Original post:
forum.directadmin.com
Updated from a week with Directadmin. I have kept a lot of the old verbiage and expanded some of it.
A year with DirectAdmin and my thoughts. I have almost discovered everything I think...I am kidding. I am not that smart just a regular guy like you. DirectAdmin at its core is still a great piece of software. These of course are MHO. They are also generalities.
First some general thoughts. This is still true if you take out cPanel and Plesk. DirectAdmin is still the number one choice. Which is evident by the mass influx of cPanel refugees. They just keep coming. This means more sales, more clients, more support requests, and more opinions…. A friend used to say “it’s just a bunch of work.” One other panel has similar features and they have been bought now and are updating the software. So this could be competition. There are some Open-source Panels but frankly just are not viable to me, still not a year later. So in case of the last year did not say it loud enough, DirectAdmin it’s you OR Venture capitalists. For most its a no-brainer. This places the company still in a pivotal spot. I think they are still trying to pivot.
Strengths:
Rock-solid stable. I have had not one issue over the entire year due to a DA update. I even have done automatic updates every day all year. That just made some people cringe. I am here to tell you I did it and it works. Now keep in mind I don’t run old EOL PHP or some crazy custom setup. That is asking for trouble. I have run ./build all several times just for fun. All works just fine.
Is not interwoven into the OS. You are not getting something with nonstandard binaries. So no guessing how it will behave. Just go to the man page and see how..still true. A note about binaries I am not against them as long as they are standard OS-based ones.
Simplicity. For example, all the conf are in one place in the GUI File editor. Still true more GUI features added now. The system is very maintainable even in the terminal. I would love to see a Menu driven system for the command line 2 other popular panels have this.
Current: Since its source built. It has the ability to be stable and current at the same time. No waiting for some distro or company to release a non standard binary. This makes the application in question configurable. Want Process control on PHP go add it to compiler options… Still true.
Options. Need a different OS, check. Need a different webserver, check. Need a different spam tool, check. Great options. Still true.
The OS choice is a strength, not a weakness. Lately, some have said it would be better to focus on popular Linux only. Well which popular Linux CentOS, Debian, how about the top Distro on Distrowatch MXlinux https://distrowatch.com/mx
No...you say, its desktop Linux but it is popular. What about windows server it has 30% market share just like Linux 30%. So where is the other 40% its in Unix or not listed as Linux.. Windows is popular. Why not code for windows?
Performance. Since it's giving you source control and compiled on your system and server. Memory usage is low and performance is top. Still true.
Custom settings: You can customize anything and save that so the system will behave how you want it to. Never losing it at all. Still true.
Not for faint of heart: Not a sysadmin? Don’t know what Linux or FreeBSD is? Can’t research on google at the very least? In short, if you are a “Business Person” just opening a web hosting business hire a sysadmin. Can’t afford one. Not for you… move on. Sorry if that’s harsh but sometimes the truth hurts. This is still true.
The new part here is the addition of the personal license. This brings some that are users, not admins. They struggle since most just think it easy to install Directadmin and maintain the server. Some never even read the help files and want someone to just tell them where the Software went wrong...
Forum Users: This one of the biggest assets. The community is so awesome. STILL AWESOME...
Weaknesses:
Backup/Restore system. Ok, a year later and no movement. No improvement. Frankly, it is very strange. I don't understand how an IT company can’t feel compelled to have a great backup and recovery system. Still a big weakness.
It needs to be more complete and have more location options. You need to be able to choose “who, what, when, where, and how”.
Who: All good here.
What: is good.
When: I think cron covers this.
Where: local, ftp, sftp, AWS, BackBlaze, and others. You also need to be able to restore from all locations.
How: Full, incremental, both, and except list. It should include logic based on the type chosen example Incremental > full back up= weekly, monthly , etc.
Restore: should accommodate from all “Where” and all “How”
File manager: I would say lately they have improved this some. It is still fine. You need to show it to your non-tech spouse or friend and say use this. Then write down everything they say… The “Root” location of User is fine but it should default to the opening on the Domains folder. OR “Root” should be Domains folder and allow you to go back to Users. I also agree the function type stuff should just be a bar on the same row as columns and density, not tooltips. Should add options to sort folder or files to top that the users can save.
directadmin.conf: Still not added. I still think we need it. directadmin.conf needs an Admin-only GUI screen. All the choices are not face up and apparent. Not centrally located either. Let me give example: You want dkim, ssl, certain letsenctypt settings. All do able if you “knew” there was a setting. You do find the settings eventually and set it. After a few forum posts and searching https://help.directadmin.com In short I should be able to check a box or add text to the correct area. This way I know I have all the settings set and or added. Without a screen or a well-commented file, I don’t know. I think this is a multi-faceted issue.
Certain features not standard: Still not added. In the every changing landscape that is Information technology. Certain “features” (directadmin.conf) should follow the 80 20 rule. All of these seem to be documented in the https://help.directadmin.com
Here is what I mean.
10 years ago https:// wasn’t the 80% it was 20% now it’s the standard. SSL is still not the automatic default but they are working on it. SSL still should just be built in and work by default. Failing only because DNS was wrong or it just couldn’t issue. The system should just set a letsencrypt cert on the server out of the gate. The 20% should be set ssl=0 and turn it off. This goes back to the directadmin.conf issue.
DKIM this should be in the system by default. Some might say DMARC as well. Just like Spf. This goes back to the directadmin.conf issue. Still not Default
webmail.domain.com should be built by default. This should just exist in the system https://help.directadmin.com/item.php?id=633 by default. Not able to set as default option
DNS: Bind is fine to keep it. You should offer native PowerDNS support as well. Its ability to cluster and be Master and Slave simultaneously would be great. We still need PowerDNS not added.
Server to Server user transfer: If I have 2 DA servers and I need to transfer users to a new server this would be a great MultiServer option. In the Admin Backup and Transfer there should be a button that is “Transfer”. Which guides you through from which server to transfer where. This would also be a great place to keep the GUI for external account transfers like from cPanel, Interworks, Plesk, and others… Still not added and still needed.
Documentation and Forum software: The new documentation site has helped. The old one is still up which is confusing. The documentation has gotten better More work is needed but better. Here is the short of it. The documentation should be clear, concise, and cover every feature and option.
I have a new twist on this. Part of the issue is a lot of the new users don’t read the documentation or search for the answer. They just post a question that was literally 3 posts ago. Also, Directadmin doesn't have enough active moderators to keep post organized and the duplicate posts shutdown. The documentation should be so good I go to the forum as a last resort. I understand the forum is community-driven and the software has been around a long time. Still not there yet.
Forum: A+ this is fixed now we have xenforo as I suggested a year ago. Vbulletin is gone…
They added the feedback site which is great. https://feedback.directadmin.com/ It only allows upvotes which cut down on the +1 no -1 no...+2 bickering. If you want it upvote it otherwise move on. The only problem here is some things with just a few votes got added and some things with lots of votes have yet to be added.
They added a new documentation site which is great. https://docs.directadmin.com/ The old one needs to be taken down.
In general thanks for all the work and added features. Keep at it you doing good.
Again these a just my opinions. Feel free to write your own thread.
I hope you, and everyone you know are well. I like you hope and pray everyday COVID goes away.
Stay Safe, wear a mask and stay inside.
A few weeks in with DirectAdmin and my thoughts
A few weeks in with DirectAdmin and my thoughts. I haven’t discovered everything. DirectAdmin at its core is great piece of software. These of course are MHO. They are also generalities. Note: I am not looking for a debate. I am simply a Client voicing his opinion. I am not mad or angry...
Strengths:
Weaknesses:
Who: All good here.
What: is good.
