needhelppp
- Jul 1, 2020
So I guess updating the PHP version is what started all this mess for me? ;/
The same situation here, ./build modsecurity , fix the problem, but we discover the problem after:
- Install new versions of php
- Change the IP of a server (using the script of DA for this)
I think if the apache template file of the modsecurity included in custombuild changes but a recompile of modsecurity isnt included or forced, you will face the problem with any action related to the apache config, and the ./build rewrite_confs is a very popular command to face a problem or any change.
Regards
./build modsecurity on update time when confs are rewritten)."./build update_versions" shouldn't update modsecurity config if no related items got updated. What was updated in the list? Didn't you run "./build rewrite_confs"?
Thank you for the information!
2020-07-03 20:17:29 vpn: DirectAdmin update requested
2020-07-03 20:17:31 vpn: Lego 3.8.0 installed
2020-07-03 20:17:32 vpn: Let's Encrypt client update requested
2020-07-03 20:18:30 vpn: Proftpd 1.3.6d installed
2020-07-03 20:18:49 vpn: nghttp2 1.41.0 installed
2020-07-03 20:19:13 vpn: pcre2 10.35 installed
2020-07-03 20:19:15 vpn: Awstats 7.8 installed
2020-07-03 20:19:15 vpn: awstats_process.sh updated to 2.9
2020-07-03 20:19:34 vpn: EasySpamFighter 1.31 installed
2020-07-03 20:19:35 vpn: exim.conf installed
2020-07-03 20:19:35 vpn: Exim 4.94 installed
2020-07-03 20:19:36 vpn: composer 1.10.8 installed
2020-07-03 20:20:18 vpn: s-nail 14.9.19 installed
2020-07-03 20:21:34 vpn: zstd 1.4.5 installed
2020-07-03 20:26:28 vpn: Ioncube 10.4.0 installed
2020-07-03 20:26:51 vpn: PHP 7.3.19 installed
2020-07-03 20:26:53 vpn: called: php_expert 7.3 php-fpm
2020-07-03 20:26:56 vpn: RoundCube 1.4.5 installed
2020-07-03 20:26:57 vpn: called: update_versions
# yum repolist
repo id repo name
AppStream CentOS-8 - AppStream
BaseOS CentOS-8 - Base
Zabbix_8_x86_64 Zabbix_8_x86_64
Zabbix_nonsupported_8_x86_64 Zabbix_nonsupported_8_x86_64
epel Extra Packages for Enterprise Linux 8 - x86_64
epel-modular Extra Packages for Enterprise Linux Modular 8 - x86_64
extras CentOS-8 - Extras
Was it yajl-devel? CentOS6? If it's centos6, the one you installed is too old, and CB needs to be used for it.
Hello, a lot got said since, but as a reply;
I'm running CentOS 8.2
I searched for the yajl-devel, but it can't be found.
./build modsecurity didn't fix it, and I can this in the output;
No match for argument: lua-devel
Error: Unable to find a match: lua-devel
Last metadata expiration check: 2:29:36 ago on Sat Jul 4 07:25:09 2020.
No match for argument: yajl-devel
Error: Unable to find a match: yajl-devel
I've detected a typo in a variable which should enable PowerTools on CentOS8, fixed in CB 2.0 rev. 2524, thank you for the report.Sorry for the double post.
I enabled the powertools repo. Then it could find the yajl-devel package. Then did the ./build update_versions and modesecurity was build.
Everything seems to be back to normal now
I'm sorry, bugs are natural in software... This doesn't mean the software shouldn't be tested throughly. There is a reason why giants like Android or iOS release updates with bugfixes, the same must be done by your OS. It doesn't mean we're not testing it through, some bugs just go through the testing phase and go unnoticed for a longer time even in production, and I guess everyone is affected (linux kernel, windows, macos, you name it)2524 has solved it for us. Thanks for fixing this during the weekend.
Is this something we can prevent in the future? Are there any beta's that people can test before things like these hit production?
Yes, they are different. See https://www.modsecurity.org. ModSecurity 3.0 (libModsecurity) has no stable version for Apache yet, thus ModSecurity 2.9 is used.In the CustomBuild - Build tab i see option to Build ModSecurity and an option to Build libModsecurity (which does not have any setting in Edit tab). What are those Modsecurities, why is there two? And if they are different, what are their purposes?
I'm sorry, bugs are natural in software... This doesn't mean the software shouldn't be tested throughly. There is a reason why giants like Android or iOS release updates with bugfixes, the same must be done by your OS. It doesn't mean we're not testing it through, some bugs just go through the testing phase and go unnoticed for a longer time even in production, and I guess everyone is affected (linux kernel, windows, macos, you name it)![]()
AH00526: Syntax error on line 12 of /etc/httpd/conf/extra/httpd-modsecurity.conf:
Invalid command 'SecAuditLogFormat', perhaps misspelled or defined by a module not included in the server configuration
make[2]: Leaving directory `/usr/local/directadmin/custombuild/modsecurity-2.9.3'
make[1]: Leaving directory `/usr/local/directadmin/custombuild/modsecurity-2.9.3'
ModSecurity has been installed successfully.
Installing Comodo Rule Set for ModSecurity...
Updating to latest CWAF client version
current version is up to date
update process finished!
Defaulting to Comodo WAF SecDefaultAction...
Installation of ModSecurity Rule Set has been finished.
custombuild]# yum install yajl-devel
Loaded plugins: fastestmirror
Setting up Install Process
Determining fastest mirrors
YumRepo Error: All mirror URLs are not using ftp, http or file.
Eg. Invalid release/repo/arch combination/
removing mirrorlist with no valid mirrors: /var/cache/yum/i386/6/centos-sclo-rh/mirrorlist.txt
Error: Cannot find a valid baseurl for repo: centos-sclo-rh
systemd[1]: Starting The Apache HTTP Server...
httpd[3143246]: AH00526: Syntax error on line 12 of /etc/httpd/conf/extra/httpd-modsecurity.conf:
httpd[3143246]: Invalid command 'SecAuditLogFormat', perhaps misspelled or defined by a module not included in the server configuration
systemd[1]: httpd.service: main process exited, code=exited, status=1/FAILURE
