H hamid.yzp Verified User Joined Oct 11, 2020 Messages 21 Nov 22, 2020 #1 Hi All, I need to install composer tecnickcom/tc-lib-barcode ^1.15 how can I install this composer in my server and directadmin?
smtalk Administrator Staff member Joined Aug 22, 2006 Messages 7,758 Location LT, EU Nov 22, 2020 #2 Composer can be installed using: Code: cd /usr/local/directadmin/custombuild ./build update ./build composer
H hamid.yzp Verified User Joined Oct 11, 2020 Messages 21 Nov 23, 2020 #3 thank you for your answer, I did this but it doesn't work!!! I used custombuild panel in directadmin to update composer.
smtalk Administrator Staff member Joined Aug 22, 2006 Messages 7,758 Location LT, EU Nov 23, 2020 #4 Do you mean composer was not installed?
G GR_ Verified User Joined Nov 13, 2008 Messages 26 Nov 25, 2020 #5 smtalk said: Do you mean composer was not installed? Click to expand... Dear smtalk I've the same problem - Composer installed with the instruction above you've provided, but after composer command displays nothing, just no output.
G GR_ Verified User Joined Nov 13, 2008 Messages 26 Nov 25, 2020 #6 Just fixed the Composer issue - set default php 7.4, rebuild the php, rebuild composer and worked fine!
