Blank page on phpmyadmin SSO for user
Richard G
Maastricht
When I login as the user, choose mysql, choose a database and click the phpmyadmin SSO I only get a blank page.
When logging in as a reseller, list users, select user and login as the user (so via being logged in as reseller), choose database and click phpmyadmin SSO I get the database page of phpmyadmin as should be.
So if it functions this way via reseler, why do I get a blank page when using it being logged in directly with the useraccount?
Seen nothing. It's very odd. Monday I could do what I want, only visible when logging in via reseller.
So you answered and today I had another look, just to be sure, and now I can see any database I want logged in as the user.
No blank pages, no issues. Very odd.
Shall we blame a small solar flare :cool:
Oke I found the cause. Some other people might walk into the same issue.
And I just remember that I've mentioned this like 1 or 2 years ago (but then with just phpmyadmin login without sso), but nothing was done about it. As far as I'm concerned, it's a DA bug.
If "force redirect to www" is in effect you can still login to DA via domain.com without www. If you do that and force redirect to www is in effect, then you will get a blank page on phpmyadmin SSO.
Probably it will be the same if you login to DA with www and force redirect to non-www is in effect.
Why it's not happening when logging in via reseller or admin account, even without www, I have no clue. Must be some redirect issue somewhere in DA.
So if anybody encounters blank phpmyadmin SSO pages, check if and which redirects are in effect.
awesome work my friend.. so I am not to blame now?
