lfd on /domain.name/: Excessive resource usage: www-data (617 (Parent PID:413))
mateusz
After latest updates I‘m getting messages from server ([email protected]) every hour 2 messages:
Title: lfd on /domain.name/: Excessive resource usage: www-data (617 (Parent PID:413))
Message:
Time: Mon Nov 2 22:08:03 2020 +0100
Account: www-data
Resource: Process Time
Exceeded: 180300 > 1800 (seconds)
Executable: /usr/sbin/php-fpm7.4
Command Line: php-fpm: pool www
PID: 617 (Parent PID:413)
Killed: No
Thanks for your help in advance,
m
That is a PT message from CSF. It means the Firewall thinks PHP-FPM is using too much time. Also looks like it from a non DA server do you have Directadmin installed on this server?
Thanks, yes I have DirectAdmin (1.61.5).
Any suggestions what to do in this situation?
Thanks,
Mat
Well it could be a great many things or it could be nothing. You need to research why php is using so much process time.
Do you have any entries in your csf process ignore file for fpm?
grep -i fpm /etc/csf/csf.pignore
Thanks, in SSH I’m getting:
pexe:/usr/local/php../sbin/php-fpm..
But file has this:
exe:/bin/dbus-daemon
exe:/sbin/ntpd
exe:/usr/bin/dbus-daemon
exe:/usr/bin/dbus-daemon-1
exe:/usr/bin/lsmd
exe:/usr/lib/polkit-1/polkitd
exe:/usr/libexec/dovecot/anvil
exe:/usr/libexec/dovecot/imap
exe:/usr/libexec/dovecot/imap-login
exe:/usr/libexec/dovecot/pop3
exe:/usr/libexec/dovecot/pop3-login
exe:/usr/libexec/dovecot/stats
exe:/usr/libexec/gam_server
exe:/usr/libexec/hald-addon-acpi
exe:/usr/libexec/hald-addon-keyboard
exe:/usr/local/directadmin/dataskq
exe:/usr/local/directadmin/directadmin
exe:/usr/local/libexec/dovecot/imap
exe:/usr/local/libexec/dovecot/imap-login
exe:/usr/local/libexec/dovecot/pop3
exe:/usr/local/libexec/dovecot/pop3-login
exe:/usr/local/mysql-5.1.54-linux-x86_64/bin/mysqld
exe:/usr/sbin/chronyd
exe:/usr/sbin/exim
exe:/usr/sbin/exim
exe:/usr/sbin/hald
exe:/usr/sbin/httpd
exe:/usr/sbin/mysqld
exe:/usr/sbin/mysqld_safe
exe:/usr/sbin/named
exe:/usr/sbin/nscd
exe:/usr/sbin/ntpd
exe:/usr/sbin/proftpd
exe:/usr/sbin/sshd
exe:/usr/sbin/apache2
exe:/lib/systemd/systemd-timesyncd
exe:/usr/local/bin/freshclam
# Some additional entries that you might want to ignore on DirectAdmin
# servers.
# However, be aware of the security implications under "Process Tracking" in
# the csf readme.txt when using these:
#cmd:/bin/sh /usr/bin/mysqld_safe
#cmd:/bin/sh /usr/bin/mysqld_safe --basedir=/usr
user:mysql
user:diradmin
exe:/usr/libexec/dovecot/lmtp
exe:/usr/libexec/dovecot/managesieve-login
exe:/usr/local/bin/clamd
exe:/usr/share/cagefs-skeleton/usr/selector/lsphp
exe:/usr/selector/lsphp
exe:/usr/local/bin/lsphp
pexe:/usr/local/php../bin/php_uploadscan.sh
pexe:/opt/alt/php../usr/bin/php-cgi
pexe:/opt/alt/php../usr/bin/lsphp
pexe:/usr/local/php../bin/php-cgi..
pexe:/usr/local/php../bin/php..
pexe:/usr/local/php../bin/lsphp..
exe:/usr/sbin/pure-ftpd
exe:/usr/local/bin/pureftpd_uploadscan.sh
exe:/usr/selector/php
exe:/usr/selector/php-cli
exe:/usr/sbin/nginx
exe:/usr/sbin/proxyexec
pexe:/usr/local/safe-bin/fcgid...sh
exe:/usr/sbin/rsyslogd
exe:/usr/sbin/atd
exe:/usr/bin/wget
exe:/bin/gzip
exe:/bin/tar
exe:/usr/bin/rspamd
# MANAGED BY INSTALLATRON
pcmd:/usr/local/bin/php -n -c /usr/local/installatron/etc/php.ini -f (?:/usr/local/installatron/lib/|/var/installatron/cache/|/var/installatron/tasks/)[^/]+
# MANAGED BY INSTALLATRON END
exe:/opt/netdata/usr/libexec/netdata/plugins.d/go.d.plugin
exe:/opt/netdata/bin/srv/netdata
exe:/opt/netdata/usr/libexec/netdata/plugins.d/apps.plugin
exe:/opt/netdata/bin/bash
user:netdata
Something isnt normal...
The path used by DirectAdmin for php already is ignored in your csf config:
For example the path for php 7.4 is:
/usr/local/php74/sbin/php-fpm74
Can you exec this:
ls -al /usr/sbin/php*
ls -al /usr/local/bin/php*
Other thing is the account "www-data", php-fpm pool is executed under the user uid, for example:
webapps 23751 0.2 0.1 317264 22656 ? S Nov05 0:35 php-fpm: pool webapps
So where came from the user www-data or the www pool? is a www-data user in /usr/local/directadmin/data/users/ ?
Have you installed php and php-fpm using yum or apt?
