How can I login to phpmyadmin as root?
Shira
I want to log in phpmyadmin as root to see a list of all the username_database entries. If I click on phpmyadmin from DA as Admin it doesn't do anything. Thanks
Just use login details from
cat /usr/local/directadmin/conf/my.cnf
Likely your browser (Sarafi?) blocking pop-up? Try clicking once more there :) If that doesn't still work - check the browser settings.
To open it manually, you may just access https://yourdomain.com/phpMyAdmin.
Trying manually says "Access to phpMyAdmin is only allowed from control panel."
Popups are allowed for the DA domain. If I right-click on phpmyadmin>open in new tab it just loads the main DA dashboard again.
Just take any domain on your server and add /phpmyadmin behind it.
example.com/phpmyadmin
If you use the user/password from my.cnf you can log in as da_admin accessing all databases.
You have this on
more info here
  • You can make /phpMyAdmin SSO-only accessible (no user/pass allowed) using:
    ./build set phpmyadmin_public no
    ./build phpmyadmin
    such that any access to /phpMyAdmin manually would throw:
