Unable to start httpd and ./build update
diectsupport
We have unable to restart httpd and ./build update .We have faced time out error. Please check and error log .
-- The start-up result is done.
Nov 20 03:44:01 foam.whitelabelcp.com CROND[15197]: (root) CMD (/usr/local/directadmin/dataskq)
Nov 20 03:44:01 foam.whitelabelcp.com CROND[15201]: (ragnaway) CMD (/usr/local/php73/bin/php -d memory_limit=-1 -d max_execution_time=0 /home/ragnaway/domains/ragnaway.com/
Nov 20 03:44:19 foam.whitelabelcp.com dovecot[23025]: imap-login: Disconnected (no auth attempts in 0 secs): user=<>, rip=174.214.48.195, lip=134.73.55.3, TLS, session=<gO+
Nov 20 03:44:19 foam.whitelabelcp.com dovecot[23025]: imap-login: Disconnected (no auth attempts in 0 secs): user=<>, rip=174.214.48.195, lip=134.73.55.3, TLS, session=<9jO
Nov 20 03:44:49 foam.whitelabelcp.com dovecot[26444]: master: Error: service(imap-login): Initial status notification not received in 30 seconds, killing the process
Nov 20 03:46:28 foam.whitelabelcp.com systemd[1]: systemd-journald.service watchdog timeout (limit 3min)!
Nov 20 03:44:49 foam.whitelabelcp.com dovecot[23025]: imap-login: Fatal: master: service(imap-login): child 15223 killed with signal 9
Nov 20 03:46:44 foam.whitelabelcp.com dovecot[23025]: imap-login: Disconnected: Inactivity during authentication (disconnected while authenticating, waited 180 secs): user=
Nov 20 03:47:11 foam.whitelabelcp.com dovecot[23025]: imap-login: Disconnected (no auth attempts in 1 secs): user=<>, rip=174.214.48.195, lip=134.73.55.3, TLS, session=<40j
Nov 20 03:47:11 foam.whitelabelcp.com dovecot[23025]: imap-login: Disconnected (no auth attempts in 1 secs): user=<>, rip=174.214.48.195, lip=134.73.55.3, TLS, session=<04H
Nov 20 03:47:40 foam.whitelabelcp.com pure-ftpd[32535]: ([email protected]@139.192.175.103) [NOTICE] /home/dowassap/ftpdlinkcam//20170120/20/homevid_20170120_20210
Nov 20 03:48:41 foam.whitelabelcp.com dovecot[23025]: imap-login: Fatal: master: service(imap-login): child 15222 killed with signal 9
[root@foam custombuild]# df -h
Filesystem Size Used Avail Use% Mounted on
devtmpfs 1.9G 0 1.9G 0% /dev
tmpfs 1.9G 0 1.9G 0% /dev/shm
tmpfs 1.9G 184M 1.7G 10% /run
tmpfs 1.9G 0 1.9G 0% /sys/fs/cgroup
/dev/vda1 243G 169G 62G 74% /
tmpfs 379M 0 379M 0% /run/user/990
tmpfs 379M 0 379M 0% /run/user/0
You were asked to check memory usage and instead you checked disk usage?
Can you check vm.overcommit_memory and apache Rlimit settings?
For vm.overcommit_memory:
sysctl -a | grep overcommit
