[Security] sudo - Privilege escalation via command line argument parsing - (CVE-2021-3156)
ccto
Hong Kong
A flaw was found in sudo. A heap-based buffer overflow was found in the way sudo parses command line arguments. This flaw is exploitable by any local user (normal users and system users, sudoers and non-sudoers), without authentication (i.e., the attacker does not need to know the user's password). Successful exploitation of this flaw could lead to privilege escalation. The highest threat from this vulnerability is to data confidentiality and integrity as well as system availability.
ref.:
Ok now it is out some Admins have te react more fast i guess.
Sudo versions affected:​
Sudo versions 1.8.2 through 1.8.31p2 and 1.9.0 through 1.9.5p1 are affected.
In case you have no update available or your os is a bit older:
# yum -y install git
# cd /opt
# git clone https://github.com/sudo-project/sudo.git
# cd sudo
# ./configure --prefix=/usr
# make
# make install
test with:
sudoedit -s '\' `perl -e 'print "A" x 65536'`
A 'usage' message is ok, a segmentation error = vulnerable.
I see this: -bash: sudo: command not found
I have CentOS 7 and it looks like i've not installed sudo?
And i see also no sudo updatepackage with yum check-update
Normally, i can use su to elevate to root.
Can someone explain this?
sudo en su are different tools. 'su' is simply to switch between users and 'sudo' is to execute a command as a different user.
sudo is not installed by default on CentOS 7 and maybe 8. So yes you may never have used it or installed it.
Well, never assume anything. But it's your own server so you should know it best ;)
True, for a while I was under the impression that it would also be standard in CentOS 7.
But that is not the case. As far as I know it was in CentOS 6.
It's clear for me now.
