Once listed, you can restart fpm using one of the listed names, for example:systemctl -l | grep -i fpm
systemctl restart php-fpm73
i use php 7.4 latest version and no workingWhich PHP version are you using? Anyway, you can list the php-fpm services using this command:
[Thu Nov 12 03:02:01.065747 2020] [proxy:error] [pid 27217:tid 140235165558528] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /usr/local/php74/sockets/darius.sock (*) failedThere are a lot of reasons it might fail, but without showing us exactly what you see or log file entries showing what is wrong, it is hard to diagnose. RoseHosting asked an important question (and commands to run) that you didn't answer. Once you show us that you ran his commands and show us the output, we can move to the next step in figuring out which of the hundreds of potential issues your issue might be.
● php-fpm74.service loaded failed failed The PHP FastCGI Process ManagerWhich PHP version are you using? Anyway, you can list the php-fpm services using this command:
listen = /usr/local/php74/sockets/$pool.sockThose are not errors starting php-fpm those are errors from your proxy trying to connect to the unix socket that php was supposed to create. What do you see when you do this command:
ps -eaf|grep php
And what do you see with these commands:
ls -l /usr/local/php74/etc/php-fpm.conf
grep listen /usr/local/php74/etc/php-fpm.conf
problem fixed i buid 7.3 php version after delete old config files and again rebuid back to 7.4 now work fine.OK, what do you see when you do these commands:
systemctl status php-74fpm.service
and
systemctl show php-74fpm.service
