This is an automated message notifying you that the 5 minute load average on your system is 10.11.
This has exceeded the 10 threshold.
One Minute - 15.94
Five Minutes - 10.11
Fifteen Minutes - 4.85
top - 21:15:14 up 20:59, 0 users, load average: 15.94, 10.11, 4.85
Tasks: 107 total, 6 running, 101 sleeping, 0 stopped, 0 zombie
%Cpu(s): 1.1 us, 91.5 sy, 0.0 ni, 7.4 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
MiB Mem : 3072.0 total, 0.1 free, 2994.3 used, 77.6 buff/cache
MiB Swap: 1024.0 total, 158.0 free, 866.0 used. 40.5 avail Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
516 mysql 20 0 1750404 53060 0 S 55.2 1.7 13:15.87 /usr/sbin/mysqld
29529 root 20 0 42400 712 504 R 34.5 0.0 0:02.08 /usr/sbin/sendmail -f root -t
89 root 20 0 126752 52 0 R 27.6 0.0 0:35.19 /usr/lib/systemd/systemd-journald
29462 myuser+ 20 0 2093880 1.7g 22944 R 27.6 56.1 0:42.90 lsphp:omains/mysite.com/private_html/index.php
392 root 20 0 433108 0 0 S 24.1 0.0 0:28.87 /usr/sbin/rsyslogd -n
1 root 20 0 250488 176 84 S 17.2 0.0 0:10.66 init -z
29536 root 20 0 51144 1012 784 R 13.8 0.0 0:00.58 /usr/bin/top -c -b -n 1
22538 apache 20 0 84164 6740 408 R 6.9 0.2 0:27.89 openlitespeed (lshttpd -
22539 apache 20 0 88040 2932 80 S 3.4 0.1 0:25.81 openlitespeed (lshttpd -
94 root 20 0 97168 16 0 S 0.0 0.0 0:00.78 /usr/lib/systemd/systemd-udevd
110 root 20 0 25064 0 0 S 0.0 0.0 0:00.00 /usr/sbin/pure-certd -r /usr/local/bin/pureftpd_sni.sh -s /var/run/pure-certd.sock
114 root 20 0 83676 0 0 S 0.0 0.0 0:00.78 /usr/lib/systemd/systemd-logind
130 root 20 0 58264 0 0 S 0.0 0.0 0:00.00 /usr/sbin/saslauthd -m /run/saslauthd -a pam -n 2
132 root 20 0 58264 8 0 S 0.0 0.0 0:00.00 /usr/sbin/saslauthd -m /run/saslauthd -a pam -n 2
134 dbus 20 0 54072 40 16 S 0.0 0.0 0:04.91 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
381 mail 20 0 65912 12 4 S 0.0 0.0 0:00.38 /usr/sbin/exim -bd -q1h
383 root 20 0 20764 32 0 S 0.0 0.0 0:02.69 /usr/local/directadmin/da-popb4smtp
387 root 20 0 14596 4 4 S 0.0 0.0 0:00.16 /usr/sbin/dovecot -F
389 root 20 0 78508 0 0 S 0.0 0.0 0:00.03 /usr/sbin/sshd -D -oCiphers=aes256-gcm@openssh.com,chacha20-poly1305@openssh.com,aes256-ctr,aes256-cbc,aes128-gcm@openssh.com,aes128-ctr,aes128-cbc -oMACs=hmac-sha2-256-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha2-256,hmac-sha1,umac-128@openssh.com,hmac-sha2-512 -oGSSAPIKexAlgorithms=gss-gex-sha1-,gss-group14-sha1- -oKexAlgorithms=curve25519-sha256,curve25519-sha256@libssh.o+
394 root 20 0 6508 0 0 S 0.0 0.0 0:00.00 /sbin/agetty -o -p -- \u --noclear tty2 linux
395 root 20 0 22852 0 0 S 0.0 0.0 0:03.86 /usr/sbin/crond -n
400 root 20 0 6508 4 0 S 0.0 0.0 0:00.00 /sbin/agetty -o -p -- \u --noclear --keep-baud console 115200,38400,9600 linux
402 root 20 0 241868 0 0 S 0.0 0.0 0:00.21 /usr/sbin/pure-ftpd /etc/pure-ftpd.conf
Connection counts:
1 189.81.219.12
1 192.71.126.175
1 192.71.3.26
IP '192.71.3.26' currently has '1' connections
Connection info for '192.71.3.26':
tcp 25 0 :443 192.71.3.26:41145 CLOSE_WAIT
/usr/sbin/ss output:
NetidState Recv-Q Send-Q Local Address:Port Peer Address:Port
u_strESTAB 0 0 * -647198357 * -647186061
u_strESTAB 0 0 * -647185031 * -647184910
u_strESTAB 0 0 * -647182800 * -647185857
u_strESTAB 0 0 /var/run/dovecot/login/login -647185852 * -647182788
u_strESTAB 0 0 * -647185947 * -647185946
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647184933 * -647185079
u_strESTAB 0 0 * -647185110 * -647185001
u_strESTAB 0 0 * -647185945 * -647185944
u_strESTAB 0 0 /run/systemd/journal/stdout -647189163 * -647208965
u_strESTAB 0 0 * -647185924 * -647185923
u_strESTAB 0 0 * -647185928 * -647185927
u_strESTAB 0 0 * -588964236 * -588964237
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647185903 * -647185905
u_strESTAB 0 0 /var/run/dovecot/config -647184961 * -647185026
u_strESTAB 0 0 /var/run/dovecot/anvil -647185815 * -647185818
u_strESTAB 0 0 * -588792357 * -588780381
u_strESTAB 0 0 * -647185056 * -647184976
u_strESTAB 0 0 * -647185077 * -647184932
u_strESTAB 0 0 /var/run/dovecot/config -647184998 * -647185103
u_strESTAB 0 0 * -588800866 * -588792778
u_strESTAB 0 0 /var/run/dovecot/config -632197802 * -632233271
u_strESTAB 0 0 * -647190730 * -647196892
u_strESTAB 0 0 /var/run/dovecot/anvil -647186097 * -647198375
u_strESTAB 0 0 * -647185021 * -647184905
u_strESTAB 0 0 /var/run/dovecot/config -647184970 * -647185044
u_strESTAB 0 0 * -647185032 * -647184964
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647184931 * -647185075
u_strESTAB 0 0 /var/run/dovecot/stats-writer -598887125 * -598887126
u_strESTAB 0 0 * -647185049 * -647184919
u_strESTAB 0 0 /var/run/dovecot/anvil -640173802 * -640173805
u_strESTAB 0 0 * -647190880 * -647181796
u_strESTAB 0 0 /var/run/dovecot/login/login -647186014 * -647198356
u_strESTAB 0 0 * -647185967 * -647185966
u_strESTAB 0 0 * -647185062 * -647184979
u_strESTAB 0 0 /var/run/dovecot/anvil -647186060 * -647198343
u_strESTAB 0 0 * -647185109 * -647184946
u_strESTAB 0 0 * -647177619 * -647185871
u_strESTAB 0 0 * -647185038 * -647184967
u_strESTAB 0 0 /var/run/dovecot/config -647184992 * -647185088
u_strESTAB 0 0 /var/run/dovecot/anvil -598887120 * -598887123
u_strESTAB 0 0 * -647185128 * -647184954
u_strESTAB 0 0 * -647185901 * -647185900
u_strESTAB 0 0 * -647185985 * -647185984
u_strESTAB 0 0 * -611048791 * -611046203
u_strESTAB 0 0 /var/run/dovecot/config -647184969 * -647185042
u_strESTAB 0 0 /var/run/dovecot/login/login -591782113 * -591782116
u_strESTAB 0 0 * -647185096 * -647184940
u_strESTAB 0 0 * -647194858 * -647194857
u_strESTAB 0 0 /var/run/dovecot/config -647184980 * -647185064
u_strESTAB 0 0 * -647185080 * -647184988
u_strESTAB 0 0 /var/run/dovecot/login/login -647185856 * -647182799
u_strESTAB 0 0 /var/run/dovecot/login/login -647186036 * -647184867
u_strESTAB 0 0 * -647185066 * -647184981
u_strESTAB 0 0 * -647185956 * -647185955
u_strESTAB 0 0 * -647185039 * -647184914
u_strESTAB 0 0 /var/run/dovecot/anvil -647185910 * -647185911
u_strESTAB 0 0 /var/run/dovecot/config -647184971 * -647185046
u_strESTAB 0 0 /var/run/dovecot/config -647184972 * -647185048
u_strESTAB 0 0 * -647185126 * -647184953
u_strESTAB 0 0 * -647185060 * -647184978
u_strESTAB 0 0 * -647184876 * -647186039
u_strESTAB 0 0 * -647182789 * -647185853
u_strESTAB 0 0 /var/run/dovecot/anvil -647186131 * -647184889
u_strESTAB 0 0 /var/run/dovecot/login/login -647186024 * -647186094
u_strESTAB 0 0 /var/run/dovecot/login/login -647186032 * -647186137
u_strESTAB 0 0 * -647185099 * -647184996
u_strESTAB 0 0 * -647198360 * -647186062
u_strESTAB 0 0 /var/run/dovecot/config -591782118 * -591778963
u_strESTAB 0 0 /var/run/dovecot/login/login -647186013 * -647198342
u_strESTAB 0 0 /var/run/dovecot/stats-writer -615138448 * -615138449
u_strESTAB 0 0 * -647184879 * -647186040
u_strESTAB 0 0 * -598887126 * -598887125
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647184954 * -647185128
u_strESTAB 0 0 * -598887127 * -598887124
u_strESTAB 0 0 /var/lib/mysql/mysql.sock -588780381 * -588792357
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647184912 * -647185035
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647184936 * -647185085
u_strESTAB 0 0 * -647185906 * -647185904
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647184926 * -647185065
u_strESTAB 0 0 * -647185071 * -647184929
u_strESTAB 0 0 /var/run/dovecot/login/login -647185964 * -647185965
u_seqESTAB 263 0 /run/systemd/coredump -588763170 * 0
u_strESTAB 0 0 * -647186100 * -647186096
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647184941 * -647185098
u_strESTAB 0 0 * -647185940 * -647185939
u_strESTAB 0 0 /var/run/dovecot/login/login -647186016 * -647186065
u_strESTAB 0 0 /var/run/dovecot/login/login -647186025 * -647186099
u_strESTAB 0 0 /var/run/dovecot/config -647184973 * -647185050
u_strESTAB 0 0 * -647185951 * -647185950
u_strESTAB 0 0 /var/run/dovecot/config -647184985 * -647185074
u_strESTAB 0 0 * -647185028 * -647184962
u_strESTAB 0 0 /run/systemd/journal/stdout -647180217 * -647186855
u_strESTAB 0 0 * -611048792 * -611048789
u_strESTAB 0 0 * -640169958 * -640173806
u_strESTAB 0 0 /var/run/dovecot/login/login -647186043 * -647184888
u_strESTAB 0 0 * -647185037 * -647184913
u_strESTAB 0 0 /var/run/dovecot/config -615144655 * -615138450
u_strESTAB 0 0 * -632233268 * -632197800
u_strESTAB 0 0 * -595257798 * -595257797
u_strESTAB 0 0 /run/systemd/journal/stdout -588883419 * 0
u_strESTAB 0 0 /var/run/dovecot/stats-writer -611063142 * -611063143
u_strESTAB 0 0 * -647185822 * -647185820
u_strESTAB 0 0 /var/run/dovecot/anvil -647186134 * -647184898
u_strESTAB 0 0 /run/systemd/journal/stdout -647181796 * -647190880
u_strESTAB 0 0 * -611063144 * -611063141
u_strESTAB 0 0 /var/run/dovecot/anvil -647185919 * -647185920
u_strESTAB 0 0 * -647181420 * -647181419
u_strESTAB 0 0 * -647185069 * -647184928
u_strESTAB 0 0 /var/run/dovecot/login/login -647185917 * -647185918
u_strESTAB 0 0 /var/run/dovecot/login/login -647185814 * -647185817
u_strESTAB 0 0 * -647185938 * -647185937
u_strESTAB 0 0 * -591778962 * -591782119
u_strESTAB 0 0 * -647182788 * -647185852
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647185948 * -647185949
u_strESTAB 0 0 * -647185078 * -647184987
u_strESTAB 0 0 /var/run/dovecot/login/login -647185944 * -647185945
u_strESTAB 0 0 * -647185971 * -647185970
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647184910 * -647185031
u_strESTAB 0 0 /var/run/dovecot/anvil -647185857 * -647182800
u_strESTAB 0 0 /var/run/dovecot/config -647184976 * -647185056
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647184932 * -647185077
u_strESTAB 0 0 * -647185102 * -647184943
u_strESTAB 0 0 * -632233270 * -632233269
u_strESTAB 0 0 /run/systemd/journal/stdout -647196892 * -647190730
u_strESTAB 0 0 /var/run/dovecot/anvil -647186124 * -647184868
u_strESTAB 0 0 /var/run/dovecot/config -647185970 * -647185971
u_strESTAB 0 0 * -647185978 * -647185975
u_strESTAB 0 0 /var/run/dovecot/config -647185923 * -647185924
u_strESTAB 0 0 /var/run/dovecot/anvil -647185926 * -647185929
u_strESTAB 0 0 * -588964237 * -588964236
u_strESTAB 0 0 * -647185905 * -647185903
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647184934 * -647185081
u_strESTAB 0 0 * -647186138 * -647186120
u_strESTAB 0 0 /var/run/dovecot/config -647184984 * -647185072
u_strESTAB 0 0 * -647185085 * -647184936
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647184905 * -647185021
u_strESTAB 0 0 /var/run/dovecot/config -647184979 * -647185062
u_strESTAB 0 0 * -647186077 * -647186019
u_strESTAB 0 0 /var/run/dovecot/config -640173807 * -640169959
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647184919 * -647185049
u_strESTAB 0 0 * -640173804 * -640173801
u_strESTAB 0 0 /var/run/dovecot/login/login -611046203 * -611048791
u_strESTAB 0 0 * -647185041 * -647184915
u_strESTAB 0 0 * -647185042 * -647184969
u_strESTAB 0 0 * -591782116 * -591782113
u_strESTAB 0 0 /var/run/dovecot/config -647184995 * -647185097
u_strESTAB 0 0 * -647198343 * -647186060
u_strESTAB 0 0 /var/run/dovecot/config -647185001 * -647185110
u_strESTAB 0 0 * -647182795 * -647185855
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647185981 * -647185982
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647184914 * -647185039
u_strESTAB 0 0 * -647185087 * -647184937
u_strESTAB 0 0 * -647198377 * -647186028
u_strESTAB 0 0 /var/run/dovecot/anvil -647185899 * -647185902
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647184924 * -647185061
u_strESTAB 0 0 /var/run/dovecot/login/login -647186039 * -647184876
u_strESTAB 0 0 * -647184889 * -647186131
u_strESTAB 0 0 * -647184898 * -647186134
u_strESTAB 0 0 /var/run/dovecot/anvil -632197800 * -632233268
u_strESTAB 0 0 /var/run/dovecot/login/login -647186035 * -647184864
u_strESTAB 0 0 * -647185063 * -647184925
u_strESTAB 0 0 /var/run/dovecot/config -647184988 * -647185080
u_strESTAB 0 0 * -632233271 * -632197802
u_strESTAB 0 0 * -647182796 * -647185854
u_strESTAB 0 0 * -647184867 * -647186036
u_strESTAB 0 0 /var/lib/mysql/mysql.sock -589036817 * -589036818
u_strESTAB 0 0 /var/run/dovecot/anvil -615138444 * -615138447
u_strESTAB 0 0 /var/run/dovecot/anvil -647186127 * -647184877
u_strESTAB 0 0 * -647185911 * -647185910
u_strESTAB 0 0 * -647185046 * -647184971
u_strESTAB 0 0 * -647185047 * -647184918
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647184953 * -647185126
u_strESTAB 0 0 /var/run/dovecot/config -599957731 * -599957732
u_strESTAB 0 0 /var/run/dovecot/config -647185930 * -647185933
u_strESTAB 0 0 * -647185084 * -647184990
u_strESTAB 0 0 /var/run/dovecot/login/login -647185908 * -647185909
u_strESTAB 0 0 * -647185065 * -647184926
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647184929 * -647185071
u_strESTAB 0 0 /var/run/dovecot/stats-writer -599978234 * -599957730
u_strESTAB 0 0 /var/run/dovecot/anvil -599978233 * -599957729
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647185912 * -647185913
u_strESTAB 0 0 * -647185127 * -647185009
u_strESTAB 0 0 /var/run/dovecot/config -647184962 * -647185028
u_strESTAB 0 0 * -647186855 * -647180217
u_strESTAB 0 0 /var/run/dovecot/anvil -611048789 * -611048792
u_strESTAB 0 0 * -647184886 * -647186130
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647184913 * -647185037
u_strESTAB 0 0 * -615138449 * -615138448
u_strESTAB 0 0 /var/run/dovecot/stats-writer -632233269 * -632233270
u_strESTAB 0 0 * -595257797 * -595257798
u_strESTAB 0 0 * -647185965 * -647185964
u_strESTAB 0 0 * -647185098 * -647184941
u_strESTAB 0 0 * -647185929 * -647185926
u_strESTAB 0 0 /var/run/dovecot/config -647185941 * -647185942
u_strESTAB 0 0 * -647186099 * -647186025
u_strESTAB 0 0 /var/run/dovecot/config -647185950 * -647185951
u_strESTAB 0 0 * -647185074 * -647184985
u_strESTAB 0 0 /var/run/dovecot/config -647184983 * -647185070
u_strESTAB 0 0 * -647185082 * -647184989
u_strESTAB 0 0 * -647185918 * -647185917
u_strESTAB 0 0 * -647185817 * -647185814
u_strESTAB 0 0 /var/run/dovecot/anvil -647185937 * -647185938
u_strESTAB 0 0 * -647186066 * -647186063
u_strESTAB 0 0 /var/run/dovecot/config -647185820 * -647185822
u_strESTAB 0 0 * -611063143 * -611063142
u_strESTAB 0 0 * -647185922 * -647185921
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647184908 * -647185027
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647185819 * -647185821
u_strESTAB 0 0 * -647185055 * -647184921
u_strESTAB 0 0 * -647185076 * -647184986
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647184943 * -647185102
u_strESTAB 0 0 * -615138450 * -615144655
u_strESTAB 0 0 /var/run/dovecot/login/login -647186028 * -647198377
u_strESTAB 0 0 * -647184868 * -647186124
u_strESTAB 0 0 * -647185022 * -647184959
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647184917 * -647185045
u_strESTAB 0 0 /var/run/dovecot/login/login -647185975 * -647185978
u_strESTAB 0 0 * -647184862 * -647188078
u_strESTAB 0 0 * -647198359 * -647186015
u_strESTAB 0 0 /var/run/dovecot/anvil -647185966 * -647185967
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647184907 * -647185025
u_strESTAB 0 0 /var/run/dovecot/anvil -647185957 * -647185958
u_strESTAB 0 0 /var/run/dovecot/config -647184987 * -647185078
u_strESTAB 0 0 * -647185942 * -647185941
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647185871 * -647177619
u_strESTAB 0 0 * -647186055 * -647186053
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647184937 * -647185087
u_strESTAB 0 0 * -647185103 * -647184998
u_strESTAB 0 0 * -591782117 * -591782114
u_strESTAB 0 0 * -598887123 * -598887120
u_strESTAB 0 0 /var/run/dovecot/anvil -647186105 * -647198378
u_strESTAB 0 0 * -647185129 * -647185010
u_strESTAB 0 0 * -647185203 * -647185202
u_strESTAB 0 0 * -647185982 * -647185981
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647184915 * -647185041
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647184916 * -647185043
u_strESTAB 0 0 /var/run/dovecot/anvil -591782114 * -591782117
u_strESTAB 0 0 /var/run/dovecot/anvil -647186074 * -647186078
u_strESTAB 0 0 /var/run/dovecot/config -647184986 * -647185076
u_strESTAB 0 0 /var/lib/mysql/mysql.sock -589013527 * -589013528
u_strESTAB 0 0 * -640169959 * -640173807
u_strESTAB 0 0 * -647185048 * -647184972
u_strESTAB 0 0 * -647190997 * -647190996
u_strESTAB 0 0 /var/run/dovecot/anvil -647186061 * -647198357
u_strESTAB 0 0 /run/dbus/system_bus_socket -647199293 * -647190973
u_strESTAB 8 0 /tmp/lshttpd/lsphp74.sock.10010 -589118336 * 0
u_strESTAB 0 0 * -647185081 * -647184934
u_strESTAB 0 0 /var/run/dovecot/config -647185961 * -647185962
u_strESTAB 0 0 /run/systemd/journal/stdout -647198269 * -647204339
u_strESTAB 0 0 * -647185072 * -647184984
u_strESTAB 0 0 /var/run/dovecot/config -647184991 * -647185086
u_strESTAB 0 0 * -647185061 * -647184924
u_strESTAB 0 0 * -599957729 * -599978233
u_strESTAB 0 0 * -647185059 * -647184923
u_strESTAB 0 0 * -647185913 * -647185912
u_strESTAB 0 0 * -647184880 * -647186128
u_strESTAB 0 0 /var/run/dovecot/login/login -647186046 * -647184897
u_strESTAB 0 0 * -632233267 * -632197799
u_strESTAB 0 0 /var/run/dovecot/config -647185009 * -647185127
u_strESTAB 0 0 /var/run/dovecot/login/login -599978232 * -599957728
u_strESTAB 0 0 /var/run/dovecot/login/login -598887119 * -598887122
u_strESTAB 0 0 * -647185933 * -647185930
u_strESTAB 0 0 /var/run/dovecot/config -647184966 * -647185036
u_strESTAB 0 0 /var/run/dovecot/config -647184990 * -647185084
u_strESTAB 0 0 * -647185070 * -647184983
u_strESTAB 0 0 * -599957730 * -599978234
u_strESTAB 0 0 * -647184864 * -647186035
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647184925 * -647185063
u_strESTAB 0 0 * -647185079 * -647184933
u_strESTAB 0 0 * -647177620 * -647185872
u_strESTAB 0 0 * -615138446 * -615138443
u_strESTAB 0 0 /var/run/dovecot/anvil -647185853 * -647182789
u_strESTAB 0 0 * -647184877 * -647186127
u_strESTAB 0 0 * -647185040 * -647184968
u_strESTAB 0 0 * -591778963 * -591782118
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647184918 * -647185047
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647185959 * -647185960
u_strESTAB 0 0 /var/run/dovecot/anvil -647186092 * -647186095
u_strESTAB 0 0 /var/run/dovecot/anvil -647186120 * -647186138
u_strESTAB 0 0 * -647185979 * -647185976
u_strESTAB 0 0 * -647198374 * -647186026
u_strESTAB 0 0 * -647185208 * -647185201
u_strESTAB 0 0 * -647185821 * -647185819
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647184921 * -647185055
u_strESTAB 0 0 /var/run/dovecot/config -611063141 * -611063144
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647185921 * -647185922
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647184935 * -647185083
u_strESTAB 0 0 * -647185936 * -647185935
u_strESTAB 0 0 /var/run/dovecot/config -647185854 * -647182796
u_strESTAB 0 0 /var/run/dovecot/config -598887124 * -598887127
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647185931 * -647185932
u_strESTAB 0 0 /var/run/dovecot/anvil -647186063 * -647186066
u_strESTAB 0 0 * -647185949 * -647185948
u_strESTAB 0 0 * -647184885 * -647186042
u_strESTAB 0 0 * -647185027 * -647184908
u_strESTAB 0 0 /run/systemd/journal/stdout -647188271 * -647188272
u_strESTAB 0 0 * -647185962 * -647185961
u_strESTAB 0 0 /var/run/dovecot/anvil -647186130 * -647184886
u_strESTAB 0 0 * -647185036 * -647184966
u_strESTAB 0 0 /tmp/lshttpd/lsphp74.sock.10010 -588792778 * -588800866
u_strESTAB 0 0 * -647185969 * -647185968
u_strESTAB 0 0 * -647198375 * -647186097
u_strESTAB 0 0 /var/run/dovecot/config -647184959 * -647185022
u_strESTAB 0 0 * -647185044 * -647184970
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647188078 * -647184862
u_strESTAB 0 0 /var/run/dovecot/login/login -647186019 * -647186077
u_strESTAB 0 0 /var/run/dovecot/config -647184964 * -647185032
u_strESTAB 0 0 /var/run/dovecot/login/login -647185927 * -647185928
u_strESTAB 0 0 * -647185902 * -647185899
u_strESTAB 0 0 * -647185026 * -647184961
u_strESTAB 0 0 * -647185818 * -647185815
u_strESTAB 0 0 * -640173805 * -640173802
u_strESTAB 0 0 /var/run/dovecot/anvil -647185946 * -647185947
u_strESTAB 0 0 * -647185958 * -647185957
u_strESTAB 0 0 * -647208965 * -647189163
u_strESTAB 0 0 /var/run/dovecot/login/login -647186015 * -647198359
u_strESTAB 0 0 * -647185025 * -647184907
u_strESTAB 0 0 * -647182799 * -647185856
u_strESTAB 0 0 * -647185043 * -647184916
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647184940 * -647185096
u_strESTAB 0 0 /run/systemd/journal/stdout -647194857 * -647194858
u_strESTAB 0 0 * -647198342 * -647186013
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647184946 * -647185109
u_strESTAB 0 0 /var/run/dovecot/anvil-auth-penalty -647186053 * -647186055
u_strESTAB 0 0 /var/run/dovecot/config -647184967 * -647185038
u_strESTAB 0 0 * -589013528 * -589013527
u_strESTAB 0 0 * -598887122 * -598887119
u_strESTAB 0 0 * -647198378 * -647186105
u_strESTAB 0 0 /var/run/dovecot/config -647185010 * -647185129
u_strESTAB 0 0 * -647185202 * -647185203
u_strESTAB 0 0 /var/run/dovecot/login/login -647185900 * -647185901
u_strESTAB 0 0 /var/run/dovecot/config -647185984 * -647185985
u_strESTAB 0 0 * -647198356 * -647186014
u_strESTAB 0 0 * -647190973 * -647199293
u_strESTAB 0 0 /var/run/dovecot/config -647184989 * -647185082
u_strESTAB 0 0 * -647185960 * -647185959
u_strESTAB 0 0 * -647204339 * -647198269
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647184930 * -647185073
u_strESTAB 0 0 * -647185086 * -647184991
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647185968 * -647185969
u_strESTAB 0 0 * -647186078 * -647186074
u_strESTAB 0 0 * -647185075 * -647184931
u_strESTAB 0 0 /var/run/dovecot/login/login -640173801 * -640173804
u_strESTAB 0 0 /run/systemd/journal/stdout -647190996 * -647190997
u_strESTAB 0 0 * -599957728 * -599978232
u_strESTAB 0 0 * -599957732 * -599957731
u_strESTAB 0 0 /var/run/dovecot/login/login -647185935 * -647185936
u_strESTAB 0 0 * -647185035 * -647184912
u_strESTAB 0 0 /var/run/dovecot/config -647185904 * -647185906
u_strESTAB 0 0 * -647185064 * -647184980
u_strESTAB 0 0 /var/run/dovecot/anvil -647186062 * -647198360
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647184923 * -647185059
u_strESTAB 0 0 * -615138447 * -615138444
u_strESTAB 0 0 /var/run/dovecot/config -647185914 * -647185915
u_strESTAB 0 0 /var/run/dovecot/anvil -647186128 * -647184880
u_strESTAB 0 0 /var/run/dovecot/login/login -632197799 * -632233267
u_strESTAB 0 0 /var/run/dovecot/config -647184978 * -647185060
u_strESTAB 0 0 * -647184888 * -647186043
u_strESTAB 0 0 * -647186094 * -647186024
u_strESTAB 0 0 * -647186137 * -647186032
u_strESTAB 0 0 /var/run/dovecot/config -647184996 * -647185099
u_strESTAB 0 0 /var/run/dovecot/anvil -647186123 * -647184865
u_strESTAB 0 0 * -647184865 * -647186123
u_strESTAB 0 0 /var/run/dovecot/config -647184981 * -647185066
u_strESTAB 0 0 * -589036818 * -589036817
u_strESTAB 0 0 /var/run/dovecot/login/login -615138443 * -615138446
u_strESTAB 0 0 /var/run/dovecot/login/login -647185955 * -647185956
u_strESTAB 0 0 /var/run/dovecot/login/login -647186040 * -647184879
u_strESTAB 0 0 /var/run/dovecot/config -647184968 * -647185040
u_strESTAB 0 0 * -647185909 * -647185908
u_strESTAB 0 0 * -647185045 * -647184917
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647184928 * -647185069
u_strESTAB 0 0 * -647185083 * -647184935
u_strESTAB 0 0 * -647185915 * -647185914
u_strESTAB 8 0 /tmp/lshttpd/lsphp74.sock.10010 -589050376 * 0
u_strESTAB 0 0 /var/run/dovecot/stats-writer -591782119 * -591778962
u_strESTAB 0 0 /var/run/dovecot/anvil -647185976 * -647185979
u_strESTAB 0 0 /var/run/dovecot/login/login -647186026 * -647198374
u_strESTAB 0 0 /run/dbus/system_bus_socket -647185201 * -647185208
u_strESTAB 0 0 * -647184897 * -647186046
u_strESTAB 0 0 * -647185920 * -647185919
u_strESTAB 0 0 * -647181419 * -647181420
u_strESTAB 0 0 /var/run/dovecot/login/login -647186042 * -647184885
u_strESTAB 0 0 * -647188272 * -647188271
u_strESTAB 0 0 /var/run/dovecot/stats-writer -640173806 * -640169958
u_strESTAB 0 0 * -647185088 * -647184992
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647185855 * -647182795
u_strESTAB 0 0 /var/run/dovecot/config -647185872 * -647177620
u_strESTAB 0 0 /var/run/dovecot/anvil -647186096 * -647186100
u_strESTAB 0 0 * -647185097 * -647184995
u_strESTAB 0 0 * -647185932 * -647185931
u_strESTAB 0 0 /var/run/dovecot/stats-writer -647185939 * -647185940
u_strESTAB 0 0 * -647186065 * -647186016
u_strESTAB 0 0 * -647186095 * -647186092
u_strESTAB 0 0 * -647185050 * -647184973
u_strESTAB 0 0 * -647185073 * -647184930
tcp LAST-ACK 0 1116 :80 192.71.126.175:34331
tcp CLOSE-WAIT 25 0 :443 192.71.3.26:41145
tcp ESTAB 0 0 :21 189.81.219.12:10966
Top Memory Usage:
myuser+ 29462 11.7 56.4 2096128 1777192 ? Dsl 21:09 0:46 lsphp:omains/mysite.com/private_html/index.php
mysql 516 1.0 1.6 1750404 51356 ? Ssl 00:15 13:21 /usr/sbin/mysqld
apache 22538 0.3 0.2 84164 8076 ? S 18:55 0:28 openlitespeed (lshttpd -
root 29580 0.0 0.1 44592 3384 ? R 21:15 0:00 /bin/ps aux
root 29577 0.0 0.1 250492 4488 ? RNs 21:15 0:00 (coredump)
root 29506 3.0 0.1 96940 5688 ? R 21:12 0:05 lfd - child closing
root 1 0.0 0.1 250488 5472 ? Ss 00:15 0:10 init -z
myuser+ 29525 2.1 0.1 308300 3460 ? Rs 21:14 0:01 lsphp:omains/mysite.com/private_html/index.php
root 29583 0.0 0.0 38072 1364 ? Rs 21:15 0:00 /usr/sbin/exim -Mc 1kwFP9-0007gH-NF
root 29582 0.0 0.0 4356 732 ? S 21:15 0:00 head
Virtual Memory Info:
procs -----------------------memory---------------------- ---swap-- -----io---- -system-- --------cpu-------- -----timestamp-----
r b swpd free buff cache si so bi bo in cs us sy id wa st EST
6 0 282960 1032616 0 223812 0 0 20 12 0 53 1 1 98 0 0 2021-01-03 21:15:56
0 3 258780 2751564 0 262864 12 0 9976 1292 0 1083 20 27 53 0 0 2021-01-03 21:15:57
0 0 257680 2723780 0 285948 0 0 12660 12 0 1068 12 12 77 0 0 2021-01-03 21:15:58
Current MySQL Queries
1 system user NULL Daemon NULL InnoDB purge worker NULL 0.000
2 system user NULL Daemon NULL InnoDB purge coordinator NULL 0.000
3 system user NULL Daemon NULL InnoDB purge worker NULL 0.000
4 system user NULL Daemon NULL InnoDB purge worker NULL 0.000
5 system user NULL Daemon NULL InnoDB shutdown handler NULL 0.000
1764 da_admin localhost NULL Query 0 Init SHOW FULL PROCESSLIST 0.000
Automated Message Generated by DirectAdmin 1.61.5
