Litespeed changed to apache automatically after reboot
Desavil
Something strange happened on my server CloudLinux 7 with DirectAdmin today.
There was a high load on the server. I barely logged into the SSH. After logging in I couldn't do anything, so I typed: poweroff -f
Then I started the server and the web server did not start anymore. The other services worked.
httpd[]: AH00526: Syntax error on line 12 of /etc/httpd/conf/extra/httpd-modsecurity.conf:
httpd[]: Invalid command 'SecAuditLogFormat', perhaps misspelled or defined by a module not included in the server configuration
I decided to update all the services on the server (updates I usually do every few months).
yum update
next:
./build update_versions
The web server still did not start.
I decided to reboot the server. After the reboot, I noticed in the process (ps x) that an apache is being built. It surprised me a lot, because I've been using litespeed for a long time.
I checked options.conf and noticed changes in it. For example, the webserver from litespeed has changed to apache, php1_mode from lsapi to fastcgi.
How is it possible that these settings in options.conf have changed themselves?
Why did the apache start to build itself after rebooting the server?
Tab: The Service Monitor (/CMD_SHOW_SERVICES) is empty for me after all this.
Best regards!
Check the logs to see if anybody else has logged into the server.
When the load problem started and during it I see a lot of something like that in the logs:
Jul 15 7:49:08 s kernel: lowmem_reserve[]: 0 0 0 0
Jul 15 7:49:08 s kernel: Node 0 DMA: 1*4kB (U) 0*8kB 0*16kB 1*32kB (U) 2*64kB (U) 1*128kB (U) 1*256kB (U) 0*512kB 1*1024kB (U) 1*2048kB (M) 3*4096kB (M) = 15908kB
Jul 15 7:49:08 s kernel: Node 0 DMA32: 5699*4kB (UEM) 5360*8kB (UEM) 728*16kB (UEM) 6*32kB (U) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 77516kB
Jul 15 7:49:08 s kernel: Node 0 Normal: 2221*4kB (UEM) 7895*8kB (UEM) 1383*16kB (UEM) 211*32kB (UEM) 8*64kB (UM) 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 101436kB
Jul 15 7:49:08 s kernel: Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=2048kB
Jul 15 7:49:08 s kernel: 190312 total pagecache pages
Jul 15 7:49:08 s kernel: 0 pages in swap cache
Jul 15 7:49:08 s kernel: Swap cache stats: add 0, delete 0, find 0/0
Jul 15 7:49:08 s kernel: Free swap  = 0kB
Jul 15 7:49:08 s kernel: Total swap = 0kB
Jul 15 7:49:08 s kernel: 2097018 pages RAM
Jul 15 7:49:08 s kernel: 0 pages HighMem/MovableOnly
Jul 15 7:49:08 s kernel: 94815 pages reserved
Jul 15 7:49:08 s kernel: Out of memory: Kill process 280388 (lsphp) score 1 or sacrifice child
Jul 15 7:49:08 s kernel: Killed process 283030 (lsphp) in VE "0" total-vm:328448kB, anon-rss:7108kB, file-rss:0kB, shmem-rss:1080kB
Jul 15 7:49:08 s kernel: lsphp: page allocation failure: order:0, mode:0x201da
Jul 15 7:49:08 s kernel: CPU: 2 PID: 283030 Comm: lsphp ve: 0 Kdump: loaded Tainted: G           OE  ------------   3.10.0-962.3.2.lve1.5.28.el7.x86_64 #1 61.16
Jul 15 7:49:08 s kernel: Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.11.2-0-gf9626ccb91-prebuilt.qemu-project.org 04/01/2014
Jul 15 7:49:08 s kernel: Call Trace:
Jul 15 7:49:08 s kernel: [<ffffffff91929a1d>] dump_stack+0x19/0x1b
Jul 15 7:49:08 s kernel: [<ffffffff913b16d0>] warn_alloc_failed+0x110/0x180
Jul 15 7:49:08 s kernel: [<ffffffff91926574>] __alloc_pages_slowpath+0x677/0x78c
Jul 15 7:49:08 s kernel: [<ffffffff913b5e65>] __alloc_pages_nodemask+0x5d5/0x600
Jul 15 7:49:08 s kernel: [<ffffffff91405368>] alloc_pages_current+0x98/0x110
Jul 15 7:49:08 s kernel: [<ffffffff913aa6e7>] __page_cache_alloc+0x97/0xb0
Jul 15 7:49:08 s kernel: [<ffffffff913ad150>] filemap_fault+0x200/0x4b0
Jul 15 7:49:08 s kernel: [<ffffffffc0454a96>] ext4_filemap_fault+0x36/0x50 [ext4]
Jul 15 7:49:08 s kernel: [<ffffffff913dbced>] __do_fault.isra.61+0x9d/0x150
Jul 15 7:49:08 s kernel: [<ffffffff913e0e75>] handle_pte_fault+0x3c5/0xce0
Jul 15 7:49:08 s kernel: [<ffffffff9122a5e1>] ? __switch_to+0x151/0x580
Jul 15 7:49:08 s kernel: [<ffffffff913e3757>] handle_mm_fault+0x397/0x9a0
Jul 15 7:49:08 s kernel: [<ffffffff91936607>] __do_page_fault+0x197/0x4f0
Jul 15 7:49:08 s kernel: [<ffffffff91936a46>] trace_do_page_fault+0x56/0x150
Jul 15 7:49:08 s kernel: [<ffffffff91935fd2>] do_async_page_fault+0x22/0xf0
Jul 15 7:49:08 s kernel: [<ffffffff919327a8>] async_page_fault+0x28/0x30
Jul 15 7:49:08 s kernel: Mem-Info:
Jul 15 7:49:08 s kernel: active_anon:1695108 inactive_anon:107340 isolated_anon:0#012 active_file:279 inactive_file:502 isolated_file:50#012 unevictable:43 dirty:0 writeback:0 wbtmp:0 unstable:0#012 slab_reclaimable:45310 slab_unreclaimable:31380#012 mapped:58098 shmem:189861 pagetables:40560 bounce:0#012 free:48871 free_pcp:0 free_cma:0
Jul 15 7:49:08 s kernel: Node 0 DMA free:15908kB min:316kB low:392kB high:472kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15992kB managed:15908kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
Jul 15 7:49:08 s kernel: lowmem_reserve[]: 0 2830 7805 7805
Jul 15 7:49:08 s kernel: Node 0 DMA32 free:77824kB min:57972kB low:72464kB high:86956kB active_anon:2461272kB inactive_anon:162472kB active_file:144kB inactive_file:476kB unevictable:56kB isolated(anon):0kB isolated(file):0kB present:3129200kB managed:2898768kB mlocked:56kB dirty:0kB writeback:0kB mapped:101708kB shmem:267272kB slab_reclaimable:78496kB slab_unreclaimable:39020kB kernel_stack:3312kB pagetables:54376kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
Jul 15 7:49:08 s kernel: lowmem_reserve[]: 0 0 4974 4974
Jul 15 7:49:08 s kernel: Node 0 Normal free:101752kB min:101812kB low:127264kB high:152716kB active_anon:4319160kB inactive_anon:266888kB active_file:972kB inactive_file:1532kB unevictable:116kB isolated(anon):0kB isolated(file):200kB present:5242880kB managed:5094136kB mlocked:116kB dirty:0kB writeback:0kB mapped:130684kB shmem:492172kB slab_reclaimable:102744kB slab_unreclaimable:86500kB kernel_stack:12512kB pagetables:107864kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
Jul 15 7:49:08 s kernel: Node 0 DMA32: 5814*4kB (UEM) 5368*8kB (UEM) 728*16kB (UEM) 6*32kB (U) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 78040kB
Jul 15 7:49:08 s kernel: Node 0 Normal: 2362*4kB (UEM) 7895*8kB (UEM) 1383*16kB (UEM) 211*32kB (UEM) 8*64kB (UM) 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 102000kB
Jul 15 7:49:08 s kernel: 190824 total pagecache pages
Jul 15 7:49:08 s kernel: lsphp invoked oom-killer: gfp_mask=0x201da, order=0, oom_score_adj=0
Jul 15 7:49:08 s kernel: lsphp cpuset=lve1939 mems_allowed=0
Jul 15 7:49:08 s kernel: CPU: 2 PID: 283392 Comm: lsphp ve: 0 Kdump: loaded Tainted: G           OE  ------------   3.10.0-962.3.2.lve1.5.28.el7.x86_64 #1 61.16
Jul 15 7:49:08 s kernel: [<ffffffff919259bf>] dump_header+0x90/0x229
Jul 15 7:49:08 s kernel: [<ffffffff9126b17e>] ? kvm_clock_get_cycles+0x1e/0x20
Jul 15 7:49:08 s kernel: [<ffffffff913af228>] oom_kill_process+0x5e8/0x640
Jul 15 7:49:08 s kernel: [<ffffffff913d7d4e>] ? get_task_oom_score_adj+0xee/0x100
Jul 15 7:49:08 s kernel: [<ffffffff913af671>] out_of_memory+0x391/0x4e0
Jul 15 7:49:08 s kernel: [<ffffffff919264db>] __alloc_pages_slowpath+0x5de/0x78c
Jul 15 7:49:08 s kernel: [<ffffffff91235eae>] ? set_cpuid_faulting+0x1e/0x30
Jul 15 7:49:08 s kernel: active_anon:1695381 inactive_anon:107323 isolated_anon:0#012 active_file:72 inactive_file:100 isolated_file:77#012 unevictable:43 dirty:0 writeback:0 wbtmp:0 unstable:0#012 slab_reclaimable:45310 slab_unreclaimable:31397#012 mapped:57909 shmem:189861 pagetables:40459 bounce:0#012 free:49129 free_pcp:64 free_cma:0
Jul 15 7:49:08 s kernel: Node 0 DMA32 free:78264kB min:57972kB low:72464kB high:86956kB active_anon:2461448kB inactive_anon:162404kB active_file:60kB inactive_file:0kB unevictable:56kB isolated(anon):0kB isolated(file):0kB present:3129200kB managed:2898768kB mlocked:56kB dirty:0kB writeback:0kB mapped:101460kB shmem:267272kB slab_reclaimable:78496kB slab_unreclaimable:39028kB kernel_stack:3296kB pagetables:54328kB unstable:0kB bounce:0kB free_pcp:24kB local_pcp:4kB free_cma:0kB writeback_tmp:0kB pages_scanned:438 all_unreclaimable? yes
Jul 15 7:49:08 s kernel: Node 0 Normal free:102344kB min:101812kB low:127264kB high:152716kB active_anon:4320076kB inactive_anon:266888kB active_file:228kB inactive_file:476kB unevictable:116kB isolated(anon):0kB isolated(file):316kB present:5242880kB managed:5094136kB mlocked:116kB dirty:0kB writeback:0kB mapped:130176kB shmem:492172kB slab_reclaimable:102744kB slab_unreclaimable:86560kB kernel_stack:12512kB pagetables:107508kB unstable:0kB bounce:0kB free_pcp:232kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:1315 all_unreclaimable? yes
Jul 15 7:49:08 s kernel: Node 0 DMA32: 5926*4kB (UEM) 5375*8kB (UEM) 730*16kB (UEM) 6*32kB (U) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 78576kB
Jul 15 7:49:08 s kernel: Node 0 Normal: 2363*4kB (UEM) 7899*8kB (UEM) 1383*16kB (UEM) 210*32kB (UEM) 8*64kB (UM) 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 102004kB
Jul 15 7:49:08 s kernel: 190262 total pagecache pages
Jul 15 7:49:08 s kernel: Killed process 283160 (lsphp) in VE "0" total-vm:328292kB, anon-rss:6972kB, file-rss:0kB, shmem-rss:744kB
Jul 15 7:49:08 s kernel: lsphp cpuset=lve1000 mems_allowed=0
Jul 15 7:49:08 s kernel: CPU: 2 PID: 280986 Comm: lsphp ve: 0 Kdump: loaded Tainted: G           OE  ------------   3.10.0-962.3.2.lve1.5.28.el7.x86_64 #1 61.16
Jul 15 7:49:08 s kernel: [<ffffffff91339fb2>] ? from_kgid_munged+0x12/0x20
Jul 15 7:49:08 s kernel: active_anon:1695178 inactive_anon:107323 isolated_anon:0#012 active_file:122 inactive_file:156 isolated_file:77#012 unevictable:43 dirty:0 writeback:0 wbtmp:0 unstable:0#012 slab_reclaimable:45310 slab_unreclaimable:31397#012 mapped:57909 shmem:189861 pagetables:40340 bounce:0#012 free:48906 free_pcp:537 free_cma:0
Jul 15 7:49:08 s kernel: Node 0 DMA32 free:77904kB min:57972kB low:72464kB high:86956kB active_anon:2461152kB inactive_anon:162404kB active_file:60kB inactive_file:188kB unevictable:56kB isolated(anon):0kB isolated(file):0kB present:3129200kB managed:2898768kB mlocked:56kB dirty:0kB writeback:0kB mapped:101460kB shmem:267272kB slab_reclaimable:78496kB slab_unreclaimable:39028kB kernel_stack:3296kB pagetables:54108kB unstable:0kB bounce:0kB free_pcp:1024kB local_pcp:676kB free_cma:0kB writeback_tmp:0kB pages_scanned:377 all_unreclaimable? yes
Yeah that's what caused the server to stop responding. But you want to know how the options.conf could have changed. Well somebody did it. It didn't just happen by itself. So back to my question.
It must have happened on its own.
Before reboot I also changed the apache to litespeed in options.conf and after reboot there was an apache back.
You are still not answering my question so I am done until you do.
I wasn't looking at it.
I know for sure that before the reboot I changed to litespeed, and after the reboot there was an apache again, when it started to build itself.
I think I know how it happened. Litespeed turned into an apache.
It's not human. :)
I forgot to add that after poweroff I changed the RAM from 8 GB to 12 GB.
Look at what I see in the logs after the reboot:
Jul 15 8:24:58 s lswsctrl: [FATAL] license problem, back to Apache!
Jul 15 8:24:59 s systemd: Reloading.
Jul 15 8:24:59 s systemd: Binding to IPv6 address not available since kernel does not support IPv6.
Jul 15 8:24:59 s lswsctrl: 2020-07-15 13:24:59.252511 [NOTICE] Switch back to Apache ...
Jul 15 8:24:59 s lswsctrl: [ERROR] Failed to start litespeed!
Jul 15 8:24:59 s lswsctrl: Detected DirectAdmin Environment
Jul 15 8:24:59 s dbus[944]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service'
Jul 15 8:24:59 s systemd: Starting Time & Date Service...
Jul 15 8:24:59 s dbus[944]: [system] Successfully activated service 'org.freedesktop.timedate1'
Jul 15 8:24:59 s systemd: Started Time & Date Service.
Jul 15 8:25:00 s lswsctrl: Changed #033[1mphp1_mode#033(B#033[m option from #033[1mlsphp#033(B#033[m to #033[1mfastcgi#033(B#033[m
Jul 15 8:25:01 s lswsctrl: Changed #033[1mmod_ruid2#033(B#033[m option from #033[1mno#033(B#033[m to #033[1mno#033(B#033[m
Jul 15 8:25:02 s lswsctrl: 2020-07-15 8:25:02.549598 [NOTICE] Memory size is: 12136828KB.
Jul 15 8:25:02 s lswsctrl: [ERROR] This license cannot be used on server with more than 8GB memory.
Jul 15 8:25:02 s lswsctrl: Please upgrade your license!
Jul 15 8:25:02 s lswsctrl: php1_mode must be set to lsphp when using litespeed WEB server.
Jul 15 8:25:03 s lswsctrl: [FATAL] license problem, back to Apache!
Is it normal for a change in RAM to turn litespeed into apache and lsphp to fastcgi?
I thought it just couldn't handle the memory anymore...
I still don't see where DirectAdmin or Custombuild did anything. I see where Litespeed failed to start because of the license problem. "back to Apache!" is a Litespeed message. What does the custombuild.log say happened?
2020-07-15 8:27:13 : mod_fcgid 2.3.9 installed
2020-07-15 8:28:13 : Apache 2.4.43 installed
2020-07-15 8:28:14 : called: apache
But at what point was it set to apache? It had to be set to apache before it was installed.
So this had nothing to do with DirectAdmin or Custombuild.
