Disable firewall for a site
iPwsite
How to disable Firewall & Mod Security for a particular website (just one web not server) via Direct admin panel interface ?
The reason we ask is because some feature of our web doesn’t work. And the thene developer suggested to disable this feature .
DA has a new option to control modsecurity. Log in in your DA panel go to the desired user and go to the domain setup. There you find an modsecurity option. You can enable/disable modsecurity and disable rules by entering their id. (You should browse to your log files to find out which id is causing trouble, so best first disable modsecurity to find out if that solves your problem.)
If you have multiple ip's at your disposal, you could assign a specific ip to the site for which you want to disable the firewall. Then exclude it in iptables or firewalld.
