rowebca
Hi.
I am trying to implement some automatic backups and I see an error message in after backups:
I tried to connect to Rouncube but is not working SQL error access.
Now, I tried to reinstall roundcube and I received this:
I tried to drop the database etc, reinstall same result. Squiremail is working corect.
Please help me with this.
Regards,
George B.
RoundCube Backup Error:
Warning: mysqli::__construct(): Unexpected server respose while doing caching_sha2 auth: 109 in /usr/local/directadmin/scripts/backup_roundcube.php on line 121
Warning: mysqli::__construct(): MySQL server has gone away in /usr/local/directadmin/scripts/backup_roundcube.php on line 121
Warning: mysqli::__construct(): (HY000/2006): MySQL server has gone away in /usr/local/directadmin/scripts/backup_roundcube.php on line 121
Failed to connect to MySQL: (2006) MySQL server has gone away
WARNING: Changed defaults (These config options have new default values):
- 'skin'
- 'smtp_port'
- 'smtp_user'
- 'smtp_pass'
- 'jquery_ui_skin_map'
Executing database schema update. (at this points is hanging until is failing, I try to increase the execution time, but same result of failing)
ERROR: SQLSTATE[HY000] [2006] MySQL server has gone away
ERROR: Failed to connect to database
Reloading apache.
Regards,
George B.
