Logging into DirectAdmin causes high server load
Lampard
I just deployed a new server with CentOS 8 and converted it into CloudLinux 8, whenever i login to the admin panel, the server load spikes to 2 from 0.5-1.
Is there any issue with DirectAdmin? Because other nodes does not have this problem at all.
Screenshot has been attached to this thread.
May you check if you have the same problem with pre-release of DirectAdmin?
Server is currently in production, so i think installing pre-release won't be a good idea.
Also, even when using the DirectAdmin Control Panel, it is causing the high load. So not just on the login only.
If that's not a problem for you, I'd suggest waiting for the next release of DA then and checking it then :)
