Brute Force and CSF
Zhenyapan
UA
Directadmin BFM see: User user has 632 failed login attempts: exim2=29 & proftpd1=4 & sshd4=599
But CSF didn't see proftpd and exim.
Centos7 x64.
Can You provide rules that BFM use to parce logs, and can I put them to CSF/LFD?
Centos7 x64.
Did you convert the server to the new integrated method?
No, just installed from archive downloaded from CSF website.
Can you tell more about conversion?
Look's like it works, but it didn't ban if bruteforce non existent login like:
User nologin has 1228 failed login attempts: exim2=1228
User info has 411 failed login attempts: dovecot1=10 & exim1=103 & exim2=246 & sshd4=52
User postmaster has 240 failed login attempts: exim1=64 & exim2=170 & sshd4=6
also proftpd still BFM see attempts, but didn't ban:
while CSF configured to ban after 3 failed attempts. Where I can set BFM to ban EXIM/DOVECOT/PROFTPD/SSH after 3 fsiled attempts?
this too?
maybe look at the section in csf > firewall config
Login Failure Blocking and Alerts
LF_FTPD = Default: 10 [0-100]
LF_FTPD_PERM = Default: 1 [0-604800]
[*]Enable login failure detection of SMTP AUTH connections
LF_SMTPAUTH = Default: 5 [0-100]
LF_SMTPAUTH_PERM = Default: 1 [0-604800]
[*]Enable syntax failure detection of Exim connections
LF_EXIMSYNTAX = Default: 10 [0-100]
LF_EXIMSYNTAX_PERM = Default: 1 [0-604800]
[*]Enable login failure detection of pop3 connections
SECURITY NOTE: This option is affected by the RESTRICT_SYSLOG option. Read
this file about RESTRICT_SYSLOG before enabling this option:
LF_POP3D = Default: 10 [0-100]
LF_POP3D_PERM = Default: 1 [0-604800]
[*]Enable login failure detection of imap connections
LF_IMAPD = Default: 10 [0-100]
LF_IMAPD_PERM = Default: 1 [0-604800]
