PHP 8 configure unrecognized options
Erulezz
When installing PHP 8 on CentOS 8.3 with the default configure.php80 I get the following warning when ./build php:
configure: WARNING: unrecognized options: --with-iconv-dir
When installing PHP 7.4 I don't receive that warning. PHP 8 successfully compiles, even with this warning. It is using the system iconv, because I don't have iconv installed with custombuild:
checking for iconv support... yes
checking for iconv... yes
checking if iconv is glibc's... yes
checking if iconv supports errno... yes
checking if iconv supports //IGNORE... no
I can't find anything in the release notes about this configure option being removed / deprecated, but as the warning suggests this line can be removed from the configure.php80 script.
When I tried to install iconv with ./build iconv, and then after ./build php I received this error:
checking if iconv supports errno... no
configure: error: iconv does not support errno
*** There was an error while trying to configure php. Check the configure file
Same thing for me, have found any solutions.
Which directory directory u do the ./build icnonv command?
I got it fixed by;
- Removing libiconv that was installed with CustomBuild
- Remove the --with-iconv-dir line in configure.php80
rm -rf the unpacked php-8.0.0 folder in CB directory and run ./build php again. Now it’s using the iconv that comes with glibc, and no errors/warnings during compiling
I got it fixed by;
How did you remove libiconv ?
also there is no --with-iconv-dir on my configure.php80
./build php
If you run any of the official mirrors.
Updating CustomBuild and recompiling all versions of php is not the solution and also causes the compilation of imagick to fail and breaks other versions of php, now all versions of php not working.
grep: /usr/local/lib/libiconv.la: No such file or directory
/usr/bin/sed: can't read /usr/local/lib/libiconv.la: No such file or directory
libtool: link: `/usr/local/lib/libiconv.la' is not a valid libtool archive
make: *** [imagick.la] Error 1
[02-Jan-2021 03:46:30] NOTICE: PHP message: PHP Warning:  PHP Startup: Unable to load dynamic library 'imagick.so' (tried: /usr/local/php73/lib/php/extensions/no-debug-non-zts-20180731/imagick.so (libiconv.so.2: cannot open shared object file: No such file or directory), /usr/local/php73/lib/php/extensions/no-debug-non-zts-20180731/imagick.so.so (/usr/local/php73/lib/php/extensions/no-debug-non-zts-20180731/imagick.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
Jan 02 03:49:06 php-fpm56[214077]: /usr/local/php56/sbin/php-fpm56: error while loading shared libraries: libiconv.so.2: cannot open shared object file: No such file or directory
Jan 02 03:49:06 systemd[1]: php-fpm56.service: main process exited, code=exited, status=127/n/a
Jan 02 03:49:06 systemd[1]: Failed to start The PHP FastCGI Process Manager.
Jan 02 03:49:06 systemd[1]: Unit php-fpm56.service entered failed state.
Jan 02 03:49:06 systemd[1]: php-fpm56.service failed.
Jan 02 03:50:16 php-fpm71[216368]: /usr/local/php71/sbin/php-fpm71: error while loading shared libraries: libiconv.so.2: cannot open shared object file: No such file or directory
Jan 02 03:50:16 systemd[1]: php-fpm71.service: main process exited, code=exited, status=127/n/a
Jan 02 03:50:16 systemd[1]: Failed to start The PHP FastCGI Process Manager.
Jan 02 03:50:16 systemd[1]: Unit php-fpm71.service entered failed state.
Jan 02 03:50:16 systemd[1]: php-fpm71.service failed.
./build php
I confirm that it's working now. at least for me.
I did update and build successfully this time .
Thank you
Did you run rm commands above? If yes, then ./build all d is recommended. Otherwise it should do this automatically.
./build all d
Making all in clamscan
make[2]: Entering directory `/usr/local/directadmin/custombuild/clamav-0.103.0/clamscan'
  CC       clamscan.o
  CC       manager.o
  CCLD     clamscan
../libclamav/.libs/libclamav.so: undefined reference to `libiconv'
../libclamav/.libs/libclamav.so: undefined reference to `libiconv_close'
../libclamav/.libs/libclamav.so: undefined reference to `libiconv_open'
collect2: error: ld returned 1 exit status
make[2]: *** [clamscan] Error 1
make[2]: Leaving directory `/usr/local/directadmin/custombuild/clamav-0.103.0/clamscan'
make[1]: Leaving directory `/usr/local/directadmin/custombuild/clamav-0.103.0'
make: *** [all] Error 2
:cry:
/bin/sh /usr/local/directadmin/custombuild/php-7.3.26/libtool --silent --preserve-dup-deps --mode=link cc -export-dynamic -I/usr/local/include -g -O2 -fvisibility=hidden -DZEND_SIGNALS -L/usr/local/lib -L/usr/local/imap-2007f/lib -L/usr/local/icu/lib -R /usr/local/lib -R /usr/local/imap-2007f/lib -R /usr/local/icu/lib ext/date/php_date.lo ext/date/lib/astro.lo ext/date/lib/dow.lo ext/date/lib/parse_date.lo ext/date/lib/parse_tz.lo ext/date/lib/timelib.lo ext/date/lib/tm2unixtime.lo ext/date/lib/unixtime2tm.lo ext/date/lib/parse_iso_intervals.lo ext/date/lib/interval.lo ext/libxml/libxml.lo ext/openssl/openssl.lo ext/openssl/xp_ssl.lo ext/pcre/php_pcre.lo ext/sqlite3/sqlite3.lo ext/sqlite3/libsqlite/sqlite3.lo ext/zlib/zlib.lo ext/zlib/zlib_fopen_wrapper.lo ext/zlib/zlib_filter.lo ext/bcmath/bcmath.lo ext/bcmath/libbcmath/src/add.lo ext/bcmath/libbcmath/src/div.lo ext/bcmath/libbcmath/src/init.lo ext/bcmath/libbcmath/src/neg.lo ext/bcmath/libbcmath/src/outofmem.lo ext/bcmath/libbcmath/src/raisemod.lo ext/bcmath/libbcmath/src/sub.lo ext/bcmath/libbcmath/src/compare.lo ext/bcmath/libbcmath/src/divmod.lo ext/bcmath/libbcmath/src/int2num.lo ext/bcmath/libbcmath/src/num2long.lo ext/bcmath/libbcmath/src/output.lo ext/bcmath/libbcmath/src/recmul.lo ext/bcmath/libbcmath/src/sqrt.lo ext/bcmath/libbcmath/src/zero.lo ext/bcmath/libbcmath/src/debug.lo ext/bcmath/libbcmath/src/doaddsub.lo ext/bcmath/libbcmath/src/nearzero.lo ext/bcmath/libbcmath/src/num2str.lo ext/bcmath/libbcmath/src/raise.lo ext/bcmath/libbcmath/src/rmzero.lo ext/bcmath/libbcmath/src/str2num.lo ext/calendar/calendar.lo ext/calendar/dow.lo ext/calendar/french.lo ext/calendar/gregor.lo ext/calendar/jewish.lo ext/calendar/julian.lo ext/calendar/easter.lo ext/calendar/cal_unix.lo ext/ctype/ctype.lo ext/curl/interface.lo ext/curl/multi.lo ext/curl/share.lo ext/curl/curl_file.lo ext/dom/php_dom.lo ext/dom/attr.lo ext/dom/document.lo ext/dom/domerrorhandler.lo ext/dom/domstringlist.lo ext/dom/domexception.lo ext/dom/namelist.lo ext/dom/processinginstruction.lo ext/dom/cdatasection.lo ext/dom/documentfragment.lo ext/dom/domimplementation.lo ext/dom/element.lo ext/dom/node.lo ext/dom/string_extend.lo ext/dom/characterdata.lo ext/dom/documenttype.lo ext/dom/domimplementationlist.lo ext/dom/entity.lo ext/dom/nodelist.lo ext/dom/text.lo ext/dom/comment.lo ext/dom/domconfiguration.lo ext/dom/domimplementationsource.lo ext/dom/entityreference.lo ext/dom/notation.lo ext/dom/xpath.lo ext/dom/dom_iterators.lo ext/dom/typeinfo.lo ext/dom/domerror.lo ext/dom/domlocator.lo ext/dom/namednodemap.lo ext/dom/userdatahandler.lo ext/exif/exif.lo ext/fileinfo/fileinfo.lo ext/fileinfo/libmagic/apprentice.lo ext/fileinfo/libmagic/apptype.lo ext/fileinfo/libmagic/ascmagic.lo ext/fileinfo/libmagic/cdf.lo ext/fileinfo/libmagic/cdf_time.lo ext/fileinfo/libmagic/compress.lo ext/fileinfo/libmagic/encoding.lo ext/fileinfo/libmagic/fsmagic.lo ext/fileinfo/libmagic/funcs.lo ext/fileinfo/libmagic/is_tar.lo ext/fileinfo/libmagic/magic.lo ext/fileinfo/libmagic/print.lo ext/fileinfo/libmagic/readcdf.lo ext/fileinfo/libmagic/softmagic.lo ext/fileinfo/libmagic/der.lo ext/fileinfo/libmagic/buffer.lo ext/filter/filter.lo ext/filter/sanitizing_filters.lo ext/filter/logical_filters.lo ext/filter/callback_filter.lo ext/ftp/php_ftp.lo ext/ftp/ftp.lo ext/gd/gd.lo ext/gd/libgd/gd.lo ext/gd/libgd/gd_gd.lo ext/gd/libgd/gd_gd2.lo ext/gd/libgd/gd_io.lo ext/gd/libgd/gd_io_dp.lo ext/gd/libgd/gd_io_file.lo ext/gd/libgd/gd_ss.lo ext/gd/libgd/gd_io_ss.lo ext/gd/libgd/gd_webp.lo ext/gd/libgd/gd_png.lo ext/gd/libgd/gd_jpeg.lo ext/gd/libgd/gdxpm.lo ext/gd/libgd/gdfontt.lo ext/gd/libgd/gdfonts.lo ext/gd/libgd/gdfontmb.lo ext/gd/libgd/gdfontl.lo ext/gd/libgd/gdfontg.lo ext/gd/libgd/gdtables.lo ext/gd/libgd/gdft.lo ext/gd/libgd/gdcache.lo ext/gd/libgd/gdkanji.lo ext/gd/libgd/wbmp.lo ext/gd/libgd/gd_wbmp.lo ext/gd/libgd/gdhelpers.lo ext/gd/libgd/gd_topal.lo ext/gd/libgd/gd_gif_in.lo ext/gd/libgd/gd_xbm.lo ext/gd/libgd/gd_gif_out.lo ext/gd/libgd/gd_security.lo ext/gd/libgd/gd_filter.lo ext/gd/libgd/gd_pixelate.lo ext/gd/libgd/gd_rotate.lo ext/gd/libgd/gd_color_match.lo ext/gd/libgd/gd_transform.lo ext/gd/libgd/gd_crop.lo ext/gd/libgd/gd_interpolation.lo ext/gd/libgd/gd_matrix.lo ext/gd/libgd/gd_bmp.lo ext/gettext/gettext.lo ext/hash/hash.lo ext/hash/hash_md.lo ext/hash/hash_sha.lo ext/hash/hash_ripemd.lo ext/hash/hash_haval.lo ext/hash/hash_tiger.lo ext/hash/hash_gost.lo ext/hash/hash_snefru.lo ext/hash/hash_whirlpool.lo ext/hash/hash_adler32.lo ext/hash/hash_crc32.lo ext/hash/hash_fnv.lo ext/hash/hash_joaat.lo ext/hash/sha3/generic64lc/KeccakP-1600-opt64.lo ext/hash/sha3/generic64lc/KeccakHash.lo ext/hash/sha3/generic64lc/KeccakSponge.lo ext/hash/hash_sha3.lo ext/iconv/iconv.lo ext/imap/php_imap.lo ext/intl/php_intl.lo ext/intl/intl_error.lo ext/intl/intl_convert.lo ext/intl/collator/collator.lo ext/intl/collator/collator_class.lo ext/intl/collator/collator_sort.lo ext/intl/collator/collator_convert.lo ext/intl/collator/collator_locale.lo ext/intl/collator/collator_compare.lo ext/intl/collator/collator_attr.lo ext/intl/collator/collator_create.lo ext/intl/collator/collator_is_numeric.lo ext/intl/collator/collator_error.lo ext/intl/common/common_error.lo ext/intl/converter/converter.lo ext/intl/formatter/formatter.lo ext/intl/formatter/formatter_main.lo ext/intl/formatter/formatter_class.lo ext/intl/formatter/formatter_attr.lo ext/intl/formatter/formatter_data.lo ext/intl/formatter/formatter_format.lo ext/intl/formatter/formatter_parse.lo ext/intl/normalizer/normalizer.lo ext/intl/normalizer/normalizer_class.lo ext/intl/normalizer/normalizer_normalize.lo ext/intl/locale/locale.lo ext/intl/locale/locale_class.lo ext/intl/locale/locale_methods.lo ext/intl/dateformat/dateformat.lo ext/intl/dateformat/dateformat_class.lo ext/intl/dateformat/dateformat_attr.lo ext/intl/dateformat/dateformat_data.lo ext/intl/dateformat/dateformat_format.lo ext/intl/dateformat/dateformat_parse.lo ext/intl/msgformat/msgformat.lo ext/intl/msgformat/msgformat_attr.lo ext/intl/msgformat/msgformat_class.lo ext/intl/msgformat/msgformat_data.lo ext/intl/msgformat/msgformat_format.lo ext/intl/msgformat/msgformat_parse.lo ext/intl/grapheme/grapheme_string.lo ext/intl/grapheme/grapheme_util.lo ext/intl/resourcebundle/resourcebundle.lo ext/intl/resourcebundle/resourcebundle_class.lo ext/intl/resourcebundle/resourcebundle_iterator.lo ext/intl/transliterator/transliterator.lo ext/intl/transliterator/transliterator_class.lo ext/intl/transliterator/transliterator_methods.lo ext/intl/uchar/uchar.lo ext/intl/idn/idn.lo ext/intl/spoofchecker/spoofchecker_class.lo ext/intl/spoofchecker/spoofchecker.lo ext/intl/spoofchecker/spoofchecker_create.lo ext/intl/spoofchecker/spoofchecker_main.lo ext/intl/intl_convertcpp.lo ext/intl/common/common_enum.lo ext/intl/common/common_date.lo ext/intl/dateformat/dateformat_format_object.lo ext/intl/dateformat/dateformat_create.lo ext/intl/dateformat/dateformat_attrcpp.lo ext/intl/dateformat/dateformat_helpers.lo ext/intl/msgformat/msgformat_helpers.lo ext/intl/timezone/timezone_class.lo ext/intl/timezone/timezone_methods.lo ext/intl/calendar/calendar_class.lo ext/intl/calendar/calendar_methods.lo ext/intl/calendar/gregoriancalendar_methods.lo ext/intl/breakiterator/breakiterator_class.lo ext/intl/breakiterator/breakiterator_iterators.lo ext/intl/breakiterator/breakiterator_methods.lo ext/intl/breakiterator/rulebasedbreakiterator_methods.lo ext/intl/breakiterator/codepointiterator_internal.lo ext/intl/breakiterator/codepointiterator_methods.lo ext/json/json.lo ext/json/json_encoder.lo ext/json/json_parser.lo ext/json/json_scanner.lo ext/mbstring/oniguruma/src/ascii.lo ext/mbstring/oniguruma/src/big5.lo ext/mbstring/oniguruma/src/cp1251.lo ext/mbstring/oniguruma/src/euc_jp.lo ext/mbstring/oniguruma/src/euc_jp_prop.lo ext/mbstring/oniguruma/src/euc_kr.lo ext/mbstring/oniguruma/src/euc_tw.lo ext/mbstring/oniguruma/src/gb18030.lo ext/mbstring/oniguruma/src/iso8859_1.lo ext/mbstring/oniguruma/src/iso8859_10.lo ext/mbstring/oniguruma/src/iso8859_11.lo ext/mbstring/oniguruma/src/iso8859_13.lo ext/mbstring/oniguruma/src/iso8859_14.lo ext/mbstring/oniguruma/src/iso8859_15.lo ext/mbstring/oniguruma/src/iso8859_16.lo ext/mbstring/oniguruma/src/iso8859_2.lo ext/mbstring/oniguruma/src/iso8859_3.lo ext/mbstring/oniguruma/src/iso8859_4.lo ext/mbstring/oniguruma/src/iso8859_5.lo ext/mbstring/oniguruma/src/iso8859_6.lo ext/mbstring/oniguruma/src/iso8859_7.lo ext/mbstring/oniguruma/src/iso8859_8.lo ext/mbstring/oniguruma/src/iso8859_9.lo ext/mbstring/oniguruma/src/koi8.lo ext/mbstring/oniguruma/src/koi8_r.lo ext/mbstring/oniguruma/src/onig_init.lo ext/mbstring/oniguruma/src/regcomp.lo ext/mbstring/oniguruma/src/regenc.lo ext/mbstring/oniguruma/src/regerror.lo ext/mbstring/oniguruma/src/regexec.lo ext/mbstring/oniguruma/src/regext.lo ext/mbstring/oniguruma/src/reggnu.lo ext/mbstring/oniguruma/src/regparse.lo ext/mbstring/oniguruma/src/regposerr.lo ext/mbstring/oniguruma/src/regposix.lo ext/mbstring/oniguruma/src/regsyntax.lo ext/mbstring/oniguruma/src/regtrav.lo ext/mbstring/oniguruma/src/regversion.lo ext/mbstring/oniguruma/src/sjis.lo ext/mbstring/oniguruma/src/sjis_prop.lo ext/mbstring/oniguruma/src/st.lo ext/mbstring/oniguruma/src/unicode.lo ext/mbstring/oniguruma/src/unicode_fold1_key.lo ext/mbstring/oniguruma/src/unicode_fold2_key.lo ext/mbstring/oniguruma/src/unicode_fold3_key.lo ext/mbstring/oniguruma/src/unicode_unfold_key.lo ext/mbstring/oniguruma/src/utf16_be.lo ext/mbstring/oniguruma/src/utf16_le.lo ext/mbstring/oniguruma/src/utf32_be.lo ext/mbstring/oniguruma/src/utf32_le.lo ext/mbstring/oniguruma/src/utf8.lo ext/mbstring/libmbfl/filters/html_entities.lo ext/mbstring/libmbfl/filters/mbfilter_7bit.lo ext/mbstring/libmbfl/filters/mbfilter_ascii.lo ext/mbstring/libmbfl/filters/mbfilter_base64.lo ext/mbstring/libmbfl/filters/mbfilter_big5.lo ext/mbstring/libmbfl/filters/mbfilter_byte2.lo ext/mbstring/libmbfl/filters/mbfilter_byte4.lo ext/mbstring/libmbfl/filters/mbfilter_cp1251.lo ext/mbstring/libmbfl/filters/mbfilter_cp1252.lo ext/mbstring/libmbfl/filters/mbfilter_cp1254.lo ext/mbstring/libmbfl/filters/mbfilter_cp5022x.lo ext/mbstring/libmbfl/filters/mbfilter_cp51932.lo ext/mbstring/libmbfl/filters/mbfilter_cp850.lo ext/mbstring/libmbfl/filters/mbfilter_cp866.lo ext/mbstring/libmbfl/filters/mbfilter_cp932.lo ext/mbstring/libmbfl/filters/mbfilter_cp936.lo ext/mbstring/libmbfl/filters/mbfilter_gb18030.lo ext/mbstring/libmbfl/filters/mbfilter_euc_cn.lo ext/mbstring/libmbfl/filters/mbfilter_euc_jp.lo ext/mbstring/libmbfl/filters/mbfilter_euc_jp_2004.lo ext/mbstring/libmbfl/filters/mbfilter_euc_jp_win.lo ext/mbstring/libmbfl/filters/mbfilter_euc_kr.lo ext/mbstring/libmbfl/filters/mbfilter_euc_tw.lo ext/mbstring/libmbfl/filters/mbfilter_htmlent.lo ext/mbstring/libmbfl/filters/mbfilter_hz.lo ext/mbstring/libmbfl/filters/mbfilter_iso2022_jp_ms.lo ext/mbstring/libmbfl/filters/mbfilter_iso2022jp_2004.lo ext/mbstring/libmbfl/filters/mbfilter_iso2022jp_mobile.lo ext/mbstring/libmbfl/filters/mbfilter_iso2022_kr.lo ext/mbstring/libmbfl/filters/mbfilter_iso8859_1.lo ext/mbstring/libmbfl/filters/mbfilter_iso8859_10.lo ext/mbstring/libmbfl/filters/mbfilter_iso8859_13.lo ext/mbstring/libmbfl/filters/mbfilter_iso8859_14.lo ext/mbstring/libmbfl/filters/mbfilter_iso8859_15.lo ext/mbstring/libmbfl/filters/mbfilter_iso8859_16.lo ext/mbstring/libmbfl/filters/mbfilter_iso8859_2.lo ext/mbstring/libmbfl/filters/mbfilter_iso8859_3.lo ext/mbstring/libmbfl/filters/mbfilter_iso8859_4.lo ext/mbstring/libmbfl/filters/mbfilter_iso8859_5.lo ext/mbstring/libmbfl/filters/mbfilter_iso8859_6.lo ext/mbstring/libmbfl/filters/mbfilter_iso8859_7.lo ext/mbstring/libmbfl/filters/mbfilter_iso8859_8.lo ext/mbstring/libmbfl/filters/mbfilter_iso8859_9.lo ext/mbstring/libmbfl/filters/mbfilter_jis.lo ext/mbstring/libmbfl/filters/mbfilter_koi8r.lo ext/mbstring/libmbfl/filters/mbfilter_armscii8.lo ext/mbstring/libmbfl/filters/mbfilter_qprint.lo ext/mbstring/libmbfl/filters/mbfilter_sjis.lo ext/mbstring/libmbfl/filters/mbfilter_sjis_open.lo ext/mbstring/libmbfl/filters/mbfilter_sjis_mobile.lo ext/mbstring/libmbfl/filters/mbfilter_sjis_mac.lo ext/mbstring/libmbfl/filters/mbfilter_sjis_2004.lo ext/mbstring/libmbfl/filters/mbfilter_tl_jisx0201_jisx0208.lo ext/mbstring/libmbfl/filters/mbfilter_ucs2.lo ext/mbstring/libmbfl/filters/mbfilter_ucs4.lo ext/mbstring/libmbfl/filters/mbfilter_uhc.lo ext/mbstring/libmbfl/filters/mbfilter_utf16.lo ext/mbstring/libmbfl/filters/mbfilter_utf32.lo ext/mbstring/libmbfl/filters/mbfilter_utf7.lo ext/mbstring/libmbfl/filters/mbfilter_utf7imap.lo ext/mbstring/libmbfl/filters/mbfilter_utf8.lo ext/mbstring/libmbfl/filters/mbfilter_utf8_mobile.lo ext/mbstring/libmbfl/filters/mbfilter_uuencode.lo ext/mbstring/libmbfl/filters/mbfilter_koi8u.lo ext/mbstring/libmbfl/mbfl/mbfilter.lo ext/mbstring/libmbfl/mbfl/mbfilter_8bit.lo ext/mbstring/libmbfl/mbfl/mbfilter_pass.lo ext/mbstring/libmbfl/mbfl/mbfilter_wchar.lo ext/mbstring/libmbfl/mbfl/mbfl_convert.lo ext/mbstring/libmbfl/mbfl/mbfl_encoding.lo ext/mbstring/libmbfl/mbfl/mbfl_filter_output.lo ext/mbstring/libmbfl/mbfl/mbfl_ident.lo ext/mbstring/libmbfl/mbfl/mbfl_language.lo ext/mbstring/libmbfl/mbfl/mbfl_memory_device.lo ext/mbstring/libmbfl/mbfl/mbfl_string.lo ext/mbstring/libmbfl/mbfl/mbfl_allocators.lo ext/mbstring/libmbfl/nls/nls_de.lo ext/mbstring/libmbfl/nls/nls_en.lo ext/mbstring/libmbfl/nls/nls_ja.lo ext/mbstring/libmbfl/nls/nls_kr.lo ext/mbstring/libmbfl/nls/nls_neutral.lo ext/mbstring/libmbfl/nls/nls_ru.lo ext/mbstring/libmbfl/nls/nls_uni.lo ext/mbstring/libmbfl/nls/nls_zh.lo ext/mbstring/libmbfl/nls/nls_hy.lo ext/mbstring/libmbfl/nls/nls_tr.lo ext/mbstring/libmbfl/nls/nls_ua.lo ext/mbstring/mbstring.lo ext/mbstring/php_unicode.lo ext/mbstring/mb_gpc.lo ext/mbstring/php_mbregex.lo ext/mysqli/mysqli.lo ext/mysqli/mysqli_api.lo ext/mysqli/mysqli_prop.lo ext/mysqli/mysqli_nonapi.lo ext/mysqli/mysqli_fe.lo ext/mysqli/mysqli_report.lo ext/mysqli/mysqli_driver.lo ext/mysqli/mysqli_warning.lo ext/mysqli/mysqli_exception.lo ext/mysqli/mysqli_result_iterator.lo ext/pdo/pdo.lo ext/pdo/pdo_dbh.lo ext/pdo/pdo_stmt.lo ext/pdo/pdo_sql_parser.lo ext/pdo/pdo_sqlstate.lo ext/pdo_mysql/pdo_mysql.lo ext/pdo_mysql/mysql_driver.lo ext/pdo_mysql/mysql_statement.lo ext/pdo_sqlite/pdo_sqlite.lo ext/pdo_sqlite/sqlite_driver.lo ext/pdo_sqlite/sqlite_statement.lo ext/phar/util.lo ext/phar/tar.lo ext/phar/zip.lo ext/phar/stream.lo ext/phar/func_interceptors.lo ext/phar/dirstream.lo ext/phar/phar.lo ext/phar/phar_object.lo ext/phar/phar_path_check.lo ext/posix/posix.lo ext/reflection/php_reflection.lo ext/session/mod_user_class.lo ext/session/session.lo ext/session/mod_files.lo ext/session/mod_mm.lo ext/session/mod_user.lo ext/simplexml/simplexml.lo ext/simplexml/sxe.lo ext/soap/soap.lo ext/soap/php_encoding.lo ext/soap/php_http.lo ext/soap/php_packet_soap.lo ext/soap/php_schema.lo ext/soap/php_sdl.lo ext/soap/php_xml.lo ext/sockets/sockets.lo ext/sockets/multicast.lo ext/sockets/conversions.lo ext/sockets/sockaddr_conv.lo ext/sockets/sendrecvmsg.lo ext/sodium/libsodium.lo ext/spl/php_spl.lo ext/spl/spl_functions.lo ext/spl/spl_engine.lo ext/spl/spl_iterators.lo ext/spl/spl_array.lo ext/spl/spl_directory.lo ext/spl/spl_exceptions.lo ext/spl/spl_observer.lo ext/spl/spl_dllist.lo ext/spl/spl_heap.lo ext/spl/spl_fixedarray.lo ext/standard/crypt_freesec.lo ext/standard/crypt_blowfish.lo ext/standard/crypt_sha512.lo ext/standard/crypt_sha256.lo ext/standard/php_crypt_r.lo ext/standard/array.lo ext/standard/base64.lo ext/standard/basic_functions.lo ext/standard/browscap.lo ext/standard/crc32.lo ext/standard/crypt.lo ext/standard/cyr_convert.lo ext/standard/datetime.lo ext/standard/dir.lo ext/standard/dl.lo ext/standard/dns.lo ext/standard/exec.lo ext/standard/file.lo ext/standard/filestat.lo ext/standard/flock_compat.lo ext/standard/formatted_print.lo ext/standard/fsock.lo ext/standard/head.lo ext/standard/html.lo ext/standard/image.lo ext/standard/info.lo ext/standard/iptc.lo ext/standard/lcg.lo ext/standard/link.lo ext/standard/mail.lo ext/standard/math.lo ext/standard/md5.lo ext/standard/metaphone.lo ext/standard/microtime.lo ext/standard/pack.lo ext/standard/pageinfo.lo ext/standard/quot_print.lo ext/standard/rand.lo ext/standard/mt_rand.lo ext/standard/soundex.lo ext/standard/string.lo ext/standard/scanf.lo ext/standard/syslog.lo ext/standard/type.lo ext/standard/uniqid.lo ext/standard/url.lo ext/standard/var.lo ext/standard/versioning.lo ext/standard/assert.lo ext/standard/strnatcmp.lo ext/standard/levenshtein.lo ext/standard/incomplete_class.lo ext/standard/url_scanner_ex.lo ext/standard/ftp_fopen_wrapper.lo ext/standard/http_fopen_wrapper.lo ext/standard/php_fopen_wrapper.lo ext/standard/credits.lo ext/standard/css.lo ext/standard/var_unserializer.lo ext/standard/ftok.lo ext/standard/sha1.lo ext/standard/user_filters.lo ext/standard/uuencode.lo ext/standard/filters.lo ext/standard/proc_open.lo ext/standard/streamsfuncs.lo ext/standard/http.lo ext/standard/password.lo ext/standard/random.lo ext/standard/net.lo ext/standard/hrtime.lo ext/tokenizer/tokenizer.lo ext/tokenizer/tokenizer_data.lo ext/xml/xml.lo ext/xml/compat.lo ext/xmlreader/php_xmlreader.lo ext/xmlrpc/xmlrpc-epi-php.lo ext/xmlrpc/libxmlrpc/base64.lo ext/xmlrpc/libxmlrpc/simplestring.lo ext/xmlrpc/libxmlrpc/xml_to_dandarpc.lo ext/xmlrpc/libxmlrpc/xmlrpc_introspection.lo ext/xmlrpc/libxmlrpc/encodings.lo ext/xmlrpc/libxmlrpc/system_methods.lo ext/xmlrpc/libxmlrpc/xml_to_xmlrpc.lo ext/xmlrpc/libxmlrpc/queue.lo ext/xmlrpc/libxmlrpc/xml_element.lo ext/xmlrpc/libxmlrpc/xmlrpc.lo ext/xmlrpc/libxmlrpc/xml_to_soap.lo ext/xmlwriter/php_xmlwriter.lo ext/xsl/php_xsl.lo ext/xsl/xsltprocessor.lo ext/zip/php_zip.lo ext/zip/zip_stream.lo ext/zip/lib/zip_add.lo ext/zip/lib/zip_add_dir.lo ext/zip/lib/zip_add_entry.lo ext/zip/lib/zip_buffer.lo ext/zip/lib/zip_file_set_mtime.lo ext/zip/lib/zip_io_util.lo ext/zip/lib/zip_source_begin_write.lo ext/zip/lib/zip_source_call.lo ext/zip/lib/zip_source_commit_write.lo ext/zip/lib/zip_source_is_deleted.lo ext/zip/lib/zip_source_remove.lo ext/zip/lib/zip_source_rollback_write.lo ext/zip/lib/zip_source_seek.lo ext/zip/lib/zip_source_seek_write.lo ext/zip/lib/zip_source_supports.lo ext/zip/lib/zip_source_tell.lo ext/zip/lib/zip_source_tell_write.lo ext/zip/lib/zip_source_write.lo ext/zip/lib/zip_close.lo ext/zip/lib/zip_delete.lo ext/zip/lib/zip_dir_add.lo ext/zip/lib/zip_dirent.lo ext/zip/lib/zip_discard.lo ext/zip/lib/zip_entry.lo ext/zip/lib/zip_err_str.lo ext/zip/lib/zip_error.lo ext/zip/lib/zip_error_clear.lo ext/zip/lib/zip_error_get.lo ext/zip/lib/zip_error_get_sys_type.lo ext/zip/lib/zip_error_strerror.lo ext/zip/lib/zip_error_to_str.lo ext/zip/lib/zip_extra_field.lo ext/zip/lib/zip_extra_field_api.lo ext/zip/lib/zip_fclose.lo ext/zip/lib/zip_fdopen.lo ext/zip/lib/zip_file_add.lo ext/zip/lib/zip_file_error_clear.lo ext/zip/lib/zip_file_error_get.lo ext/zip/lib/zip_file_get_comment.lo ext/zip/lib/zip_file_get_offset.lo ext/zip/lib/zip_file_rename.lo ext/zip/lib/zip_file_replace.lo ext/zip/lib/zip_file_set_comment.lo ext/zip/lib/zip_file_strerror.lo ext/zip/lib/zip_filerange_crc.lo ext/zip/lib/zip_fopen.lo ext/zip/lib/zip_file_get_external_attributes.lo ext/zip/lib/zip_file_set_external_attributes.lo ext/zip/lib/zip_fopen_encrypted.lo ext/zip/lib/zip_fopen_index.lo ext/zip/lib/zip_fopen_index_encrypted.lo ext/zip/lib/zip_fread.lo ext/zip/lib/zip_get_archive_comment.lo ext/zip/lib/zip_get_archive_flag.lo ext/zip/lib/zip_get_compression_implementation.lo ext/zip/lib/zip_get_encryption_implementation.lo ext/zip/lib/zip_get_file_comment.lo ext/zip/lib/zip_get_name.lo ext/zip/lib/zip_get_num_entries.lo ext/zip/lib/zip_get_num_files.lo ext/zip/lib/zip_memdup.lo ext/zip/lib/zip_name_locate.lo ext/zip/lib/zip_new.lo ext/zip/lib/zip_open.lo ext/zip/lib/zip_rename.lo ext/zip/lib/zip_replace.lo ext/zip/lib/zip_hash.lo ext/zip/lib/zip_set_archive_comment.lo ext/zip/lib/zip_set_archive_flag.lo ext/zip/lib/zip_set_default_password.lo ext/zip/lib/zip_set_file_comment.lo ext/zip/lib/zip_set_file_compression.lo ext/zip/lib/zip_set_name.lo ext/zip/lib/zip_source_buffer.lo ext/zip/lib/zip_source_close.lo ext/zip/lib/zip_source_crc.lo ext/zip/lib/zip_source_deflate.lo ext/zip/lib/zip_source_error.lo ext/zip/lib/zip_source_file.lo ext/zip/lib/zip_source_filep.lo ext/zip/lib/zip_source_free.lo ext/zip/lib/zip_source_function.lo ext/zip/lib/zip_source_layered.lo ext/zip/lib/zip_source_open.lo ext/zip/lib/zip_source_pkware.lo ext/zip/lib/zip_source_read.lo ext/zip/lib/zip_source_stat.lo ext/zip/lib/zip_source_window.lo ext/zip/lib/zip_source_zip.lo ext/zip/lib/zip_source_zip_new.lo ext/zip/lib/zip_stat.lo ext/zip/lib/zip_stat_index.lo ext/zip/lib/zip_stat_init.lo ext/zip/lib/zip_strerror.lo ext/zip/lib/zip_string.lo ext/zip/lib/zip_unchange.lo ext/zip/lib/zip_unchange_all.lo ext/zip/lib/zip_unchange_archive.lo ext/zip/lib/zip_unchange_data.lo ext/zip/lib/zip_utf-8.lo ext/zip/lib/mkstemp.lo ext/mysqlnd/mysqlnd_connection.lo ext/mysqlnd/mysqlnd_alloc.lo ext/mysqlnd/mysqlnd_charset.lo ext/mysqlnd/mysqlnd_wireprotocol.lo ext/mysqlnd/mysqlnd_loaddata.lo ext/mysqlnd/mysqlnd_reverse_api.lo ext/mysqlnd/mysqlnd_vio.lo ext/mysqlnd/mysqlnd_protocol_frame_codec.lo ext/mysqlnd/mysqlnd_statistics.lo ext/mysqlnd/mysqlnd_driver.lo ext/mysqlnd/mysqlnd_ext_plugin.lo ext/mysqlnd/mysqlnd_auth.lo ext/mysqlnd/mysqlnd_result.lo ext/mysqlnd/mysqlnd_result_meta.lo ext/mysqlnd/mysqlnd_debug.lo ext/mysqlnd/mysqlnd_commands.lo ext/mysqlnd/mysqlnd_block_alloc.lo ext/mysqlnd/mysqlnd_read_buffer.lo ext/mysqlnd/mysqlnd_plugin.lo ext/mysqlnd/php_mysqlnd.lo ext/mysqlnd/mysqlnd_ps.lo ext/mysqlnd/mysqlnd_ps_codec.lo TSRM/TSRM.lo TSRM/tsrm_strtok_r.lo main/main.lo main/snprintf.lo main/spprintf.lo main/php_sprintf.lo main/fopen_wrappers.lo main/alloca.lo main/php_scandir.lo main/php_ini.lo main/SAPI.lo main/rfc1867.lo main/php_content_types.lo main/strlcpy.lo main/strlcat.lo main/explicit_bzero.lo main/mergesort.lo main/reentrancy.lo main/php_variables.lo main/php_ticks.lo main/network.lo main/php_open_temporary_file.lo main/output.lo main/getopt.lo main/php_syslog.lo main/streams/streams.lo main/streams/cast.lo main/streams/memory.lo main/streams/filter.lo main/streams/plain_wrapper.lo main/streams/userspace.lo main/streams/transports.lo main/streams/xp_socket.lo main/streams/mmap.lo main/streams/glob_wrapper.lo Zend/zend_language_parser.lo Zend/zend_language_scanner.lo Zend/zend_ini_parser.lo Zend/zend_ini_scanner.lo Zend/zend_alloc.lo Zend/zend_compile.lo Zend/zend_constants.lo Zend/zend_dtrace.lo Zend/zend_execute_API.lo Zend/zend_highlight.lo Zend/zend_llist.lo Zend/zend_vm_opcodes.lo Zend/zend_opcode.lo Zend/zend_operators.lo Zend/zend_ptr_stack.lo Zend/zend_stack.lo Zend/zend_variables.lo Zend/zend.lo Zend/zend_API.lo Zend/zend_extensions.lo Zend/zend_hash.lo Zend/zend_list.lo Zend/zend_builtin_functions.lo Zend/zend_sprintf.lo Zend/zend_ini.lo Zend/zend_sort.lo Zend/zend_multibyte.lo Zend/zend_ts_hash.lo Zend/zend_stream.lo Zend/zend_iterators.lo Zend/zend_interfaces.lo Zend/zend_exceptions.lo Zend/zend_strtod.lo Zend/zend_gc.lo Zend/zend_closures.lo Zend/zend_float.lo Zend/zend_string.lo Zend/zend_signal.lo Zend/zend_generators.lo Zend/zend_virtual_cwd.lo Zend/zend_ast.lo Zend/zend_objects.lo Zend/zend_object_handlers.lo Zend/zend_objects_API.lo Zend/zend_default_classes.lo Zend/zend_inheritance.lo Zend/zend_smart_str.lo Zend/zend_cpuinfo.lo Zend/zend_execute.lo main/internal_functions_cli.lo sapi/phpdbg/phpdbg.lo sapi/phpdbg/phpdbg_parser.lo sapi/phpdbg/phpdbg_lexer.lo sapi/phpdbg/phpdbg_prompt.lo sapi/phpdbg/phpdbg_help.lo sapi/phpdbg/phpdbg_break.lo sapi/phpdbg/phpdbg_print.lo sapi/phpdbg/phpdbg_bp.lo sapi/phpdbg/phpdbg_opcode.lo sapi/phpdbg/phpdbg_list.lo sapi/phpdbg/phpdbg_utils.lo sapi/phpdbg/phpdbg_info.lo sapi/phpdbg/phpdbg_cmd.lo sapi/phpdbg/phpdbg_set.lo sapi/phpdbg/phpdbg_frame.lo sapi/phpdbg/phpdbg_watch.lo sapi/phpdbg/phpdbg_btree.lo sapi/phpdbg/phpdbg_sigsafe.lo sapi/phpdbg/phpdbg_wait.lo sapi/phpdbg/phpdbg_io.lo sapi/phpdbg/phpdbg_eol.lo sapi/phpdbg/phpdbg_out.lo -lcrypt -lc-client -lz -lexslt -lresolv -lcrypt -lsodium -lrt -lstdc++ -lcrypt -lpam -lpng -lz -ljpeg -lwebp -lz -lrt -lm -ldl -lnsl -lsystemd -lxml2 -lz -llzma -lm -ldl -lgssapi_krb5 -lkrb5 -lk5crypto -lcom_err -lssl -lcrypto -lpcre2-8 -lcurl -lxml2 -lz -llzma -lm -ldl -lssl -lcrypto -lfreetype -lgssapi_krb5 -lkrb5 -lk5crypto -lcom_err -lssl -lcrypto -licui18n -licuuc -licudata -licuio -lxml2 -lz -llzma -lm -ldl -lxml2 -lz -llzma -lm -ldl -lcrypt -lxml2 -lz -llzma -lm -ldl -lxml2 -lz -llzma -lm -ldl -lxml2 -lz -llzma -lm -ldl -lxml2 -lz -llzma -lm -ldl -lxslt -lxml2 -lz -llzma -ldl -lm -lssl -lcrypto -lcrypt -o sapi/phpdbg/phpdbg
/bin/sh /usr/local/directadmin/custombuild/php-7.3.26/libtool --silent --preserve-dup-deps --mode=link cc -export-dynamic -I/usr/local/include -g -O2 -fvisibility=hidden -DZEND_SIGNALS -L/usr/local/lib -L/usr/local/imap-2007f/lib -L/usr/local/icu/lib -R /usr/local/lib -R /usr/local/imap-2007f/lib -R /usr/local/icu/lib ext/date/php_date.lo ext/date/lib/astro.lo ext/date/lib/dow.lo ext/date/lib/parse_date.lo ext/date/lib/parse_tz.lo ext/date/lib/timelib.lo ext/date/lib/tm2unixtime.lo ext/date/lib/unixtime2tm.lo ext/date/lib/parse_iso_intervals.lo ext/date/lib/interval.lo ext/libxml/libxml.lo ext/openssl/openssl.lo ext/openssl/xp_ssl.lo ext/pcre/php_pcre.lo ext/sqlite3/sqlite3.lo ext/sqlite3/libsqlite/sqlite3.lo ext/zlib/zlib.lo ext/zlib/zlib_fopen_wrapper.lo ext/zlib/zlib_filter.lo ext/bcmath/bcmath.lo ext/bcmath/libbcmath/src/add.lo ext/bcmath/libbcmath/src/div.lo ext/bcmath/libbcmath/src/init.lo ext/bcmath/libbcmath/src/neg.lo ext/bcmath/libbcmath/src/outofmem.lo ext/bcmath/libbcmath/src/raisemod.lo ext/bcmath/libbcmath/src/sub.lo ext/bcmath/libbcmath/src/compare.lo ext/bcmath/libbcmath/src/divmod.lo ext/bcmath/libbcmath/src/int2num.lo ext/bcmath/libbcmath/src/num2long.lo ext/bcmath/libbcmath/src/output.lo ext/bcmath/libbcmath/src/recmul.lo ext/bcmath/libbcmath/src/sqrt.lo ext/bcmath/libbcmath/src/zero.lo ext/bcmath/libbcmath/src/debug.lo ext/bcmath/libbcmath/src/doaddsub.lo ext/bcmath/libbcmath/src/nearzero.lo ext/bcmath/libbcmath/src/num2str.lo ext/bcmath/libbcmath/src/raise.lo ext/bcmath/libbcmath/src/rmzero.lo ext/bcmath/libbcmath/src/str2num.lo ext/calendar/calendar.lo ext/calendar/dow.lo ext/calendar/french.lo ext/calendar/gregor.lo ext/calendar/jewish.lo ext/calendar/julian.lo ext/calendar/easter.lo ext/calendar/cal_unix.lo ext/ctype/ctype.lo ext/curl/interface.lo ext/curl/multi.lo ext/curl/share.lo ext/curl/curl_file.lo ext/dom/php_dom.lo ext/dom/attr.lo ext/dom/document.lo ext/dom/domerrorhandler.lo ext/dom/domstringlist.lo ext/dom/domexception.lo ext/dom/namelist.lo ext/dom/processinginstruction.lo ext/dom/cdatasection.lo ext/dom/documentfragment.lo ext/dom/domimplementation.lo ext/dom/element.lo ext/dom/node.lo ext/dom/string_extend.lo ext/dom/characterdata.lo ext/dom/documenttype.lo ext/dom/domimplementationlist.lo ext/dom/entity.lo ext/dom/nodelist.lo ext/dom/text.lo ext/dom/comment.lo ext/dom/domconfiguration.lo ext/dom/domimplementationsource.lo ext/dom/entityreference.lo ext/dom/notation.lo ext/dom/xpath.lo ext/dom/dom_iterators.lo ext/dom/typeinfo.lo ext/dom/domerror.lo ext/dom/domlocator.lo ext/dom/namednodemap.lo ext/dom/userdatahandler.lo ext/exif/exif.lo ext/fileinfo/fileinfo.lo ext/fileinfo/libmagic/apprentice.lo ext/fileinfo/libmagic/apptype.lo ext/fileinfo/libmagic/ascmagic.lo ext/fileinfo/libmagic/cdf.lo ext/fileinfo/libmagic/cdf_time.lo ext/fileinfo/libmagic/compress.lo ext/fileinfo/libmagic/encoding.lo ext/fileinfo/libmagic/fsmagic.lo ext/fileinfo/libmagic/funcs.lo ext/fileinfo/libmagic/is_tar.lo ext/fileinfo/libmagic/magic.lo ext/fileinfo/libmagic/print.lo ext/fileinfo/libmagic/readcdf.lo ext/fileinfo/libmagic/softmagic.lo ext/fileinfo/libmagic/der.lo ext/fileinfo/libmagic/buffer.lo ext/filter/filter.lo ext/filter/sanitizing_filters.lo ext/filter/logical_filters.lo ext/filter/callback_filter.lo ext/ftp/php_ftp.lo ext/ftp/ftp.lo ext/gd/gd.lo ext/gd/libgd/gd.lo ext/gd/libgd/gd_gd.lo ext/gd/libgd/gd_gd2.lo ext/gd/libgd/gd_io.lo ext/gd/libgd/gd_io_dp.lo ext/gd/libgd/gd_io_file.lo ext/gd/libgd/gd_ss.lo ext/gd/libgd/gd_io_ss.lo ext/gd/libgd/gd_webp.lo ext/gd/libgd/gd_png.lo ext/gd/libgd/gd_jpeg.lo ext/gd/libgd/gdxpm.lo ext/gd/libgd/gdfontt.lo ext/gd/libgd/gdfonts.lo ext/gd/libgd/gdfontmb.lo ext/gd/libgd/gdfontl.lo ext/gd/libgd/gdfontg.lo ext/gd/libgd/gdtables.lo ext/gd/libgd/gdft.lo ext/gd/libgd/gdcache.lo ext/gd/libgd/gdkanji.lo ext/gd/libgd/wbmp.lo ext/gd/libgd/gd_wbmp.lo ext/gd/libgd/gdhelpers.lo ext/gd/libgd/gd_topal.lo ext/gd/libgd/gd_gif_in.lo ext/gd/libgd/gd_xbm.lo ext/gd/libgd/gd_gif_out.lo ext/gd/libgd/gd_security.lo ext/gd/libgd/gd_filter.lo ext/gd/libgd/gd_pixelate.lo ext/gd/libgd/gd_rotate.lo ext/gd/libgd/gd_color_match.lo ext/gd/libgd/gd_transform.lo ext/gd/libgd/gd_crop.lo ext/gd/libgd/gd_interpolation.lo ext/gd/libgd/gd_matrix.lo ext/gd/libgd/gd_bmp.lo ext/gettext/gettext.lo ext/hash/hash.lo ext/hash/hash_md.lo ext/hash/hash_sha.lo ext/hash/hash_ripemd.lo ext/hash/hash_haval.lo ext/hash/hash_tiger.lo ext/hash/hash_gost.lo ext/hash/hash_snefru.lo ext/hash/hash_whirlpool.lo ext/hash/hash_adler32.lo ext/hash/hash_crc32.lo ext/hash/hash_fnv.lo ext/hash/hash_joaat.lo ext/hash/sha3/generic64lc/KeccakP-1600-opt64.lo ext/hash/sha3/generic64lc/KeccakHash.lo ext/hash/sha3/generic64lc/KeccakSponge.lo ext/hash/hash_sha3.lo ext/iconv/iconv.lo ext/imap/php_imap.lo ext/intl/php_intl.lo ext/intl/intl_error.lo ext/intl/intl_convert.lo ext/intl/collator/collator.lo ext/intl/collator/collator_class.lo ext/intl/collator/collator_sort.lo ext/intl/collator/collator_convert.lo ext/intl/collator/collator_locale.lo ext/intl/collator/collator_compare.lo ext/intl/collator/collator_attr.lo ext/intl/collator/collator_create.lo ext/intl/collator/collator_is_numeric.lo ext/intl/collator/collator_error.lo ext/intl/common/common_error.lo ext/intl/converter/converter.lo ext/intl/formatter/formatter.lo ext/intl/formatter/formatter_main.lo ext/intl/formatter/formatter_class.lo ext/intl/formatter/formatter_attr.lo ext/intl/formatter/formatter_data.lo ext/intl/formatter/formatter_format.lo ext/intl/formatter/formatter_parse.lo ext/intl/normalizer/normalizer.lo ext/intl/normalizer/normalizer_class.lo ext/intl/normalizer/normalizer_normalize.lo ext/intl/locale/locale.lo ext/intl/locale/locale_class.lo ext/intl/locale/locale_methods.lo ext/intl/dateformat/dateformat.lo ext/intl/dateformat/dateformat_class.lo ext/intl/dateformat/dateformat_attr.lo ext/intl/dateformat/dateformat_data.lo ext/intl/dateformat/dateformat_format.lo ext/intl/dateformat/dateformat_parse.lo ext/intl/msgformat/msgformat.lo ext/intl/msgformat/msgformat_attr.lo ext/intl/msgformat/msgformat_class.lo ext/intl/msgformat/msgformat_data.lo ext/intl/msgformat/msgformat_format.lo ext/intl/msgformat/msgformat_parse.lo ext/intl/grapheme/grapheme_string.lo ext/intl/grapheme/grapheme_util.lo ext/intl/resourcebundle/resourcebundle.lo ext/intl/resourcebundle/resourcebundle_class.lo ext/intl/resourcebundle/resourcebundle_iterator.lo ext/intl/transliterator/transliterator.lo ext/intl/transliterator/transliterator_class.lo ext/intl/transliterator/transliterator_methods.lo ext/intl/uchar/uchar.lo ext/intl/idn/idn.lo ext/intl/spoofchecker/spoofchecker_class.lo ext/intl/spoofchecker/spoofchecker.lo ext/intl/spoofchecker/spoofchecker_create.lo ext/intl/spoofchecker/spoofchecker_main.lo ext/intl/intl_convertcpp.lo ext/intl/common/common_enum.lo ext/intl/common/common_date.lo ext/intl/dateformat/dateformat_format_object.lo ext/intl/dateformat/dateformat_create.lo ext/intl/dateformat/dateformat_attrcpp.lo ext/intl/dateformat/dateformat_helpers.lo ext/intl/msgformat/msgformat_helpers.lo ext/intl/timezone/timezone_class.lo ext/intl/timezone/timezone_methods.lo ext/intl/calendar/calendar_class.lo ext/intl/calendar/calendar_methods.lo ext/intl/calendar/gregoriancalendar_methods.lo ext/intl/breakiterator/breakiterator_class.lo ext/intl/breakiterator/breakiterator_iterators.lo ext/intl/breakiterator/breakiterator_methods.lo ext/intl/breakiterator/rulebasedbreakiterator_methods.lo ext/intl/breakiterator/codepointiterator_internal.lo ext/intl/breakiterator/codepointiterator_methods.lo ext/json/json.lo ext/json/json_encoder.lo ext/json/json_parser.lo ext/json/json_scanner.lo ext/mbstring/oniguruma/src/ascii.lo ext/mbstring/oniguruma/src/big5.lo ext/mbstring/oniguruma/src/cp1251.lo ext/mbstring/oniguruma/src/euc_jp.lo ext/mbstring/oniguruma/src/euc_jp_prop.lo ext/mbstring/oniguruma/src/euc_kr.lo ext/mbstring/oniguruma/src/euc_tw.lo ext/mbstring/oniguruma/src/gb18030.lo ext/mbstring/oniguruma/src/iso8859_1.lo ext/mbstring/oniguruma/src/iso8859_10.lo ext/mbstring/oniguruma/src/iso8859_11.lo ext/mbstring/oniguruma/src/iso8859_13.lo ext/mbstring/oniguruma/src/iso8859_14.lo ext/mbstring/oniguruma/src/iso8859_15.lo ext/mbstring/oniguruma/src/iso8859_16.lo ext/mbstring/oniguruma/src/iso8859_2.lo ext/mbstring/oniguruma/src/iso8859_3.lo ext/mbstring/oniguruma/src/iso8859_4.lo ext/mbstring/oniguruma/src/iso8859_5.lo ext/mbstring/oniguruma/src/iso8859_6.lo ext/mbstring/oniguruma/src/iso8859_7.lo ext/mbstring/oniguruma/src/iso8859_8.lo ext/mbstring/oniguruma/src/iso8859_9.lo ext/mbstring/oniguruma/src/koi8.lo ext/mbstring/oniguruma/src/koi8_r.lo ext/mbstring/oniguruma/src/onig_init.lo ext/mbstring/oniguruma/src/regcomp.lo ext/mbstring/oniguruma/src/regenc.lo ext/mbstring/oniguruma/src/regerror.lo ext/mbstring/oniguruma/src/regexec.lo ext/mbstring/oniguruma/src/regext.lo ext/mbstring/oniguruma/src/reggnu.lo ext/mbstring/oniguruma/src/regparse.lo ext/mbstring/oniguruma/src/regposerr.lo ext/mbstring/oniguruma/src/regposix.lo ext/mbstring/oniguruma/src/regsyntax.lo ext/mbstring/oniguruma/src/regtrav.lo ext/mbstring/oniguruma/src/regversion.lo ext/mbstring/oniguruma/src/sjis.lo ext/mbstring/oniguruma/src/sjis_prop.lo ext/mbstring/oniguruma/src/st.lo ext/mbstring/oniguruma/src/unicode.lo ext/mbstring/oniguruma/src/unicode_fold1_key.lo ext/mbstring/oniguruma/src/unicode_fold2_key.lo ext/mbstring/oniguruma/src/unicode_fold3_key.lo ext/mbstring/oniguruma/src/unicode_unfold_key.lo ext/mbstring/oniguruma/src/utf16_be.lo ext/mbstring/oniguruma/src/utf16_le.lo ext/mbstring/oniguruma/src/utf32_be.lo ext/mbstring/oniguruma/src/utf32_le.lo ext/mbstring/oniguruma/src/utf8.lo ext/mbstring/libmbfl/filters/html_entities.lo ext/mbstring/libmbfl/filters/mbfilter_7bit.lo ext/mbstring/libmbfl/filters/mbfilter_ascii.lo ext/mbstring/libmbfl/filters/mbfilter_base64.lo ext/mbstring/libmbfl/filters/mbfilter_big5.lo ext/mbstring/libmbfl/filters/mbfilter_byte2.lo ext/mbstring/libmbfl/filters/mbfilter_byte4.lo ext/mbstring/libmbfl/filters/mbfilter_cp1251.lo ext/mbstring/libmbfl/filters/mbfilter_cp1252.lo ext/mbstring/libmbfl/filters/mbfilter_cp1254.lo ext/mbstring/libmbfl/filters/mbfilter_cp5022x.lo ext/mbstring/libmbfl/filters/mbfilter_cp51932.lo ext/mbstring/libmbfl/filters/mbfilter_cp850.lo ext/mbstring/libmbfl/filters/mbfilter_cp866.lo ext/mbstring/libmbfl/filters/mbfilter_cp932.lo ext/mbstring/libmbfl/filters/mbfilter_cp936.lo ext/mbstring/libmbfl/filters/mbfilter_gb18030.lo ext/mbstring/libmbfl/filters/mbfilter_euc_cn.lo ext/mbstring/libmbfl/filters/mbfilter_euc_jp.lo ext/mbstring/libmbfl/filters/mbfilter_euc_jp_2004.lo ext/mbstring/libmbfl/filters/mbfilter_euc_jp_win.lo ext/mbstring/libmbfl/filters/mbfilter_euc_kr.lo ext/mbstring/libmbfl/filters/mbfilter_euc_tw.lo ext/mbstring/libmbfl/filters/mbfilter_htmlent.lo ext/mbstring/libmbfl/filters/mbfilter_hz.lo ext/mbstring/libmbfl/filters/mbfilter_iso2022_jp_ms.lo ext/mbstring/libmbfl/filters/mbfilter_iso2022jp_2004.lo ext/mbstring/libmbfl/filters/mbfilter_iso2022jp_mobile.lo ext/mbstring/libmbfl/filters/mbfilter_iso2022_kr.lo ext/mbstring/libmbfl/filters/mbfilter_iso8859_1.lo ext/mbstring/libmbfl/filters/mbfilter_iso8859_10.lo ext/mbstring/libmbfl/filters/mbfilter_iso8859_13.lo ext/mbstring/libmbfl/filters/mbfilter_iso8859_14.lo ext/mbstring/libmbfl/filters/mbfilter_iso8859_15.lo ext/mbstring/libmbfl/filters/mbfilter_iso8859_16.lo ext/mbstring/libmbfl/filters/mbfilter_iso8859_2.lo ext/mbstring/libmbfl/filters/mbfilter_iso8859_3.lo ext/mbstring/libmbfl/filters/mbfilter_iso8859_4.lo ext/mbstring/libmbfl/filters/mbfilter_iso8859_5.lo ext/mbstring/libmbfl/filters/mbfilter_iso8859_6.lo ext/mbstring/libmbfl/filters/mbfilter_iso8859_7.lo ext/mbstring/libmbfl/filters/mbfilter_iso8859_8.lo ext/mbstring/libmbfl/filters/mbfilter_iso8859_9.lo ext/mbstring/libmbfl/filters/mbfilter_jis.lo ext/mbstring/libmbfl/filters/mbfilter_koi8r.lo ext/mbstring/libmbfl/filters/mbfilter_armscii8.lo ext/mbstring/libmbfl/filters/mbfilter_qprint.lo ext/mbstring/libmbfl/filters/mbfilter_sjis.lo ext/mbstring/libmbfl/filters/mbfilter_sjis_open.lo ext/mbstring/libmbfl/filters/mbfilter_sjis_mobile.lo ext/mbstring/libmbfl/filters/mbfilter_sjis_mac.lo ext/mbstring/libmbfl/filters/mbfilter_sjis_2004.lo ext/mbstring/libmbfl/filters/mbfilter_tl_jisx0201_jisx0208.lo ext/mbstring/libmbfl/filters/mbfilter_ucs2.lo ext/mbstring/libmbfl/filters/mbfilter_ucs4.lo ext/mbstring/libmbfl/filters/mbfilter_uhc.lo ext/mbstring/libmbfl/filters/mbfilter_utf16.lo ext/mbstring/libmbfl/filters/mbfilter_utf32.lo ext/mbstring/libmbfl/filters/mbfilter_utf7.lo ext/mbstring/libmbfl/filters/mbfilter_utf7imap.lo ext/mbstring/libmbfl/filters/mbfilter_utf8.lo ext/mbstring/libmbfl/filters/mbfilter_utf8_mobile.lo ext/mbstring/libmbfl/filters/mbfilter_uuencode.lo ext/mbstring/libmbfl/filters/mbfilter_koi8u.lo ext/mbstring/libmbfl/mbfl/mbfilter.lo ext/mbstring/libmbfl/mbfl/mbfilter_8bit.lo ext/mbstring/libmbfl/mbfl/mbfilter_pass.lo ext/mbstring/libmbfl/mbfl/mbfilter_wchar.lo ext/mbstring/libmbfl/mbfl/mbfl_convert.lo ext/mbstring/libmbfl/mbfl/mbfl_encoding.lo ext/mbstring/libmbfl/mbfl/mbfl_filter_output.lo ext/mbstring/libmbfl/mbfl/mbfl_ident.lo ext/mbstring/libmbfl/mbfl/mbfl_language.lo ext/mbstring/libmbfl/mbfl/mbfl_memory_device.lo ext/mbstring/libmbfl/mbfl/mbfl_string.lo ext/mbstring/libmbfl/mbfl/mbfl_allocators.lo ext/mbstring/libmbfl/nls/nls_de.lo ext/mbstring/libmbfl/nls/nls_en.lo ext/mbstring/libmbfl/nls/nls_ja.lo ext/mbstring/libmbfl/nls/nls_kr.lo ext/mbstring/libmbfl/nls/nls_neutral.lo ext/mbstring/libmbfl/nls/nls_ru.lo ext/mbstring/libmbfl/nls/nls_uni.lo ext/mbstring/libmbfl/nls/nls_zh.lo ext/mbstring/libmbfl/nls/nls_hy.lo ext/mbstring/libmbfl/nls/nls_tr.lo ext/mbstring/libmbfl/nls/nls_ua.lo ext/mbstring/mbstring.lo ext/mbstring/php_unicode.lo ext/mbstring/mb_gpc.lo ext/mbstring/php_mbregex.lo ext/mysqli/mysqli.lo ext/mysqli/mysqli_api.lo ext/mysqli/mysqli_prop.lo ext/mysqli/mysqli_nonapi.lo ext/mysqli/mysqli_fe.lo ext/mysqli/mysqli_report.lo ext/mysqli/mysqli_driver.lo ext/mysqli/mysqli_warning.lo ext/mysqli/mysqli_exception.lo ext/mysqli/mysqli_result_iterator.lo ext/pdo/pdo.lo ext/pdo/pdo_dbh.lo ext/pdo/pdo_stmt.lo ext/pdo/pdo_sql_parser.lo ext/pdo/pdo_sqlstate.lo ext/pdo_mysql/pdo_mysql.lo ext/pdo_mysql/mysql_driver.lo ext/pdo_mysql/mysql_statement.lo ext/pdo_sqlite/pdo_sqlite.lo ext/pdo_sqlite/sqlite_driver.lo ext/pdo_sqlite/sqlite_statement.lo ext/phar/util.lo ext/phar/tar.lo ext/phar/zip.lo ext/phar/stream.lo ext/phar/func_interceptors.lo ext/phar/dirstream.lo ext/phar/phar.lo ext/phar/phar_object.lo ext/phar/phar_path_check.lo ext/posix/posix.lo ext/reflection/php_reflection.lo ext/session/mod_user_class.lo ext/session/session.lo ext/session/mod_files.lo ext/session/mod_mm.lo ext/session/mod_user.lo ext/simplexml/simplexml.lo ext/simplexml/sxe.lo ext/soap/soap.lo ext/soap/php_encoding.lo ext/soap/php_http.lo ext/soap/php_packet_soap.lo ext/soap/php_schema.lo ext/soap/php_sdl.lo ext/soap/php_xml.lo ext/sockets/sockets.lo ext/sockets/multicast.lo ext/sockets/conversions.lo ext/sockets/sockaddr_conv.lo ext/sockets/sendrecvmsg.lo ext/sodium/libsodium.lo ext/spl/php_spl.lo ext/spl/spl_functions.lo ext/spl/spl_engine.lo ext/spl/spl_iterators.lo ext/spl/spl_array.lo ext/spl/spl_directory.lo ext/spl/spl_exceptions.lo ext/spl/spl_observer.lo ext/spl/spl_dllist.lo ext/spl/spl_heap.lo ext/spl/spl_fixedarray.lo ext/standard/crypt_freesec.lo ext/standard/crypt_blowfish.lo ext/standard/crypt_sha512.lo ext/standard/crypt_sha256.lo ext/standard/php_crypt_r.lo ext/standard/array.lo ext/standard/base64.lo ext/standard/basic_functions.lo ext/standard/browscap.lo ext/standard/crc32.lo ext/standard/crypt.lo ext/standard/cyr_convert.lo ext/standard/datetime.lo ext/standard/dir.lo ext/standard/dl.lo ext/standard/dns.lo ext/standard/exec.lo ext/standard/file.lo ext/standard/filestat.lo ext/standard/flock_compat.lo ext/standard/formatted_print.lo ext/standard/fsock.lo ext/standard/head.lo ext/standard/html.lo ext/standard/image.lo ext/standard/info.lo ext/standard/iptc.lo ext/standard/lcg.lo ext/standard/link.lo ext/standard/mail.lo ext/standard/math.lo ext/standard/md5.lo ext/standard/metaphone.lo ext/standard/microtime.lo ext/standard/pack.lo ext/standard/pageinfo.lo ext/standard/quot_print.lo ext/standard/rand.lo ext/standard/mt_rand.lo ext/standard/soundex.lo ext/standard/string.lo ext/standard/scanf.lo ext/standard/syslog.lo ext/standard/type.lo ext/standard/uniqid.lo ext/standard/url.lo ext/standard/var.lo ext/standard/versioning.lo ext/standard/assert.lo ext/standard/strnatcmp.lo ext/standard/levenshtein.lo ext/standard/incomplete_class.lo ext/standard/url_scanner_ex.lo ext/standard/ftp_fopen_wrapper.lo ext/standard/http_fopen_wrapper.lo ext/standard/php_fopen_wrapper.lo ext/standard/credits.lo ext/standard/css.lo ext/standard/var_unserializer.lo ext/standard/ftok.lo ext/standard/sha1.lo ext/standard/user_filters.lo ext/standard/uuencode.lo ext/standard/filters.lo ext/standard/proc_open.lo ext/standard/streamsfuncs.lo ext/standard/http.lo ext/standard/password.lo ext/standard/random.lo ext/standard/net.lo ext/standard/hrtime.lo ext/tokenizer/tokenizer.lo ext/tokenizer/tokenizer_data.lo ext/xml/xml.lo ext/xml/compat.lo ext/xmlreader/php_xmlreader.lo ext/xmlrpc/xmlrpc-epi-php.lo ext/xmlrpc/libxmlrpc/base64.lo ext/xmlrpc/libxmlrpc/simplestring.lo ext/xmlrpc/libxmlrpc/xml_to_dandarpc.lo ext/xmlrpc/libxmlrpc/xmlrpc_introspection.lo ext/xmlrpc/libxmlrpc/encodings.lo ext/xmlrpc/libxmlrpc/system_methods.lo ext/xmlrpc/libxmlrpc/xml_to_xmlrpc.lo ext/xmlrpc/libxmlrpc/queue.lo ext/xmlrpc/libxmlrpc/xml_element.lo ext/xmlrpc/libxmlrpc/xmlrpc.lo ext/xmlrpc/libxmlrpc/xml_to_soap.lo ext/xmlwriter/php_xmlwriter.lo ext/xsl/php_xsl.lo ext/xsl/xsltprocessor.lo ext/zip/php_zip.lo ext/zip/zip_stream.lo ext/zip/lib/zip_add.lo ext/zip/lib/zip_add_dir.lo ext/zip/lib/zip_add_entry.lo ext/zip/lib/zip_buffer.lo ext/zip/lib/zip_file_set_mtime.lo ext/zip/lib/zip_io_util.lo ext/zip/lib/zip_source_begin_write.lo ext/zip/lib/zip_source_call.lo ext/zip/lib/zip_source_commit_write.lo ext/zip/lib/zip_source_is_deleted.lo ext/zip/lib/zip_source_remove.lo ext/zip/lib/zip_source_rollback_write.lo ext/zip/lib/zip_source_seek.lo ext/zip/lib/zip_source_seek_write.lo ext/zip/lib/zip_source_supports.lo ext/zip/lib/zip_source_tell.lo ext/zip/lib/zip_source_tell_write.lo ext/zip/lib/zip_source_write.lo ext/zip/lib/zip_close.lo ext/zip/lib/zip_delete.lo ext/zip/lib/zip_dir_add.lo ext/zip/lib/zip_dirent.lo ext/zip/lib/zip_discard.lo ext/zip/lib/zip_entry.lo ext/zip/lib/zip_err_str.lo ext/zip/lib/zip_error.lo ext/zip/lib/zip_error_clear.lo ext/zip/lib/zip_error_get.lo ext/zip/lib/zip_error_get_sys_type.lo ext/zip/lib/zip_error_strerror.lo ext/zip/lib/zip_error_to_str.lo ext/zip/lib/zip_extra_field.lo ext/zip/lib/zip_extra_field_api.lo ext/zip/lib/zip_fclose.lo ext/zip/lib/zip_fdopen.lo ext/zip/lib/zip_file_add.lo ext/zip/lib/zip_file_error_clear.lo ext/zip/lib/zip_file_error_get.lo ext/zip/lib/zip_file_get_comment.lo ext/zip/lib/zip_file_get_offset.lo ext/zip/lib/zip_file_rename.lo ext/zip/lib/zip_file_replace.lo ext/zip/lib/zip_file_set_comment.lo ext/zip/lib/zip_file_strerror.lo ext/zip/lib/zip_filerange_crc.lo ext/zip/lib/zip_fopen.lo ext/zip/lib/zip_file_get_external_attributes.lo ext/zip/lib/zip_file_set_external_attributes.lo ext/zip/lib/zip_fopen_encrypted.lo ext/zip/lib/zip_fopen_index.lo ext/zip/lib/zip_fopen_index_encrypted.lo ext/zip/lib/zip_fread.lo ext/zip/lib/zip_get_archive_comment.lo ext/zip/lib/zip_get_archive_flag.lo ext/zip/lib/zip_get_compression_implementation.lo ext/zip/lib/zip_get_encryption_implementation.lo ext/zip/lib/zip_get_file_comment.lo ext/zip/lib/zip_get_name.lo ext/zip/lib/zip_get_num_entries.lo ext/zip/lib/zip_get_num_files.lo ext/zip/lib/zip_memdup.lo ext/zip/lib/zip_name_locate.lo ext/zip/lib/zip_new.lo ext/zip/lib/zip_open.lo ext/zip/lib/zip_rename.lo ext/zip/lib/zip_replace.lo ext/zip/lib/zip_hash.lo ext/zip/lib/zip_set_archive_comment.lo ext/zip/lib/zip_set_archive_flag.lo ext/zip/lib/zip_set_default_password.lo ext/zip/lib/zip_set_file_comment.lo ext/zip/lib/zip_set_file_compression.lo ext/zip/lib/zip_set_name.lo ext/zip/lib/zip_source_buffer.lo ext/zip/lib/zip_source_close.lo ext/zip/lib/zip_source_crc.lo ext/zip/lib/zip_source_deflate.lo ext/zip/lib/zip_source_error.lo ext/zip/lib/zip_source_file.lo ext/zip/lib/zip_source_filep.lo ext/zip/lib/zip_source_free.lo ext/zip/lib/zip_source_function.lo ext/zip/lib/zip_source_layered.lo ext/zip/lib/zip_source_open.lo ext/zip/lib/zip_source_pkware.lo ext/zip/lib/zip_source_read.lo ext/zip/lib/zip_source_stat.lo ext/zip/lib/zip_source_window.lo ext/zip/lib/zip_source_zip.lo ext/zip/lib/zip_source_zip_new.lo ext/zip/lib/zip_stat.lo ext/zip/lib/zip_stat_index.lo ext/zip/lib/zip_stat_init.lo ext/zip/lib/zip_strerror.lo ext/zip/lib/zip_string.lo ext/zip/lib/zip_unchange.lo ext/zip/lib/zip_unchange_all.lo ext/zip/lib/zip_unchange_archive.lo ext/zip/lib/zip_unchange_data.lo ext/zip/lib/zip_utf-8.lo ext/zip/lib/mkstemp.lo ext/mysqlnd/mysqlnd_connection.lo ext/mysqlnd/mysqlnd_alloc.lo ext/mysqlnd/mysqlnd_charset.lo ext/mysqlnd/mysqlnd_wireprotocol.lo ext/mysqlnd/mysqlnd_loaddata.lo ext/mysqlnd/mysqlnd_reverse_api.lo ext/mysqlnd/mysqlnd_vio.lo ext/mysqlnd/mysqlnd_protocol_frame_codec.lo ext/mysqlnd/mysqlnd_statistics.lo ext/mysqlnd/mysqlnd_driver.lo ext/mysqlnd/mysqlnd_ext_plugin.lo ext/mysqlnd/mysqlnd_auth.lo ext/mysqlnd/mysqlnd_result.lo ext/mysqlnd/mysqlnd_result_meta.lo ext/mysqlnd/mysqlnd_debug.lo ext/mysqlnd/mysqlnd_commands.lo ext/mysqlnd/mysqlnd_block_alloc.lo ext/mysqlnd/mysqlnd_read_buffer.lo ext/mysqlnd/mysqlnd_plugin.lo ext/mysqlnd/php_mysqlnd.lo ext/mysqlnd/mysqlnd_ps.lo ext/mysqlnd/mysqlnd_ps_codec.lo TSRM/TSRM.lo TSRM/tsrm_strtok_r.lo main/main.lo main/snprintf.lo main/spprintf.lo main/php_sprintf.lo main/fopen_wrappers.lo main/alloca.lo main/php_scandir.lo main/php_ini.lo main/SAPI.lo main/rfc1867.lo main/php_content_types.lo main/strlcpy.lo main/strlcat.lo main/explicit_bzero.lo main/mergesort.lo main/reentrancy.lo main/php_variables.lo main/php_ticks.lo main/network.lo main/php_open_temporary_file.lo main/output.lo main/getopt.lo main/php_syslog.lo main/streams/streams.lo main/streams/cast.lo main/streams/memory.lo main/streams/filter.lo main/streams/plain_wrapper.lo main/streams/userspace.lo main/streams/transports.lo main/streams/xp_socket.lo main/streams/mmap.lo main/streams/glob_wrapper.lo Zend/zend_language_parser.lo Zend/zend_language_scanner.lo Zend/zend_ini_parser.lo Zend/zend_ini_scanner.lo Zend/zend_alloc.lo Zend/zend_compile.lo Zend/zend_constants.lo Zend/zend_dtrace.lo Zend/zend_execute_API.lo Zend/zend_highlight.lo Zend/zend_llist.lo Zend/zend_vm_opcodes.lo Zend/zend_opcode.lo Zend/zend_operators.lo Zend/zend_ptr_stack.lo Zend/zend_stack.lo Zend/zend_variables.lo Zend/zend.lo Zend/zend_API.lo Zend/zend_extensions.lo Zend/zend_hash.lo Zend/zend_list.lo Zend/zend_builtin_functions.lo Zend/zend_sprintf.lo Zend/zend_ini.lo Zend/zend_sort.lo Zend/zend_multibyte.lo Zend/zend_ts_hash.lo Zend/zend_stream.lo Zend/zend_iterators.lo Zend/zend_interfaces.lo Zend/zend_exceptions.lo Zend/zend_strtod.lo Zend/zend_gc.lo Zend/zend_closures.lo Zend/zend_float.lo Zend/zend_string.lo Zend/zend_signal.lo Zend/zend_generators.lo Zend/zend_virtual_cwd.lo Zend/zend_ast.lo Zend/zend_objects.lo Zend/zend_object_handlers.lo Zend/zend_objects_API.lo Zend/zend_default_classes.lo Zend/zend_inheritance.lo Zend/zend_smart_str.lo Zend/zend_cpuinfo.lo Zend/zend_execute.lo main/internal_functions_cli.lo main/fastcgi.lo sapi/cgi/cgi_main.lo -lcrypt -lc-client -lz -lexslt -lresolv -lcrypt -lsodium -lrt -lstdc++ -lcrypt -lpam -lpng -lz -ljpeg -lwebp -lz -lrt -lm -ldl -lnsl -lsystemd -lxml2 -lz -llzma -lm -ldl -lgssapi_krb5 -lkrb5 -lk5crypto -lcom_err -lssl -lcrypto -lpcre2-8 -lcurl -lxml2 -lz -llzma -lm -ldl -lssl -lcrypto -lfreetype -lgssapi_krb5 -lkrb5 -lk5crypto -lcom_err -lssl -lcrypto -licui18n -licuuc -licudata -licuio -lxml2 -lz -llzma -lm -ldl -lxml2 -lz -llzma -lm -ldl -lcrypt -lxml2 -lz -llzma -lm -ldl -lxml2 -lz -llzma -lm -ldl -lxml2 -lz -llzma -lm -ldl -lxml2 -lz -llzma -lm -ldl -lxslt -lxml2 -lz -llzma -ldl -lm -lssl -lcrypto -lcrypt -o sapi/cgi/php-cgi
/usr/local/imap-2007f/lib/libc-client.a(osdep.o): In function `ssl_onceonlyinit':
/usr/local/imap-2007f/c-client/osdep.c:337: warning: the use of `tmpnam' is dangerous, better use `mkstemp'
ext/gd/libgd/.libs/gdkanji.o: In function `do_convert':
/usr/local/directadmin/custombuild/php-7.3.26/ext/gd/libgd/gdkanji.c:349: undefined reference to `libiconv_open'
/usr/local/directadmin/custombuild/php-7.3.26/ext/gd/libgd/gdkanji.c:364: undefined reference to `libiconv'
/usr/local/directadmin/custombuild/php-7.3.26/ext/gd/libgd/gdkanji.c:380: undefined reference to `libiconv_close'
ext/iconv/.libs/iconv.o: In function `php_iconv_stream_filter_dtor':
/usr/local/directadmin/custombuild/php-7.3.26/ext/iconv/iconv.c:2595: undefined reference to `libiconv_close'
ext/iconv/.libs/iconv.o: In function `php_iconv_stream_filter_ctor':
/usr/local/directadmin/custombuild/php-7.3.26/ext/iconv/iconv.c:2616: undefined reference to `libiconv_open'
ext/iconv/.libs/iconv.o: In function `_php_iconv_strlen':
/usr/local/directadmin/custombuild/php-7.3.26/ext/iconv/iconv.c:746: undefined reference to `libiconv_open'
/usr/local/directadmin/custombuild/php-7.3.26/ext/iconv/iconv.c:770: undefined reference to `libiconv'
/usr/local/directadmin/custombuild/php-7.3.26/ext/iconv/iconv.c:802: undefined reference to `libiconv_close'
ext/iconv/.libs/iconv.o: In function `_php_iconv_appendl':
/usr/local/directadmin/custombuild/php-7.3.26/ext/iconv/iconv.c:468: undefined reference to `libiconv'
/usr/local/directadmin/custombuild/php-7.3.26/ext/iconv/iconv.c:502: undefined reference to `libiconv'
ext/iconv/.libs/iconv.o: In function `_php_iconv_mime_decode':
/usr/local/directadmin/custombuild/php-7.3.26/ext/iconv/iconv.c:1498: undefined reference to `libiconv_open'
/usr/local/directadmin/custombuild/php-7.3.26/ext/iconv/iconv.c:2027: undefined reference to `libiconv_close'
/usr/local/directadmin/custombuild/php-7.3.26/ext/iconv/iconv.c:2030: undefined reference to `libiconv_close'
/usr/local/directadmin/custombuild/php-7.3.26/ext/iconv/iconv.c:1636: undefined reference to `libiconv_close'
/usr/local/directadmin/custombuild/php-7.3.26/ext/iconv/iconv.c:1639: undefined reference to `libiconv_open'
ext/iconv/.libs/iconv.o: In function `_php_iconv_substr':
/usr/local/directadmin/custombuild/php-7.3.26/ext/iconv/iconv.c:866: undefined reference to `libiconv_open'
/usr/local/directadmin/custombuild/php-7.3.26/ext/iconv/iconv.c:890: undefined reference to `libiconv'
/usr/local/directadmin/custombuild/php-7.3.26/ext/iconv/iconv.c:897: undefined reference to `libiconv_open'
/usr/local/directadmin/custombuild/php-7.3.26/ext/iconv/iconv.c:944: undefined reference to `libiconv_close'
/usr/local/directadmin/custombuild/php-7.3.26/ext/iconv/iconv.c:948: undefined reference to `libiconv_close'
ext/iconv/.libs/iconv.o: In function `_php_iconv_mime_encode':
/usr/local/directadmin/custombuild/php-7.3.26/ext/iconv/iconv.c:1186: undefined reference to `libiconv_open'
/usr/local/directadmin/custombuild/php-7.3.26/ext/iconv/iconv.c:1200: undefined reference to `libiconv_open'
/usr/local/directadmin/custombuild/php-7.3.26/ext/iconv/iconv.c:1372: undefined reference to `libiconv'
/usr/local/directadmin/custombuild/php-7.3.26/ext/iconv/iconv.c:1404: undefined reference to `libiconv'
/usr/local/directadmin/custombuild/php-7.3.26/ext/iconv/iconv.c:1460: undefined reference to `libiconv_close'
/usr/local/directadmin/custombuild/php-7.3.26/ext/iconv/iconv.c:1463: undefined reference to `libiconv_close'
/usr/local/directadmin/custombuild/php-7.3.26/ext/iconv/iconv.c:1319: undefined reference to `libiconv'
/usr/local/directadmin/custombuild/php-7.3.26/ext/iconv/iconv.c:1271: undefined reference to `libiconv'
/usr/local/directadmin/custombuild/php-7.3.26/ext/iconv/iconv.c:1303: undefined reference to `libiconv'
/usr/local/directadmin/custombuild/php-7.3.26/ext/iconv/iconv.c:1447: undefined reference to `libiconv'
ext/iconv/.libs/iconv.o: In function `php_iconv_stream_filter_append_bucket':
/usr/local/directadmin/custombuild/php-7.3.26/ext/iconv/iconv.c:2660: undefined reference to `libiconv'
ext/iconv/.libs/iconv.o:/usr/local/directadmin/custombuild/php-7.3.26/ext/iconv/iconv.c:2733: more undefined references to `libiconv' follow
ext/iconv/.libs/iconv.o: In function `php_iconv_string':
/usr/local/directadmin/custombuild/php-7.3.26/ext/iconv/iconv.c:574: undefined reference to `libiconv_open'
/usr/local/directadmin/custombuild/php-7.3.26/ext/iconv/iconv.c:583: undefined reference to `libiconv'
/usr/local/directadmin/custombuild/php-7.3.26/ext/iconv/iconv.c:599: undefined reference to `libiconv'
/usr/local/directadmin/custombuild/php-7.3.26/ext/iconv/iconv.c:609: undefined reference to `libiconv_close'
ext/iconv/.libs/iconv.o: In function `_php_iconv_strpos':
/usr/local/directadmin/custombuild/php-7.3.26/ext/iconv/iconv.c:994: undefined reference to `libiconv_open'
/usr/local/directadmin/custombuild/php-7.3.26/ext/iconv/iconv.c:1022: undefined reference to `libiconv'
/usr/local/directadmin/custombuild/php-7.3.26/ext/iconv/iconv.c:1137: undefined reference to `libiconv_close'
ext/xmlrpc/libxmlrpc/.libs/encodings.o: In function `convert':
/usr/local/directadmin/custombuild/php-7.3.26/ext/xmlrpc/libxmlrpc/encodings.c:65: undefined reference to `libiconv_open'
/usr/local/directadmin/custombuild/php-7.3.26/ext/xmlrpc/libxmlrpc/encodings.c:72: undefined reference to `libiconv'
/usr/local/directadmin/custombuild/php-7.3.26/ext/xmlrpc/libxmlrpc/encodings.c:88: undefined reference to `libiconv_close'
make: *** [sapi/cgi/php-cgi] Error 1
make: *** Waiting for unfinished jobs....
make: *** [sapi/cli/php] Error 1
make: *** [sapi/phpdbg/phpdbg] Error 1
make: *** [sapi/fpm/php-fpm] Error 1
./build all d
  CC       clamscan.o
  CC       manager.o
  CCLD     clamscan
:cry:
PM me the access details and I'll get it fixed for you. libgd needs to be fixed it seems, to fix PHP installation.
