wordpress demo instalation
saeednajafi
Hello
this is my site:
I am installing a WP demo theme called: dtdrycleaning
WHen I try to install the demo it fails it doesnt tell me why,
The theme comes witht his documation to help with the installation but that doesnt also help, I have also contacted them as well
Can you tell me how to be add those things mentioned in the link above?
Hi, Saeednajafi
Some theme in WP required more resource than standar configuration, here the solution u should try also instead that link
- set php config at php.ini in ur domain HTTPd config
* Max Execution time, commonly 60 ~ 120
* Max input vars, commonly 2000
* Php Memory limit, i use 256M
* Activate Imagick library for image process
* Php post max size, i use 64M
- Set WP-Config
* Wp-momory limit, i set 128M
* set Max Wp-memory limit, i set 256M
ALso its depend ur server resource, now i am use 2GB RAM
Maybe that help
and here are my wp-config and .htaccess
then I added those lines into my htaccess and wt-config,
then imgae 5 takes a long time and then fails.
do you need more information?
also I am using this Following this from the themforest:
Please deactivate the LiteSpeed web server from cpanel (or) Please mail us cPanel login details (Admin username and Admin password)
Deactivate the LiteSpeed https://docs.litespeedtech.com/cp/cpanel/cpanel-plugin/
Note : We have tried all the methods ( Unyson, XML, etc) we have to import the demo content. But we can’t import the demo content.
Refer :
http://manual.unyson.io/en/latest/extension/backups/index.html#litespeed-webserver
this also didnt help me!
I bought a domian + webhosting from this comonay gethosting and they gave my access to direct admin, I installed wordpress application thre and I want to work on my WP theme,
does that answer you question?
becasue I havent been able to do any work in 2 days what do I need to do?
Yes, You should ask your hosting about php.ini configuration to need ur theme,
Administrator privilege is needed for add it, i think...
Your hosting should happy to do that task or wait some one expert here for the exact answer :)
