- Feb 27, 2003
We would like to make an announcement about an issue we've discovered about recent issues with PHP 7.4 on CentOS 7, requiring recompilation of PHP ("./build php n") after issuance of "yum update", even if this update was automated.
Affecting
Affecting systems with all 3 conditions:
The oniguruma library is no longer bundled with PHP 7.4, instead libonig needs to be available on the system (or --disable-mbregex used to disable the mbregex component). CentOS 7 epel repository, which was used for installation of oniguruma-devel by default, updated their library lately. The update swaps /usr/lib64/libonig.so.2 with /usr/lib64/libonig.so.5 and breaks the linking of the library for /usr/local/php74/sbin/php-fpm74 (and other) binary files, that results in PHP outage.
Errors
You'd see an error that might look like this:
Solution
A simple recompile of php will do the trick:
If you run multiple versions as PHP, and you'd like to recompile just PHP-FPM 7.4 (for example) you may use the following command:
We hope the advanced warning will help mitigate the issue for anyone affected.
Affecting
- CentOS 7
- php 7.4 (all modes: php-fpm, cli, fastcgi)
- yum update of oniguruma package
Errors
/usr/local/bin/php: error while loading shared libraries: libonig.so.2: cannot open shared object file: No such file or directory
Solution
/usr/local/directadmin/custombuild/build php n
/usr/local/directadmin/custombuild/build php_expert 7.4 php-fpm
