./build update - MD5 Checksum for patches_versions.txt Failed
Tristan
The Netherlands
Getting this this morning for all servers using files.directadmin.com:
# ./build update
--2021-01-21 12:11:51--  https://files.directadmin.com/services/custombuild/2.0/custombuild.tar.gz
Resolving files.directadmin.com (files.directadmin.com)... 104.128.54.74, 185.42.221.168, 69.162.69.58
Connecting to files.directadmin.com (files.directadmin.com)|104.128.54.74|:443... connected.
Length: 258162 (252K) [application/x-gzip]
Saving to: './custombuild.tar.gz'
./custombuild.tar.gz                              100%[=============================================================================================================>] 252.11K   798KB/s    in 0.3s
2021-01-21 12:11:51 (798 KB/s) - './custombuild.tar.gz' saved [258162/258162]
Extracting custombuild.tar.gz...
*** MD5 Checksum for patches_versions.txt Failed.  Redownloading...***
Downloading        patches_versions.txt...
--2021-01-21 12:11:52--  https://files.directadmin.com/services/custombuild/patches_versions.txt
Length: 3335 (3.3K) [text/plain]
Saving to: '/usr/local/directadmin/custombuild/patches_versions.txt'
/usr/local/directadmin/custombuild/patches_versio 100%[=============================================================================================================>]   3.26K  --.-KB/s    in 0s
2021-01-21 12:11:52 (119 MB/s) - '/usr/local/directadmin/custombuild/patches_versions.txt' saved [3335/3335]
*** MD5 Checksum for patches_versions.txt failed *again*.***
The md5 checksum value may be incorrect, or a wrong file is being downloaded.
Install continuing with this possibly corrupted file. (it may also be fine)
Just a isolated problem with files not being completely updated with new checksums or something more serious?
Now having the same problem with the mirrors but I guess these will be updated as soon as they're synced.
./build set_fastest
Make sure you have
unofficial_mirrors
set to no in the options.conf
