DirectAdmin 1.61.4 RC1
DirectAdmin Support
Administrator
Staff member
We're pleased to announce the release candidate of DirectAdmin 1.61.4.
Version: 1.61.4 RC2
Updated: Sept 11, 2020
All changes can be found here:
https://directadmin.com/versions.php?version=1.614000
The most notable changes are below:
Features:
Bugfixes:
To try this release candidate now, grab the pre-release binaries with this guide:
https://help.directadmin.com/item.php?id=408
Should you find any issues, please reply here to avoid duplicate tickets.
I have question
Per-Domain php settings via GUI
this future can disabled via GUI when I don't want this future ? from User Package or Reseller Package ( Globals for user package in that reseller )
or disabled by add custom file to
" /usr/local/directadmin/data/templates/custom/php_settings.json " with empty json like this ?
I have question
I'd suggest using never_commands list for this (directadmin.conf) to disable it globally, alternatively you can just use commands.deny for it: https://www.directadmin.com/features.php?id=1171
Zstd has a much better (de)compression ratio and speed when using a dictionary. The disadvantage is that you always need to carry around the dictionary otherwise you can't decompress the file. The dictionary file could be generated from a set of files available in the most used CMS'es (WordPress, Joomla) and used in/spread by DirectAdmin so everyone is using the same dictionary but the archive can't be opened outside the DirectAdmin backup/restore system.
Any idea how we can solve the disadvantage? I don't know how large a dictionary file is, however you can't include it in the archive (nice chicken and egg problem haha)...
Hello. The new FileManager v2 gives an error when loading:
Oops... something went wrong!
Problems loading the skin appeared for 3rd time in a row. Please contact tech support for troubleshooting.
If the problem does not resolve after refresh, you may reset the skin to enhanced.
Compile Date Sep 6 2020, 12:06:41
Skin Evolution.
Skin Evolution.
It's first time we get this reported. Would it be possible to get access to your host (if latest pre-release does not solve it)? Any errors in browser console?
Before the last release there was a white screen, now this error. What is the best way to transfer access to you?
SyntaxError: invalid regexp group - errors in browser console
Just send it to me in pm, user-level access is enough. Also name the browser you’ve used.
is there a way to test the pre-release out, and after the pre-release go to the stable version again?
Filemanager has a bug, Upload does not work on pre-release.
Also just a suggestion.
  • Don't hide the Upload Button under "New"
  • Reduce icon sizes
  • On first load, the side menu is covering almost half of the page. This should not be the case
  • Reduce icon sizes
What’s the browser? Did you just drag and drop files from your desktop? Any errors in browser console?
I'm using google chrome. I did not use drag and drop. I clicked directly on the uploader and selected the file directly.
This is from the only error i'm getting on console.
[Intervention] Slow network is detected. See https://www.chromestatus.com/feature/5636954674692096 for more details. Fallback font will be used while loading: https://server14.domain.com:2222/assets/fm/fonts/KFOmCnqEu92Fr1Mu4mxM.49ae34d4.woff
:2222/CMD_FILE_MANAGER?json=yes:1 Failed to load resource: the server responded with a status of 500 (Internal Server Error)
There is an error in request to CMD_FILE_MANAGER?json=yes, may you copy-paste (you can PM it to me) JSON from the network tab?
We suspect it's existing file-check issue.
I have sent you account credentials, you can easily debug from your end
