Well, looking at your answer in post #29 I don't see it mentioned or I'm misunderstanding something. Didn't see it being referenced.What did I miss in my reply?![]()
So if this has to do with certain customizing requests then I did not understand it was this you were talking about in your reply.pagead2.googlesyndication.com/pagead/js/adsbygoogle.js
ThanksFYI: as more customers having license with support contacted us - pre-release has them locally, next release will have polyfill/fonts local as well.
Yes, https://forum.directadmin.com/threa...nts-apis-polyfill-io.62649/page-2#post-323793 is the answer for it. You don't have any requests to that endpoint when you load Evolution skin. Having something in source code, does not mean it's loaded. For example, you may open any email client you use, it'll auto-have selections for gmail, outlook etc. providers, but it does not mean it'll send any queries to them if you don't select themWell, looking at your answer in post #29 I don't see it mentioned or I'm misunderstanding something. Didn't see it being referenced.
I'm talking about this:
The server doesn't send any cookie information or anything else, so, it's not about safety. The only information sent once in a year (because later it's cached and loaded from your browser) is IP address requesting that resource. If you've visited any other page, which loaded the same font - no requests are sent at all. And even that 1 time in a year when the visitor IP is known (as it's the end-customer requesting the resource) won't be there anymore.security is the main problem
Yes it is, while you can't ever trust external that aren't from yourself upfront, and for the time using them, while one mistake somewhere with for example dns security somewhere and the scripts, files could be from a bogus server or site also later, this is real issue, no matter which scripts, fonts, whatever.The server doesn't send any cookie information or anything else, so, it's not about safety. The only information sent once in a year (because later it's cached and loaded from your browser) is IP address requesting that resource. If you've visited any other page, which loaded the same font - no requests are sent at all. And even that 1 time in a year when the visitor IP is known (as it's the end-customer requesting the resource) won't be there anymore.
Plus all browser/client information that's typically exchanged (browser, OS, resolution, etc.) + referrer (full URL), right?The only information sent once in a year (because later it's cached and loaded from your browser) is IP address requesting that resource.
Also if one have strict secure ( or very strict privacy settings) settings, browser, firewall, router , things are not working with that!
./directadmin o
Compiled on 'Debian 10.0 64-bit'
Compile time: Dec 5 2020 at 04:53:04
Timestamp: '1607169135'
Compiled with IPv6
Static binary: yes
commit sha: 7be62cc0
gettext support: yes
gettext path: /usr/local/directadmin/data/lang
| Last Updated | Sat Dec 5 12:53:08 2020 |
Last Restart | Mon Dec 7 00:19:23 2020 |
This has been a problem since they changed their support structure. @bdacus01 opened up a feature request to notify bugs here:I think leaving feedback isn't appropriate for this kind of issue as it would mean a midterm or longterm solution would be fine. It's not a typical feature request but a critical bug that shouldn't be at all in the system.
Glad it will be fixed but at the same time a very worrying situation. You're basically saying you will only "listen" to customers with licenses with support. This would make posting on this forum for customers without a license even more futile and even less bugs will get reported to you guys. Making DirectAdmin a less secure option in the long term.FYI: as more customers having license with support contacted us - pre-release has them locally, next release will have polyfill/fonts local as well.
Yes, and I think a lot of custommers have directadmin trough their (virtual) server provider, and thus without supportGlad it will be fixed but at the same time a very worrying situation. You're basically saying you will only "listen" to customers with licenses with support. This would make posting on this forum for customers without a license even more futile and even less bugs will get reported to you guys. Making DirectAdmin a less secure option in the long term.
Providers likely have support included, so they can forward any requests directly (and then forward the answer back to you)Yes, and I think a lot of custommers have directadmin trough their (virtual) server provider, and thus without support
This will only make it less likely users will report bugs voluntarily though.Providers likely have support included, so they can forward any requests directly (and then forward the answer back to you)
Uh wow ( i do understand you Tristan)This will only make it less likely users will report bugs voluntarily though.
It's untrue and harsh to call this tyranny. It has nothing to do with tyranny.
I have updated my post. @Richard G and others. Would you like me to remove it all together?This is a form of tyranny by an outside government.< Redacted: I take it back I was harsh it didn't need to be said I apologize.
Bug reporting should go directly to the Application development owner or team. Its their application, they developed it, and they are selling it. Its in Directadmin best interest to get Bug reports from anyone. A current support contract has nothing to do with code defects. The issue here for some is what is a bug and what is an enhancement or not a bug. However that is not a customer issue its the product developers issue. The customer should have a free and easy way to report anything they think is a Code defect aka bug.But not reporting BUGS to the right Support,
progress.I just installed latest pre-release binaries again, dated on today. Now Google Fonts is served from your own server but Polyfill still isn't.
80-90% of bug reports are just technical issues they have, then they need to be investigated, and they get support at the end of thisI thought support was for Technical issues.
