Unable to open file for reading: /etc/exim/domains/example.com/dkim.pem on Centos 7 - err_ssl_protocol_error
isohum
Hi folks,
How can I fix the issue at /var/log/messages?
panel crond: 2020-11-13 21:17:02 1kdgRJ-0008yG-Rv Tainted filename '/etc/exim/domains/example.com/dkim.pem'
panel crond: 2020-11-13 21:17:02 1kdgRJ-0008yG-Rv unable to open file for reading: /etc/exim/domains/example.com/dkim.pem
The actual permissions are:
drwxr-xr-x 2 root root 164 Nov 12 19:45 /etc/exim/domains
drwxrwx--x 2 exim mail 100 Nov 12 19:45 /etc/exim/domains/example.com/
-rw-rw---- 1 exim mail 887 Nov 12 19:45 /etc/exim/domains/example.com/dkim.pem
Everything seems working in my server, but my sites are not loading.
They show an err_ssl_protocol_error, or eror_connection_closed, or ssl handshake failed error 525
I added a link below for you to see the full content of my /etc/exim/exim.conf file
https://drive.google.com/file/d/1HL9XvgMfEcQ7MFSh5b046aKkAoDJYS5R/view?usp=sharing
I am newbie. Thx, you
Hi Richard,
The distro is CentOS Linux release 7.8.2003 (Core) with the latest vesta panel version
I fixed the SSL issue (and my sites are loading now!)
However, I still don't know how to bypass the dkim.pem issue
How can I enable dkim.pem for reading?
I tried chmod 644 /etc/exim/domains/example.com/dkim.pem with no success
I used v-restore-user admin command so I am confusing about how to use chown -R command
Thx
Hello.
In that case you're asking questions on the wrong forum.
You have to go here:
This is a support forum for the Directadmin control panel, not for Vesta CP.
We don't use directory's like /etc/exim/ which made me ask which distro you have.
So we can't help you here, you have to go to the support forum I linked to.
