Cloudlinux + Litespeed + Directadmin -> Different php versions per account
ViAdCk
Has anyone running cloudlinux+litespeed+directadmin been able to offer different php versions for domains configured in the same hosting account?
Litespeed has a guide but it's only for native: https://www.litespeedtech.com/support/wiki/doku.php/litespeed_wiki:php:per-directory-php
And cloudlinux has a guide but it's focused on apache and cpanel: https://www.cloudlinux.com/cloudlin...-php-versions-per-directories-using-mod-lsapi
Hay anyone been able to get this configured on directadmin?
Thanks in advance!
If you select lsphp as PHP mode, CloudLinux PHP selector should work fine out-of-the-box.
Hi Martynas,
Yes, cloudlinux php selector works just fine but with only 1 php version per account. Some users have various domains in their hosting accounts and would like to assign a different php version for each domain.
Any idea how this can be configured on cloudlinux + directadmin + litespeed?
Regards
old post but I had this issue, but solved with this :
add this line as you need on /etc/container/php.handler
application/x-lsphp52 /opt/alt/php52/usr/bin/lsphp
application/x-lsphp53 /opt/alt/php53/usr/bin/lsphp
application/x-lsphp54 /opt/alt/php54/usr/bin/lsphp
application/x-lsphp55 /opt/alt/php55/usr/bin/lsphp
application/x-lsphp56 /opt/alt/php56/usr/bin/lsphp
application/x-lsphp70 /opt/alt/php70/usr/bin/lsphp
application/x-lsphp71 /opt/alt/php71/usr/bin/lsphp
application/x-lsphp72 /opt/alt/php72/usr/bin/lsphp
application/x-lsphp73 /opt/alt/php73/usr/bin/lsphp
application/x-lsphp74 /opt/alt/php74/usr/bin/lsphp
create a file /etc/cl.selector/symlinks.rules add the following content: php.d.location = selector
And run the command to apply changes:
/usr/bin/selectorctl --apply-symlinks-rules
The most important thing is to check back in the litespeed panel for the External App and Script Handler for all php versions.
I didn't know it wasn't generated automatically when I installed litespeed on cloudlinux + php selector
the last use .htaccess to handle php version for example using 7.1 put inside subdomain folder/folder
<FilesMatch "\.(php4|php5|php3|php2|php|phtml)$">
SetHandler application/x-lsphp71
</FilesMatch>
i hope this help :)
i hope this help :)
we use such selector too, on any servers, with cloudlinux - as you described, without cloudlinux - php installed by YUM from REMI :)
today added php 8.1, and if PHP files uploaded, but not executed:
1. add to /etc/container/php.handler
application/x-lsphp81 /opt/alt/php81/usr/bin/lsphp
2. from DA -> Cloudlinux LVE manager -> Options -> CageFS
near CageFS Skeleton press button: Update
3. from ssh console:
cagefsctl --force-update
How do we "check back" and add it properly so that it functions as expected?
I think I figured it out, added the following in /usr/local/lsws/conf/httpd_config.xml just before the ending XML tag:
<extProcessorList> <extProcessor> <type>lsapi</type> <name>lsphp80</name> <address>uds://tmp/lshttpd/lsphp80.sock</address> <maxConns>160</maxConns> <env>PHP_LSAPI_MAX_REQUESTS=160</env> <env>PHP_LSAPI_CHILDREN=80</env> <initTimeout>60</initTimeout> <retryTimeout>0</retryTimeout> <persistConn>1</persistConn> <respBuffer>0</respBuffer> <autoStart>3</autoStart> <path>/opt/alt/php80/usr/bin/lsphp</path> <backlog>100</backlog> <instances>1</instances> <extMaxIdleTime>70</extMaxIdleTime> <priority>0</priority> <memSoftLimit>2047M</memSoftLimit> <memHardLimit>2047M</memHardLimit> <procSoftLimit>400</procSoftLimit> <procHardLimit>500</procHardLimit> </extProcessor> </extProcessorList>
Note: Must validate your XML using an XML validator before restarting the server to avoid missing something and risking unnecessary downtime.
For other PHP versions (other than php8) simply replicate the config with different PHP directories/binaries, change all occurrences of lsphp80 to lsphp81 and path from /opt/alt/php80/usr/bin/lsphp to /opt/alt/php81/usr/bin/lsphp.
Don't need above code. Go to Litespeed Web Admin Console, enable Detached Mod and control panel is Directadmin.
When you select php in Domain setup, it will change php for domain. php in litespeed is default version
