Enabling DKIM for new domains
Amplificator
How do I set DKIM to be enabled using new domains?
In the file:
/usr/local/directadmin/data/templates/custom/dns_txt.conf
..I have already added:
_dmarc="v=DMARC1; p=none;"
_domainkey="t=y; o=~;"
But I am unsure of how to generate the actual DKIM key automatically.
And have a good look what it says there, so if you want DKIM automatically created for new domains, it has to be:
./directadmin set dkim 1
so not 2.
Does the new method do it automatically for new domains as well?
If you use the 2, it will be present, but the customers need to activate it themselves. If you use 1 it will be added automatically without the need for the customer to do anything.
