Since I've pressed on update CustomBuild it stuck and I can't enter to it again.
* I already tried to restart directadmin but it didn't change anything.
* Also deactivte/activte through the Plugins Manager didn't change anything.
What can I do?
Thanks.
The status log:
server.mizrahit.co:/root # systemctl status directadmin.service
● directadmin.service - DirectAdmin Web Control Panel
Loaded: loaded (/etc/systemd/system/directadmin.service; enabled; vendor preset: disabled)
Active: active (running) since Mon 2020-12-07 20:47:02 UTC; 2min 34s ago
Docs: http://www.directadmin.com
Process: 3491 ExecStart=/usr/local/directadmin/directadmin d (code=exited, status=0/SUCCESS)
Main PID: 3492 (directadmin)
Tasks: 26 (limit: 23737)
Memory: 94.1M
CGroup: /system.slice/directadmin.service
├─3492 /usr/local/directadmin/directadmin d
├─3496 /usr/local/directadmin/directadmin d
├─3498 /usr/local/directadmin/directadmin d
├─3501 /usr/local/directadmin/directadmin d
├─3502 /usr/local/directadmin/directadmin d
├─3686 /usr/local/bin/php -nc/usr/local/directadmin/plugins/custombuild/php.ini /usr/local/directadmin/plugins/custombuild/admin/ajax_count.raw
├─3687 /bin/sh /usr/local/directadmin/custombuild/build versions_ajax
├─4030 wget --no-check-certificate https://waf.comodo.com/doc/comodo_versions.txt -O /usr/local/directadmin/custombuild/versions_cwaf.txt
├─4035 /usr/local/directadmin/directadmin d
├─4038 /usr/local/bin/php -nc/usr/local/directadmin/plugins/custombuild/php.ini /usr/local/directadmin/plugins/custombuild/admin/ajax_count.raw
├─4039 /bin/sh /usr/local/directadmin/custombuild/build versions_ajax
├─4377 wget --no-check-certificate https://waf.comodo.com/doc/comodo_versions.txt -O /usr/local/directadmin/custombuild/versions_cwaf.txt
├─4381 /usr/local/bin/php -n /usr/local/directadmin/plugins/custombuild/admin/index.html
├─4449 /bin/sh /usr/local/directadmin/custombuild/build versions_json
├─4787 wget --no-check-certificate https://waf.comodo.com/doc/comodo_versions.txt -O /usr/local/directadmin/custombuild/versions_cwaf.txt
├─6032 /usr/local/directadmin/directadmin d
├─6034 /usr/local/bin/php -nc/usr/local/directadmin/plugins/custombuild/php.ini /usr/local/directadmin/plugins/custombuild/admin/ajax_count.raw
├─6035 /bin/sh /usr/local/directadmin/custombuild/build versions_ajax
├─6374 wget --no-check-certificate https://waf.comodo.com/doc/comodo_versions.txt -O /usr/local/directadmin/custombuild/versions_cwaf.txt
├─6380 /usr/local/bin/php -n /usr/local/directadmin/plugins/custombuild/admin/index.html
├─6446 /bin/sh /usr/local/directadmin/custombuild/build versions_json
├─6784 wget --no-check-certificate https://waf.comodo.com/doc/comodo_versions.txt -O /usr/local/directadmin/custombuild/versions_cwaf.txt
├─6785 /usr/local/directadmin/directadmin d
├─6792 /usr/local/directadmin/directadmin d
├─6803 /usr/local/directadmin/directadmin d
└─6817 /usr/local/directadmin/directadmin d
Dec 07 20:47:02 server.****.co systemd[1]: Starting DirectAdmin Web Control Panel...
Dec 07 20:47:02 server.****.co systemd[1]: directadmin.service: Can't open PID file /run/directadmin.pid (yet?) after start: No such file or directory
Dec 07 20:47:02 server.****.co systemd[1]: Started DirectAdmin Web Control Panel.
What can I do?
Thanks.
The status log:
Memory: 94.1M
