Select openlitespeed release branch
dmtinc
Chile
As openlitespeed 1.7.x is having problems with quic and the 1.6.x versions are working OK, ¿it is possible add the option to select in custombuild the release branch between 1.7.x or 1.6.x?
I know is possible to force the 1.6.13 version using custom_versions but this prevent to update to new versions of the 1.6.x release, as the 1.6.14 version (not yet at DA repos).
Something like the options of apache or phpmyadmin:
apache_ver=2.4
phpmyadmin_ver=4
A reference for the quic problem:
Regards!
Did you try 1.7.2?
Now quic is working, but I'm think the branch 1.6.x its more "mature" or "stable" compared with the 1.7.x, the quic feature was always working on the 1.6.x version and in the 1.7 , between the 1.7.1 and the 1.7.2 , was two months with the problem.
As the two branch still supported from openlitespeed, the selection in CB, still be a good option in my opinion.
what change log?
You can check the changelog here:
