Beherit
- Dec 2, 2019
I'm trying to test PHP 8 but every time the compilation fails on compiling the imagick. With PHP 7.4 imagick works fine. Is there any workaround for this issue or I must wait for new imagick version with PHP 8 support?
creating libtool
appending configuration tag "CXX" to libtool
configure: patching config.h.in
configure: creating ./config.status
config.status: creating config.h
Trying to make imagick-3.4.4 PHP extension...
/bin/sh /usr/local/directadmin/custombuild/imagick-3.4.4/libtool --mode=compile cc -I. -I/usr/local/directadmin/custombuild/imagick-3.4.4 -I/usr/local/directadmin/custombuild/imagick-3.4.4/include -I/usr/local/directadmin/custombuild/imagick-3.4.4/main -I/usr/local/directadmin/custombuild/imagick-3.4.4 -I/usr/local/php80/include/php -I/usr/local/php80/include/php/main -I/usr/local/php80/include/php/TSRM -I/usr/local/php80/include/php/Zend -I/usr/local/php80/include/php/ext -I/usr/local/php80/include/php/ext/date/lib -I/usr/local/include/ImageMagick-7 -DHAVE_CONFIG_H -g -O2 -fopenmp -DMAGICKCORE_HDRI_ENABLE=1 -DMAGICKCORE_QUANTUM_DEPTH=16 -fopenmp -DMAGICKCORE_HDRI_ENABLE=1 -DMAGICKCORE_QUANTUM_DEPTH=16 -I/usr/local/include/ImageMagick-7 -c /usr/local/directadmin/custombuild/imagick-3.4.4/imagick_file.c -o imagick_file.lo
mkdir .libs
cc -I. -I/usr/local/directadmin/custombuild/imagick-3.4.4 -I/usr/local/directadmin/custombuild/imagick-3.4.4/include -I/usr/local/directadmin/custombuild/imagick-3.4.4/main -I/usr/local/directadmin/custombuild/imagick-3.4.4 -I/usr/local/php80/include/php -I/usr/local/php80/include/php/main -I/usr/local/php80/include/php/TSRM -I/usr/local/php80/include/php/Zend -I/usr/local/php80/include/php/ext -I/usr/local/php80/include/php/ext/date/lib -I/usr/local/include/ImageMagick-7 -DHAVE_CONFIG_H -g -O2 -fopenmp -DMAGICKCORE_HDRI_ENABLE=1 -DMAGICKCORE_QUANTUM_DEPTH=16 -fopenmp -DMAGICKCORE_HDRI_ENABLE=1 -DMAGICKCORE_QUANTUM_DEPTH=16 -I/usr/local/include/ImageMagick-7 -c /usr/local/directadmin/custombuild/imagick-3.4.4/imagick_file.c -fPIC -DPIC -o .libs/imagick_file.o
In file included from /usr/local/directadmin/custombuild/imagick-3.4.4/imagick_file.c:22:
/usr/local/directadmin/custombuild/imagick-3.4.4/php_imagick_file.h:61:108: error: expected ';', ',' or ')' before 'TSRMLS_DC'
zend_bool php_imagick_file_init(struct php_imagick_file_t *file, const char *filename, size_t filename_len TSRMLS_DC);
/usr/local/directadmin/custombuild/imagick-3.4.4/php_imagick_file.h:65:54: error: expected ';', ',' or ')' before 'TSRMLS_DC'
int php_imagick_safe_mode_check(const char *filename TSRMLS_DC);
/usr/local/directadmin/custombuild/imagick-3.4.4/php_imagick_file.h:68:134: error: expected ';', ',' or ')' before 'TSRMLS_DC'
php_imagick_rw_result_t php_imagick_read_file(php_imagick_object *intern, struct php_imagick_file_t *file, ImagickOperationType type TSRMLS_DC);
/usr/local/directadmin/custombuild/imagick-3.4.4/php_imagick_file.h:71:153: error: expected ';', ',' or ')' before 'TSRMLS_DC'
php_imagick_rw_result_t php_imagick_write_file(php_imagick_object *intern, struct php_imagick_file_t *file, ImagickOperationType type, zend_bool adjoin TSRMLS_DC);
/usr/local/directadmin/custombuild/imagick-3.4.4/php_imagick_file.h:74:112: error: expected ';', ',' or ')' before 'TSRMLS_DC'
zend_bool php_imagick_stream_handler(php_imagick_object *intern, php_stream *stream, ImagickOperationType type TSRMLS_DC);
/usr/local/directadmin/custombuild/imagick-3.4.4/imagick_file.c:81:51: error: expected ';', ',' or ')' before 'TSRMLS_DC'
zend_bool php_imagick_is_url(const char *filename TSRMLS_DC)
/usr/local/directadmin/custombuild/imagick-3.4.4/imagick_file.c:91:108: error: expected ';', ',' or ')' before 'TSRMLS_DC'
/usr/local/directadmin/custombuild/imagick-3.4.4/imagick_file.c:160:133: error: expected ';', ',' or ')' before 'TSRMLS_DC'
int php_imagick_read_image_using_imagemagick(php_imagick_object *intern, struct php_imagick_file_t *file, ImagickOperationType type TSRMLS_DC)
/usr/local/directadmin/custombuild/imagick-3.4.4/imagick_file.c:201:133: error: expected ';', ',' or ')' before 'TSRMLS_DC'
int php_imagick_read_image_using_php_streams(php_imagick_object *intern, struct php_imagick_file_t *file, ImagickOperationType type TSRMLS_DC)
/usr/local/directadmin/custombuild/imagick-3.4.4/imagick_file.c:255:54: error: expected ';', ',' or ')' before 'TSRMLS_DC'
/usr/local/directadmin/custombuild/imagick-3.4.4/imagick_file.c:269:134: error: expected ';', ',' or ')' before 'TSRMLS_DC'
/usr/local/directadmin/custombuild/imagick-3.4.4/imagick_file.c:288:153: error: expected ';', ',' or ')' before 'TSRMLS_DC'
/usr/local/directadmin/custombuild/imagick-3.4.4/imagick_file.c:313:112: error: expected ';', ',' or ')' before 'TSRMLS_DC'
make: *** [Makefile:209: imagick_file.lo] Error 1
