linux servers.
In this tutorial, we will learn how to set up CSF so that attempted intrusions against your system are automatically blocked. It is also possible to use CSF to pre-emptively block IP addresses in our blacklist.
