Bubblewrap chroot
sparek
I know there's a negativity on these forums any time you mention cPanel - but that's the one control panel I'm familiar with.
With cPanel - it's jailshell creates a fully functioning chroot'd environment in the directory structure /home/virtfs/%user% then it chroots to that directory.
DirectAdmin's Bubblewrap doesn't appear to do that. From the best I can tell, it creates the chroot'd environment in-line with the invocation of /usr/bin/jailshell
Now I realize that cPanel and DirectAdmin aren't the same thing. I'm not trying to ruffle anyone's feathers with this. My first question is, am I right? Or is there a /home/virtfs/%user% equivalent path within the DirectAdmin bubblewrap chroot?
The reason that /home/virtfs/%user% is nice, is because if you are using php-fpm, like I am, then php-fpm has a neat configuration variable that can be set within the user's php-fpm pool file called chroot which can then be set to this jailshell or bubblewrap chroot.
On cPanel - you can set this chroot variable to /home/virtfs/%user% - and then all execution of PHP by that user is chroot'd to it's respective jailshell - meaning that PHP can't read anything outside of the user's chroot'd environment. Effectively it's CageFS for PHP without the CloudLinux license.
There's a small issue with this on cPanel - in that it doesn't fully populate /home/virtfs/%user% unless you login to that user with jailshell. But that's remedied by looping through /var/cpanel/users for a list of users and executing a su -s /usr/local/cpanel/bin/jailshell -c exit %user% for each user.
I simply bring this up because I thought this would be a nice feature for DirectAdmin to have - being able to prevent a user from escaping out of their chroot environment when executing PHP.
If you use litespeed (added in 6 RC) or open litespeed (current) they also have their bublewarp for PHP and CGI for wich DA
LSWS 6.0 RC1
MAJOR NEW FEATURE Bubblewrap isolated CGI/PHP execution environments.
https://www.litespeedtech.com/products/litespeed-web-server/release-log
OLS did that2 months ago
https://openlitespeed.org/release-log/version-1-6-x/
V1.6.15 Stable
2020-08-05
and
DA Version 1.61.4 is out it has
BubbleWrap for LiteSpeed (TEMPLATES)
https://www.directadmin.com/features.php?id=2866
Unfortunately, I'm using Apache and I'm not really ready to make the leap to Litespeed.
Although... this did provide some insights. I thought Bubblewrap was just the name of this system that DirectAdmin developed that was akin to cPanel's jailshell. But in fact, Bubblewrap is a 3rd party developed system that DirectAdmin is just incorporating. I did not realize that.
Why do you think they're able to escape it now? (with the PHP modes supported by bubblewrap at this time - lsphp in OpenLiteSpeed and LiteSpeed, FastCGI and PHP from CLI/Cron)
There's not a facility for incorporating this with php-fpm. Or am I missing something?
FastCGI is not the same as FPM.
You can still <?php print(shell_exec("/etc/yum.conf")); ?> and read /etc/yum.conf (or other files). Of course... this can be stopped by now allowing shell_exec()
You cannot, if you’re in bubblewrap. No support for php-fpm at this time. So, things like that can be done in php-fpm. Php-fpm supports a native chroot though, and it may be integrated in DA sometime in the future.
Yea, the native chroot in php-fpm is what I was referring to.
I suppose the easily solution might be to just create a directory structure for every user (i.e. /opt/phpchroot/%user%) with bind mounts of all of the relevant system directories within each of those directory structures. Then set the chroot php-fpm variable to /opt/phpchroot/%user% for each respective user pool. But figuring out which system directories need to be mounted would be the hard part.
I honestly thought Bubblewrap was something you all invented and that was just the name you used. And I thought maybe you all had a way to translate the Bubblewrap chroot into a directory structure which could then be used by php-fpm. But now I know you're just using the Bubblewrap software developed by Flatpak
It needs no directory structure, as it simply uses linux namespaces. I'm really not a fan of a copy-of-everything + bind mounts :) It was needed when linux namespaces did not exist, but.. CentOS6 times are almost over. Regarding PHP-FPM - I think isolation is definitely coming in the future to it. Please note linux permissions are still in effect, yum.conf is world-readable, but you cannot simply read your webserver log of files of another user (this doesn't mean jailing isn't needed)
I agree. If more people understood proper Linux permission settings and setting permissions to least-needed-level, then that would solve a lot of things.
But sadly a lot of people don't understand least privileges and leave files open that could potentially expose sensitive information. CageFS I suppose provides this with CloudLinux, but there's also a directive setting right there for php-fpm to use, so why waste the money on CloudLinux just for CageFS?
I did find:
With a bit of description:
(I'm really just posting these links to act as a bookmark for myself, so I can find them later)
But as you say, this depends on bind mounts and not namespaces, so may not be directly applicable to your endeavors.
Here something i do not have time to test with php fpm
is bublewarp works in CLI/Cron with lsphp and litesspeed as this is not 100% clear, asking to be sure I understand it correctly :)
OLS 1.7.5, LiteSpeed 6.0 (RC1 already there) and Apache+PHP-FastCGI for now :) (+ CLI/Cron with any mode, of course).
Thank you docs do not says Apache + FCGI , I'll sleep better tonight knowing that I have full alternative of CL if they decide to went crazy with the price :)
First Thank you for more PHP versions that will come in the next versions ...
Is adding bubblewrap to PHP-FPM possible? Because if added that will cover all possible scenarios on the server and will be 100% geared...
