recompile php not work
exemaco
Hi, I want to recompile the php but it doesn't work.
configure: WARNING: PHP is going to be linked with an external PCRE, --with-pcre-valgrind has no effect
checking whether to enable the SQLite3 extension... yes
checking bundled sqlite3 library... yes
checking for ZLIB support... yes
checking if the location of ZLIB install directory is defined... no
checking for zlib version >= 1.2.0.4... 1.2.7
checking for gzgets in -lz... yes
checking whether to enable bc style precision math functions... yes
checking for BZip2 support... no
checking whether to enable calendar conversion support... yes
checking whether to enable ctype functions... yes
checking for cURL support... yes
checking for libcurl.pc... using default path
checking for cURL 7.15.5 or greater... configure: error: cURL version 7.15.5 or later is required to compile php with cURL support
*** There was an error while trying to configure php. Check the configure file
[root@server custombuild]#
There is your answer, please update your curl first
./build curl
./build php n
./build curl
./build php n
I have updated it and it keeps giving the same error.
[root@server custombuild]# /usr/local/bin/curl --version
curl 7.71.1 (x86_64-pc-linux-gnu) libcurl/7.71.1 OpenSSL/1.0.2k-fips zlib/1.2.7
[root@server custombuild]# ./build php n
Found /usr/local/directadmin/custombuild/php-7.3.21.tar.gz
Extracting ...
Done.
Configuring php-7.3.21...
patching file ext/mysqlnd/mysqlnd_auth.c
Hunk #6 succeeded at 610 (offset 3 lines).
Hunk #7 succeeded at 660 (offset 3 lines).
Hunk #8 succeeded at 836 (offset 3 lines).
Hunk #9 succeeded at 1103 (offset 3 lines).
patching file ext/mysqlnd/mysqlnd_auth.h
patching file ext/mysqlnd/mysqlnd_connection.c
Hunk #1 succeeded at 671 (offset 5 lines).
patching file ext/mysqlnd/mysqlnd_enum_n_def.h
patching file ext/mysqlnd/mysqlnd_structs.h
patching file ext/mysqlnd/mysqlnd_wireprotocol.c
Hunk #1 succeeded at 2125 (offset 2 lines).
Hunk #2 succeeded at 2272 (offset 2 lines).
Hunk #3 succeeded at 2461 (offset 2 lines).
Hunk #4 succeeded at 2690 (offset 2 lines).
patching file ext/mysqlnd/mysqlnd_wireprotocol.h
Patching MySQLnd to support SHA2 auth is done.
Patching php-fpm to not fail on startup if User quota maxed out on socket chown
patching file sapi/fpm/fpm/fpm_unix.c
Hunk #1 succeeded at 234 (offset -1 lines).
checking for grep that handles long lines and -e... /usr/bin/grep
checking for egrep... /usr/bin/grep -E
checking for a sed that does not truncate output... /usr/bin/sed
checking build system type... x86_64-pc-linux-gnu
checking host system type... x86_64-pc-linux-gnu
checking target system type... x86_64-pc-linux-gnu
checking for cc... cc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether cc accepts -g... yes
checking for cc option to accept ISO C89... none needed
checking how to run the C preprocessor... cc -E
checking for icc... no
checking for suncc... no
checking whether cc understands -c and -o together... yes
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking minix/config.h usability... no
checking minix/config.h presence... no
checking for minix/config.h... no
checking whether it is safe to define __EXTENSIONS__... yes
checking whether ln -s works... yes
checking for system library directory... lib
checking whether to enable runpaths... yes
checking if compiler supports -R... no
checking if compiler supports -Wl,-rpath,... yes
checking for gawk... gawk
checking for bison... bison -y
checking for bison version... 3.0 (ok)
checking for re2c... no
configure: WARNING: You will need re2c 0.13.4 or later if you want to regenerate PHP parsers.
checking whether to enable computed goto gcc extension with re2c... no
checking whether C compiler accepts -fvisibility=hidden... yes
checking whether to force non-PIC code in shared modules... no
checking whether /dev/urandom exists... yes
checking whether /dev/arandom exists... no
checking for global register variables support... yes
checking whether atof() accepts NAN... no
checking whether atof() accepts INF... no
checking whether HUGE_VAL == INF... yes
checking whether HUGE_VAL + -HUGEVAL == NAN... no
checking whether __cpuid_count is available... yes
checking for pthreads_cflags... -pthread
checking for pthreads_lib... pthread
Configuring SAPI modules
checking for Apache 2.0 handler-module support via DSO through APXS... no
checking for setproctitle... no
checking sys/pstat.h usability... no
checking sys/pstat.h presence... no
checking for sys/pstat.h... no
checking for PS_STRINGS... no
checking for CLI build... yes
checking for embedded SAPI library support... shared
checking for FPM build... yes
checking for setenv... yes
checking for clearenv... yes
checking for setproctitle... (cached) no
checking for setproctitle_fast... no
checking for library containing socket... none required
checking for library containing inet_addr... none required
checking errno.h usability... yes
checking errno.h presence... yes
checking for errno.h... yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking stdio.h usability... yes
checking stdio.h presence... yes
checking for stdio.h... yes
checking for stdlib.h... (cached) yes
checking for unistd.h... (cached) yes
checking sys/uio.h usability... yes
checking sys/uio.h presence... yes
checking for sys/uio.h... yes
checking sys/select.h usability... yes
checking sys/select.h presence... yes
checking for sys/select.h... yes
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking arpa/inet.h usability... yes
checking arpa/inet.h presence... yes
checking for arpa/inet.h... yes
checking netinet/in.h usability... yes
checking netinet/in.h presence... yes
checking for netinet/in.h... yes
checking sysexits.h usability... yes
checking sysexits.h presence... yes
checking for sysexits.h... yes
checking for prctl... yes
checking for clock_gettime... yes
checking for ptrace... yes
checking whether ptrace works... yes
checking for proc mem file... mem
checking if gcc supports __sync_bool_compare_and_swap... yes
checking for TCP_INFO... yes
checking for sysconf... yes
checking for times... yes
checking for kqueue... no
checking for port framework... no
checking for /dev/poll... no
checking for epoll... yes
checking for poll... yes
checking for select... yes
checking for apparmor... no
checking for pkg-config... /opt/mono-1.1.12.1/bin/pkg-config
checking for sd_notify in -lsystemd-daemon... yes
checking systemd/sd-daemon.h usability... yes
checking systemd/sd-daemon.h presence... yes
checking for systemd/sd-daemon.h... yes
checking for LiteSpeed support... yes
checking for phpdbg support... yes
checking for phpdbg web SAPI support... no
checking for phpdbg debug build... no
checking for phpdbg readline support... no
checking whether termios.h defines TIOCGWINSZ... no
checking whether sys/ioctl.h defines TIOCGWINSZ... yes
checking for phpdbg and readline integration... disabled
checking for CGI build... yes
checking for socklen_t in sys/socket.h... yes
checking for sun_len in sys/un.h... no
checking whether cross-process locking is required by accept()... no
checking for chosen SAPI module... embed
checking for executable SAPI binaries...  cli fpm litespeed phpdbg cgi
Running system checks
checking for sendmail... /usr/sbin/sendmail
checking whether system uses EBCDIC... no
checking whether byte ordering is bigendian... no
checking whether writing to stdout works... This is the test message -- yes
checking for socket... yes
checking for socketpair... yes
checking for htonl... yes
checking for gethostname... yes
checking for gethostbyaddr... yes
checking for yp_get_default_domain... no
checking for __yp_get_default_domain... no
checking for yp_get_default_domain in -lnsl... yes
checking for dlopen... no
checking for __dlopen... no
checking for dlopen in -ldl... yes
checking for sin in -lm... yes
checking for inet_aton... yes
checking for ANSI C header files... (cached) yes
checking for dirent.h that defines DIR... yes
checking for library containing opendir... none required
checking for inttypes.h... (cached) yes
checking for stdint.h... (cached) yes
checking for dirent.h... yes
checking for ApplicationServices/ApplicationServices.h... no
checking for sys/param.h... yes
checking for sys/types.h... (cached) yes
checking for sys/time.h... (cached) yes
checking for netinet/in.h... (cached) yes
checking for alloca.h... yes
checking for arpa/inet.h... (cached) yes
checking for arpa/nameser.h... yes
checking for assert.h... yes
checking for crypt.h... yes
checking for dns.h... no
checking for fcntl.h... (cached) yes
checking for grp.h... yes
checking for ieeefp.h... no
checking for langinfo.h... yes
checking for limits.h... yes
checking for locale.h... yes
checking for monetary.h... yes
checking for netdb.h... yes
checking for poll.h... yes
checking for pwd.h... yes
checking for resolv.h... yes
checking for signal.h... yes
checking for stdarg.h... yes
checking for string.h... (cached) yes
checking for syslog.h... yes
checking for sysexits.h... (cached) yes
checking for sys/ioctl.h... yes
checking for sys/file.h... yes
checking for sys/mman.h... yes
checking for sys/mount.h... yes
checking for sys/poll.h... yes
checking for sys/resource.h... yes
checking for sys/select.h... (cached) yes
checking for sys/socket.h... (cached) yes
checking for sys/stat.h... (cached) yes
checking for sys/statfs.h... yes
checking for sys/statvfs.h... yes
checking for sys/vfs.h... yes
checking for sys/sysexits.h... no
checking for sys/varargs.h... no
checking for sys/wait.h... yes
checking for sys/loadavg.h... no
checking for termios.h... yes
checking for unix.h... no
checking for utime.h... yes
checking for sys/utsname.h... yes
checking for sys/ipc.h... yes
checking for dlfcn.h... yes
checking for assert.h... (cached) yes
checking for tmmintrin.h... no
checking for nmmintrin.h... no
checking for immintrin.h... yes
checking for fopencookie... yes
checking for broken getcwd... no
checking for broken libc stdio... yes
checking for broken gcc optimize-strlen... no
checking whether struct tm is in sys/time.h or time.h... time.h
checking for struct tm.tm_zone... yes
checking for missing declarations of reentrant functions... done
checking for fclose declaration... ok
checking for tm_gmtoff in struct tm... yes
checking for struct flock... yes
checking for socklen_t... yes
checking size of size_t... 8
checking size of long long... 8
checking size of long long int... 8
checking size of long... 8
checking size of int... 4
checking size of intmax_t... 8
checking size of ssize_t... 8
checking size of ptrdiff_t... 8
checking size of short... 2
checking size of int... (cached) 4
checking size of long... (cached) 8
checking size of long long... (cached) 8
checking for int8... no
checking for int16... no
checking for int32... no
checking for int64... no
checking for int8_t... yes
checking for int16_t... yes
checking for int32_t... yes
checking for int64_t... yes
checking for uint8... no
checking for uint16... no
checking for uint32... no
checking for uint64... no
checking for uint8_t... yes
checking for uint16_t... yes
checking for uint32_t... yes
checking for uint64_t... yes
checking for u_int8_t... yes
checking for u_int16_t... yes
checking for u_int32_t... yes
checking for u_int64_t... yes
checking for __builtin_expect... yes
checking for __builtin_clz... yes
checking for __builtin_ctzl... yes
checking for __builtin_ctzll... yes
checking for __builtin_smull_overflow... no
checking for __builtin_smulll_overflow... no
checking for __builtin_saddl_overflow... no
checking for __builtin_saddll_overflow... no
checking for __builtin_ssubl_overflow... no
checking for __builtin_ssubll_overflow... no
checking for __builtin_cpu_init... yes
checking for __builtin_cpu_supports... yes
checking for ssse3 instructions supports... yes
checking for sse4.2 instructions supports... yes
checking for avx instructions supports... yes
checking for avx2 instructions supports... no
checking whether __SSE4_2__ is defined... no
checking for struct stat.st_blksize... yes
checking for struct stat.st_rdev... yes
checking for struct stat.st_blocks... yes
checking for size_t... yes
checking for uid_t in sys/types.h... yes
checking for struct sockaddr_storage... yes
checking for field sa_len in struct sockaddr... no
checking for __attribute__((ifunc))... yes
checking for __attribute__((target))... yes
checking for IPv6 support... yes
checking for vprintf... yes
checking for _doprnt... no
checking for alphasort... yes
checking for asctime_r... yes
checking for chroot... yes
checking for ctime_r... yes
checking for cuserid... yes
checking for crypt... no
checking for explicit_memset... no
checking for flock... yes
checking for ftok... yes
checking for funopen... no
checking for gai_strerror... yes
checking for gcvt... yes
checking for getloadavg... yes
checking for getlogin... yes
checking for getprotobyname... yes
checking for getprotobynumber... yes
checking for getservbyname... yes
checking for getservbyport... yes
checking for gethostname... (cached) yes
checking for getrusage... yes
checking for gettimeofday... yes
checking for gmtime_r... yes
checking for getpwnam_r... yes
checking for getgrnam_r... yes
checking for getpwuid_r... yes
checking for grantpt... yes
checking for inet_ntoa... yes
checking for inet_ntop... yes
checking for inet_pton... yes
checking for isascii... yes
checking for link... yes
checking for localtime_r... yes
checking for lockf... yes
checking for lchown... yes
checking for lrand48... yes
checking for memcpy... yes
checking for memmove... yes
checking for mkstemp... yes
checking for mmap... yes
checking for nl_langinfo... yes
checking for perror... yes
checking for ptsname... yes
checking for putenv... yes
checking for realpath... yes
checking for random... yes
checking for rand_r... yes
checking for scandir... yes
checking for setitimer... yes
checking for setlocale... yes
checking for localeconv... yes
checking for setenv... (cached) yes
checking for setpgid... yes
checking for setsockopt... yes
checking for setvbuf... yes
checking for shutdown... yes
checking for sin... yes
checking for snprintf... yes
checking for srand48... yes
checking for srandom... yes
checking for statfs... yes
checking for statvfs... yes
checking for std_syslog... no
checking for strcasecmp... yes
checking for strcoll... yes
checking for strdup... yes
checking for strerror... yes
checking for strftime... yes
checking for strnlen... yes
checking for strptime... yes
checking for strstr... yes
checking for strtok_r... yes
checking for symlink... yes
checking for tempnam... yes
checking for tzset... yes
checking for unlockpt... yes
checking for unsetenv... yes
checking for usleep... yes
checking for utime... yes
checking for vsnprintf... yes
checking for vasprintf... yes
checking for asprintf... yes
checking for nanosleep... yes
checking for nanosleep in -lrt... yes
checking for getaddrinfo... yes
checking for __sync_fetch_and_add... yes
checking for strlcat... no
checking for strlcpy... no
checking for explicit_bzero... no
checking for getopt... yes
checking for utime.h... (cached) yes
checking whether utime accepts a null argument... yes
checking for working alloca.h... yes
checking for alloca... yes
checking for declared timezone... yes
checking for type of reentrant time-related functions... POSIX
checking for readdir_r... yes
checking for type of readdir_r... POSIX
checking for in_addr_t... yes
checking for crypt_r... no
checking for asm goto... yes
checking whether compiler supports VLA... yes
checking whether to enable valgrind support... yes
checking for valgrind header... not found
General settings
checking whether to include gcov symbols... no
checking whether to include debugging symbols... no
checking layout of installed files... PHP
checking path to configuration file... DEFAULT
checking where to scan for configuration files... /usr/local/php73/lib/php.conf.d
checking whether to enable PHP's own SIGCHLD handler... no
checking whether to explicitly link against libgcc... no
checking whether to enable short tags by default... yes
checking whether to enable dmalloc... no
checking whether to enable IPv6 support... yes
checking whether to enable DTrace support... no
checking how big to make fd sets... using system default
Configuring extensions
checking for strings.h... (cached) yes
checking io.h usability... no
checking io.h presence... no
checking for io.h... no
checking for strtoll... yes
checking for atoll... yes
checking whether to enable LIBXML support... yes
checking libxml2 install dir... /usr/local/lib
checking for xml2-config path... /usr/local/bin/xml2-config
checking whether libxml build works... yes
checking for OpenSSL support... yes
checking for Kerberos support... yes
checking whether to use system default cipher list instead of hardcoded value... no
checking for krb5-config... /usr/bin/krb5-config
checking for RAND_egd... no
checking for OpenSSL version... >= 1.0.1
checking for CRYPTO_free in -lcrypto... yes
checking for SSL_CTX_set_ssl_version in -lssl... yes
checking for PCRE2 10.30 or greater... 10.35
checking for JIT support in PCRE2... yes
Extracting ...
Done.
General settings
