Custom Docroot Error with capital
aldhy
there is my client setup custom docroot folder for sub domain, he use /domains/Domain (with capital) and my web server was going down.
Is this bugs in web server?
I use nginx_apache
Regards,
service nginx status -l
service httpd status -l ### use " apache2 " when on ubuntu
then post message that you got from thease command.
the error is in one line on httpd.conf user
the user use custom document root /domains/ABCname
now I have removed the domain and the httpd conf running well
You can't use capitals. All lowercase.
Are you sure you can add domains with capitals? Doesn't DA use some strtolower function to fool-proof this? If not,it's a good way for someone to take a whole server down.
I assume he is going in File manager and creating some folder on his own. Like
then yes it lowers it.
The OP said the user is customizing it. I assumed after the fact or in the template files.
Which is what is happening. Sounds like.
no sir, the domain still use lowercase, this is on custom public_html root
