There was an error upgrading PHP7.3 with CB2.0
bibiugly
Vietnam
Currently I get an error when upgrading PHP version 7.3.20> 7.3.21, below is my error log:
ext/intl/breakiterator/.libs/rulebasedbreakiterator_methods.o: In function `zif_rbbi_get_rule_status_vec':
/usr/local/directadmin/custombuild/php-7.3.21/ext/intl/breakiterator/rulebasedbreakiterator_methods.cpp:173: undefined reference to `__cxa_throw_bad_array_new_length'
collect2: error: ld returned 1 exit status
make: *** [sapi/cgi/php-cgi] Error 1
make: *** Waiting for unfinished jobs....
make: *** [sapi/cli/php] Error 1
make: *** [sapi/phpdbg/phpdbg] Error 1
make: *** [sapi/fpm/php-fpm] Error 1
Hope you guys can help me. Many thanks.
Try this from Cmd Line
./build set_fastest
./build clean
./build php
./build rewrite_confs
If that doesn't work
post output of
grep php options.conf
This is my option:
php1_release=5.6
php1_mode=php-fpm
php2_release=7.2
php2_mode=php-fpm
secure_php=no
php_ini=no
php_timezone=Asia/Ho_Chi_Minh
php_ini_type=production
phpmyadmin=yes
phpmyadmin_ver=4
suhosin_php_uploadscan=no
php3_release=7.3
php4_release=7.4
php3_mode=php-fpm
php4_mode=php-fpm
phpmyadmin_public=yes
I have tried yumupdate but it didn't work. I don't dare to run the command "./build php" because there are a lot of websites running on this server. Sorry my english is very bad.
Don't worry.
You can use the "./build php n" command. It will either fix things or throw the same error.
Yum update has nothing to do with php. Use the list of commands that Brent gave you, it gives the most chance of fixing things.
Đừng bao giờ nói chẳng bao giờ
Don't be scared. Make a plan. You have to keep the system updated. So eventually you can get rid of PHP 5.6...;)
My Vietnamese is bad too..
This is my option:
php1_release=5.6
php1_mode=php-fpm
php2_release=7.2
php2_mode=php-fpm
secure_php=no
php_ini=no
phpmyadmin=yes
phpmyadmin_ver=4
php3_release=7.3
php4_release=7.4
php3_mode=php-fpm
php4_mode=php-fpm
Where is the error you posted coming from if you haven't used the ./build php n command yet? You can just update PHP through Custombuild, it's not necessary to compile anything manually.
If this thread is not closed, I am getting the same error when attempting to update 7.4.13 to 7.4.14, with the exception of the last logged error line being
Code: make: *** Waiting for unfinished jobs....
./build clean command removes the ./php*/ files from custombuild, but reinstating the ./build PHP does not update and throws the same error.
Please post more of your error along with your os and version.
Is the system all updated both DA and os?
Additional info, after rebooting and ./build clean command
This is a CloudLinux Centos 6 DirectAdmin server, fully updated. Except PHP 7.4.14
/opt/rh/devtoolset-7/root/usr/libexec/gcc/x86_64-redhat-linux/7/ld: cannot find -lzstd
make: *** [Makefile:294: sapi/cli/php] Error 1
make: *** [Makefile:306: sapi/fpm/php-fpm] Error 1
The installed PHP version is 7.4.13
In file included from /usr/local/directadmin/custombuild/php-7.4.14/sapi/litespeed/lsapi_main.c:53:0
/usr/local/directadmin/custombuild/php-7.4.14/sapi/litespeed/lscriu.c:
In function 'LSCRIU_try_checkpoint':
/usr/local/directadmin/custombuild/php-7.4.14/sapi/litespeed/lscriu.c:501:9: warning: variable 'iRet' set but not used [-Wunused-but-set-variable]
int iRet;
In function 'lsapi_clean_shutdown':
/usr/local/directadmin/custombuild/php-7.4.14/sapi/litespeed/lsapi_main.c:691:9: warning: variable 'sa_rc' set but not used [-Wunused-but-set-variable]
int sa_rc;
In function 'lsapi_module_main':
/usr/local/directadmin/custombuild/php-7.4.14/sapi/litespeed/lsapi_main.c:753:9: warning: variable 'sa_rc' set but not used [-Wunused-but-set-variable]
int sa_rc;
In function 'zif_litespeed_finish_request':
/usr/local/directadmin/custombuild/php-7.4.14/sapi/litespeed/lsapi_main.c:1790:5: warning: implicit declaration of function 'php_header'; did you mean 'php_verror'? [-Wimplicit-function-declaration]
php_header();
php_verror
In file included from /usr/local/directadmin/custombuild/php-7.4.14/sapi/litespeed/lsapi_main.c:53:0:
At top level:
/usr/local/directadmin/custombuild/php-7.4.14/sapi/litespeed/lscriu.c:314:14: warning: 'LSCRIU_Error_File_Name' defined but not used [-Wunused-function]
static char *LSCRIU_Error_File_Name(char *pchFile, int max_len)
/usr/local/directadmin/custombuild/php-7.4.14/sapi/litespeed/lscriu.c:104:12:
warning: 's_criu_debug' defined but not used [-Wunused-variable]
static int s_criu_debug = 0;
Found additional info in the package. These seem innocuous, but the install script stopped shortly afterward.
