Please help cant update php 7.3 or install new php version
IXPLANET
Hello Anyone can help us?
We have some problem update php 7.3 version or install new version php
An error like this :
  • /opt//rhopt//devtoolset//-optoptrh7////rhrhdevtoolsetroot//-/devtoolsetdevtoolset7usr--//77rootlibexec////rootrootusrgcc////usrusrlibexecx86_64///-libexeclibexecgccredhat///-gccgccx86_64linux//-/x86_64x86_64redhat7---/redhatredhatlinuxld--/:linuxlinux7 ///warning77ld://: ldld libcrypto.so.10::warning, : warningwarning needed::libcrypto.so.10 ,bylibcrypto.so.10libcrypto.so.10 ,,needed/ usrneededneededby/ libbyby// usrlibssl.so///,usrusrlib ////mayliboptliblibssl.so ///,conflictlibssl.sorhlibssl.so ,/, maywith devtoolsetmay may- conflictlibcrypto.so.1.1 7conflict
  • conflict/ with/ rootwith optwith/ libcrypto.so.1.1/ usrlibcrypto.so.1.1
  • rhlibcrypto.so.1.1/
  • libexec/optdevtoolset//opt/-optgcc/rh7//rh//rhx86_64/devtoolsetroot/-devtoolset-/devtoolsetredhat-7usr--7//7linux/rootlibexec//root//root7/usrgcc//usr//usrld/libexecx86_64/:libexec/-libexec /gccredhat/warninggcc/-gcc:/x86_64linux/ x86_64-/x86_64libcrypto.so.10-redhat7-,redhat-/redhat -linuxld-neededlinux/:linux /7 /by7/warning7 /ld://ld: ldusr: libcrypto.so.10:/lib warning, /warning: warninglibssl.so: needed:, libcrypto.so.10 libcrypto.so.10,bylibcrypto.so.10may, , needed/ conflictneeded usrneeded by/ withby libby // libcrypto.so.1.1/usrlibssl.so/
  • usr/,usr//lib /optlib/maylib//libssl.so /rhlibssl.so,conflictlibssl.so/, ,devtoolset maywith -may may7 conflictlibcrypto.so.1.1 /conflict
  • conflictroot with/ /with optwithusr libcrypto.so.1.1/ /libcrypto.so.1.1
  • rhlibcrypto.so.1.1libexec
  • //optdevtoolset/gccopt/-opt//rh7/x86_64rh//rh-/devtoolsetroot/redhatdevtoolset-/devtoolset--7usr-linux7//7//rootlibexec/7root//root//usrgcc/ldusr//usr:/libexecx86_64/ libexec/-libexecwarning/gccredhat/:gcc/-gcc /x86_64linux/libcrypto.so.10x86_64-/x86_64,-redhat7- redhat-/redhatneeded-linuxld- linux/:linuxby/7 / 7/warning7//ld:/usrld: ld/: libcrypto.so.10:lib warning, /warning: warninglibssl.so: needed:, libcrypto.so.10 libcrypto.so.10,bylibcrypto.so.10may, , needed/ conflictneeded usrneeded by/ withby libby // libcrypto.so.1.1/usrlibssl.so/
  • //optdevtoolset/gccopt/-opt//rh7/x86_64rh//rh-/devtoolsetroot/redhatdevtoolset-/devtoolset--7usr-linux7//7//rootlibexec/7root//root//usrgcc/ldusr//usr:/libexecx86_64/ libexec/-libexecwarning/gccredhat/:gcc/-gcc /x86_64linux/libcrypto.so.10x86_64-/x86_64,-redhat7- redhat-/redhatneeded-linuxld- linux/:linuxby/7 / 7/ext7//ld//usrld:opensslld/: /:lib ext. /ext/libsextlibssl.so/openssl//,openssl/openssl.oopenssl /.:/may.libs . libs/undefinedlibsconflict/openssl.o / openssl.o:referenceopenssl.owith: : undefinedto libcrypto.so.1.1undefined undefined
  • referencesymbol /reference referenceopt to' /to EVP_dss1torh symbol@ /symbol @symboldevtoolset 'libcrypto.so.10 -'EVP_dss1''7EVP_dss1@
  • EVP_dss1/@@/@[email protected].10usr@/libcrypto.so.10'/libcrypto.so.10usr'
  • lib64'/
  • libexec/usrlibcrypto.so.10//usr/:usrgcc/lib64 //lib64/errorlib64x86_64/libcrypto.so.10 /-libcrypto.so.10:addinglibcrypto.so.10redhat: :- errorsymbols linuxerror :error/ adding 7adding DSOadding/ symbols ldsymbols:missingsymbols:: : DSOfrom extDSO DSO/ missingcommand opensslmissing missing/ fromline .from
  • fromlibs command /command commandopenssl.o line :line
  • line
  • undefined reference collect2: error: ld returned 1 exit status
  • to symbol 'EVP_dss1@@libcrypto.so.10'
  • /usr/lib64/collect2: error: ld returned 1 exit status
  • libcrypto.so.10:collect2: error: ld returned 1 exit status
  • collect2: error: ld returned 1 exit status
  • error adding symbols: DSO missing from command line
  • make: *** [Makefile:350: sapi/phpdbg/phpdbg] Error 1
  • make: *** Waiting for unfinished jobs....
  • make: *** [Makefile:386: sapi/cgi/php-cgi] Error 1
  • make: *** [Makefile:308: sapi/fpm/php-fpm] Error 1
  • make: *** [Makefile:296: sapi/cli/php] Error 1
  • make: *** [Makefile:336: sapi/litespeed/php] Error 1
I really apretiate if anyone can help us about this problem
how do you rebuild it? by php_expert ?
previous version was installed by custombuild?
Hello sir was try and give same error
I attach screenshoot of error below
try via SSH console run build update then rebuild by php_expert
looks like you have custom libcrypto.so - maybe You have 2 versions of openssl? or custom php config to compile with custom modules?
this borken now,
what's your OS version and, how you compiler second openssl,
/usr/lib*/
/usr/bin/openssl
should be default openssl of your OS
and when you want to custom your openssl should do like this for tutorial
this borken now,
/usr/lib*/
/usr/bin/openssl
Hello sir. Our OS Centos 6.10
Yes i do with that tutorial and everythinh run well few month ago .. and i dont know when i was try update php right now it cant update sir
Btw only php failed to update or new install , for build update curl, apache or openlitespeed its not a problem and run well
Currently your php is use openssl from /usr/lib*
Do you have any custom compiler in " /custombuild/custom/ { your path php } /*" ?
if had it, but still wrong path usage
try symbol link from "/usr/local/lib_http2/lib/libssl..so.1.1" to "/usr/lib/libssl.so"
besure you backup old /usr/lib/libssl.so before changing.
Hello sir in /custombuild/custom/ directory previously we have only ap custom use http2 like martynas post
And strange i see log custombuild plugin before update devtoolset-7 in march 2020 everything run well because we has used at least 4 month without have any trouble update php
But after that we try update php in des 2020 and have error like that.
And we have try to empy custom directory too for testing and an result still same .
But in our other server use custom ap like in this server not have any problem build or install php .
