ASap
Anyone?
Honestly, I'd just try adding the CAA record for LE and resubmit the request to see what happens. It couldn't hurt.Anyone?
DA support ticket would be the best option there I guess (if you have support included with your license).Anyone?
If I'm using CloudFlare DNS, how can I do that?Honestly, I'd just try adding the CAA record for LE and resubmit the request to see what happens. It couldn't hurt.
With the new licensing model, unfortunately, our license is no longer eligible for creating a new support ticket.DA support ticket would be the best option there I guess (if you have support included with your license).
Thanks for your input, how can I use LEGO on DA?Do you have lego on? I would think you might use Lego for this? Although I don't follow your issue totally. So I could be wrong.
which is built into DA now.DNS Providers :: Let’s Encrypt client and ACME library written in Go.
Important lego is an independent, free, and open-source project, if you value it, consider supporting it! ❤️ This project is not owned by a company. I’m not an employee of a company. I don’t have gifted domains/accounts from DNS companies. I’ve been maintaining it for about 10 years...go-acme.github.io
So it's true that DirectAdmin old licensee holder now kind of abandoned or unsupported unless they pay the subscription.Did you do do as smtalk suggested and fill out a ticket?
What if I install an updated bind manually?Debian 8 is on extended support. It’s been eol since June 2020
You need to upgrade to Debian version 10DebianReleases - Debian Wiki
wiki.debian.org
So you know you can update support on your licence in the portal?If I'm using CloudFlare DNS, how can I do that?
I know you are frustrated I get it. From what I can tell you are running an unsupported server all around. No really a DA issue.It's been two weeks and still, there's no resolution
Flattery won't get you anywhere.So this forum is useless then?
You don't have DA support.... because you didn't purchase it.Since no one from DA responded
He didn't have to help at all.even though only once a week
Not abandoned. Not working for free. Because we need them to be around. You are choosing not to support them. Are you getting Cpanel and Plesk for free? Far from it.So it's true that DirectAdmin old licensee holder now kind of abandoned or unsupported unless they pay the subscription.
Because you did not re-up you support not DAs fault.license is no longer eligible
You can it is your server... and it unsupported.What if I install an updated bind manually?
