update OpenSSL 1.0.2k-fips to openssl 1.1.1
rahman051
Hello
This version is installed on all servers :
OpenSSL 1.0.2k-fips 26 Jan 2017
How to update it to the new version :
Apache HTTP Server version 2.4.43 or newer is required in order to operate a TLS 1.3 web server with OpenSSL 1.1.1.
Is this update correct?
yum -y install openssl openssl-devel perl-core zlib-devel
cd /usr/local/
wget https://www.openssl.org/source/openssl-1.1.1g.tar.gz
tar xzf openssl-1.1.1g.tar.gz
./config --prefix=/usr no-threads shared
make
make install
openssl version
AND :
./build set ssl_configuration intermediate
./build apache
./build php
./build rewrite_confs
After updating, many services still display the previous version, such as :
named -V
linked to OpenSSL version: OpenSSL 1.0.2k-fips 26 Jan 2017
Should the files be linked in a way that all services use the new version ?
Please help to update
don't upgrade using source code... unless you know what are you doing.
you may break your server.
the best way to upgrade is by your package manager
yum/apt
and don't forget to recomple everything with new version of openssl
yum/apt
Thanks for your reply
We have to find the right solution
With yum/apt Unable to update
There is an update only in the Centos 8 version
We want to do it in the previous version " Centos 7"
Help if there is a solution
if you running
yum update openssl\*
and there is no update...you good to go.
you can always upgrade to last version with compile the openssl.
but be careful about that
