How to disable directory path + compressing zip files
jj20051
When I add files to the clipboard and compress them using zip it includes the full path of the files (IE: /domains/public_html? etc...) how do I disable this either temporarily or permanently so that the files compressed only include the folders/files I want?
Example: If I select a folder and a few files it should put the files in the root directory of the .zip and the folder in the root directory along with them... Like cpanel does. :(
No one replied since last 10 years. I also want to resolve this issue ? This is a basic requirement.
Did you guy resolved this issue ? I am also using cpanel since last 10+ years and there is this basic function which is very useful.
First welcome to the forums and to directadmin.
If you need to ask for a improvement to the system. Please look here https://feedback.directadmin.com/
If you need to know how the system works or learn about it look here. New: https://docs.directadmin.com/ Old: https://help.directadmin.com/
Use of the System: https://www.site-helper.com/evo/sitehelper.php
Features: https://www.directadmin.com/versions.php
All these areas are searchable. The best thing to do is set up a test server and try it all out.
If you find a bug report it in the relative forum put the word BUG in the subject line. Directadmin doesn't have a real bug reporting application
Also this is a community forum no one has to reply. The forum is not a Company driven forum.
Please try not to bump an old post.
Again welcome.
Hope some of this helps.
Thanks i will create new post if any query......
thanks again for quick response...
