UDP named DDOS
qba82
I'm receiving often DDOS on my IP, attack is aimed into UDP named service, what is best and cost effective solutions for such an attacks? I don't want to discus DC protection here, because it might be insufficient.
Hi
Is it a DNS amplification attack?
Only thing you can do is to limit the requests / second with bind.
Kr
Dries
Use a software or hardware firewall to filter out automated, suspicious traffic. If you are lucky, a software firewall is enough. If you are unlucky, try to replace the software of the attacked service with a more performant one. If that's not working out too, you have to use some kind of CDN to hide your server IP address or get a hardware firewall. Depending on your provider, you might have such a solution already or can order it for a high or low price.
You might look through here and tweak the firewall.
Thank You all for Your answers.
Ddos attack is handled well by my server which has quite good configuration, problem is that my DC is blackholing my connection after some level of attack, which causing that server is not available. I already configured csf to block too many bad named requests, but I can't do anything if DC will blackhole me for few minutes or even half of an hour. Most likely will have to look for DC with better ddos protection.
