software version is 0
psalm91
Is this normal?
The current version does now show so do I need to click udpate or not?
There is likely never going to be a scenario where you don't need to click update when CustomBuild notifies you.
Unless they are not configured for use and need to be removed, or there is a bug in the release. You should update them and check settings :)
OK thanks . Got it:)
