Don't see login key on reseller
lctiendat
I don't see the reseller login key at the reseller default even though I used the enabled admin permission, can anyone help me
No, I only see login key at user but I can't find login key at reseller, I need login key at reseller to connect to whmcs
that should work, if you go under user level and use the login keys there. should have all the permissions that reseller user has.
